Everything posted by Carlston
Karoq 19 Inch wheels
Michelin don't make any such claims about XL being better at protecting your rims than SL.
Tyre sizing for 2005 Skoda Fabia 1.9TDi
It sounds like you need 185/60R14. This is one of the standard tyre sizes for the Fabia MK1 1.9TDI 100HP, and is the standard tyre size if you have the 6Jx14 ET37 rim specification. The only other Fabia MK1 14" rim specification is a 1" narrower 5Jx14 ET35, but that normally comes with a narrower 165/70R14 tyre size, not the wider 185/60R14. 185/60R14 is an economical tyre size, as shown in the example below. Vredestein Quatrac 5 185/60R14 82H https://www.camskill.co.uk/m137b0s7979p134033/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_185_60_R14_82H_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_69dB
Yes. 16" wheels will give the best ride. The comfort of 17" wheels won't be quite as good as the 16", but they will still be in a different league to the hard riding 19" wheels. Alcar 6665 6Jx16 ET43 5/112 57.1 steel rims (from Karoq) https://www.autodoc.co.uk/alcar/14750540?search=ALCAR+Rim+(6665) This Czech website shows the Karoq alloy rims from the Skoda alloy rim accessory catalogue, but you should be able to order them from any UK VAG parts department. Karoq alloy rims (from Skoda alloy rim accessory catalogue) (photo below shows 7Jx17 ET45 5/112 57.1 alloy rim) https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AKaroq%2B%282017%2B%29&page=1
New to me L&K Superb: spare wheel question please
It was JR RS (not me) who fitted a 235/40R19 (or might have been a slightly oversize 245/40R19) in the spare wheel well, and he has a Superb MK3 2.0TSI 162kW/220HP front wheel drive. Photos on this thread. https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/
Is it this one (shown on "skoda eshop cz"), designed for the Superb MK3 2.0TSI with 200kW/206kW engines? 18" Spare Wheel Replacement Kit (this product is designed for Superb MK3 2.0TSI 200kW/206kW. This product is not intended for Superb iV hybrid vehicles) https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/3V0093860E If so, I don't know if there will be room for a full size spare...even a relatively narrow 215mm wide one. However, you would need somewhere to put the punctured 235/45R18 or 235/40R19 tyre...so maybe it would fit. Sometimes a 4x4 system can reduce the amount of space in the spare wheel well for a full size spare wheel.
You would have to let all the air out. Even 1psi is going to push the sidewalls out. I don't know how keeping a spare tyre in the boot for years with no air (0 psi) would affect the long term health of the tyre.
Replacing Yeti
autodoc lists 280mm and 305mm front brake discs for various models of Kia Niro. 15" wheels should clear 280mm front brake discs, and 16" wheels should clear 305mm front brake discs. So as 16" wheels are the smallest standard size on the Kia Niro, they should fit all models.
Replacing Yeti
The link was to give an example of a 225/60R18 tyre, not to promote mytyres or any other tyre seller. I would have linked to camskill instead, but they aren't currently listing the latest Continental AllSeasonContact 2 in that tyre size.
Replacing Yeti
Great idea. Adding 10mm to the standard 215/60R18 would solve the problem of non-available all season tyres. Not cheap though at about £150 each tyre. Continental AllSeasonContact 2 225/60R18 100H https://www.mytyres.co.uk/rshop/tyre/Continental/AllSeasonContact-2/225-60-R18-100H-EVc/D-127997 Outside diameter of tyre 215/60R18 715.2mm 225/60R18 727.2mm (+1.7% bigger outside diameter compared to 215/60R18)
The Superb III Wheel Fitment Topic
The Superb MK3 2.0TSI 200kW has 340x30mm front brake discs, so 16" wheel options won't fit. Some owners have increased the width of their tyre sizes by +10mm on the standard rims as follows. Some +10mm tyre sizes 225/55R17 7Jx17 ET40 245/45R18 8Jx18 ET44 245/40R19 8Jx19 ET44 Superb MK3 280HP 4x4 fitted with slightly oversize 245/45R18 tyres to the standard 8Jx18 ET44 rims
Skoda Octavia MK3 5E brake pad sizes
I suggest you avoid Brembo brake pads with the 340x30mm front brake discs because many owners have reported noise problems over the years. The Octavia MK3 VRS pre-facelift has 340x30mm front brake discs and 272x10mm rear brake discs. The Octavia MK3 VRS petrol facelift has 340x30mm front brake discs and 310x22mm rear brake discs. The Octavia MK3 VRS diesel facelift has 312x25mm front brake discs and 272x10mm rear brake discs. Here's a complete list of TRW brake pads and ATE brake discs for the Octavia MK3. ATE brake discs have the superior coated finish whereas the TRW brake discs have the inferior painted finish. So ATE brake discs should be more resistant to corrosion than TRW brake discs. If you're looking for a cheaper aftermarket alternative, perhaps look at Jurid. Like ATE, Jurid use coated brake discs. Notice that there are two versions of the 253x10mm rear brake discs. One version is for the pre-facelift model and one version is for the facelift model. Surprisingly, both versions have the same build code 1KD even though these two different rear brake discs are not interchangeable. Octavia MK3 Brake Pads and Brake Discs TRW Front Brake Pads 1ZF 276x24mm TRW GDB2080 1ZE 288x25mm TRW GDB1956 1ZA 312x25mm TRW GDB1956 1ZB 312x25mm TRW GDB1956 1LG 340x30mm TRW GDB2114 TRW Rear Brake Pads 1KD 253x10mm TRW GDB1330 1KS 272x10mm TRW GDB2042 1KT 272x10mm TRW GDB2042 1KW 310x22mm TRW GDB1622 ATE Front Brake Discs 1ZF 276x24mm ATE 24012402581 1ZE 288x25mm ATE 24012501451 1ZA 312x25mm ATE 24012501581 1ZB 312x25mm ATE 24012501581 1LG 340x30mm ATE 24013002251 ATE Rear Brake Discs 1KD 253x10mm ATE 24011002771 (pre-facelift model) 1KD 253x10mm ATE 24011004201 (facelift model) 1KS 272x10mm ATE 24011003561 1KT 272x10mm ATE 24011003561 1KW 310x22mm ATE 24012202191 As you can see in the below diagrams of the two different 253mm rear brake discs, it's the "D" dimension that is the difference between them. So they are not interchangeable. 1KD 253x10mm rear brake disc ATE 24011002771 (pre-facelift model) 1KD 253x10mm rear brake disc ATE 24011002771 (facelift model)
Replacing Yeti
If the new Duster MK3 comes with 18" wheels I doubt the dealer would change them to 17" wheels. I asked for something similar on a new VAG car, but the dealer had no interest in swapping the wheels around. You had to accept delivery of the car with the wheels that it left the factory with. It's possible 17" wheels from the Nissan Qashqai 2021- would fit the Duster MK3, but you would have to check the specification especially the offset. I expect there's also alloy rims in this specification. The Nissan Qashqai (gen. III) 2021- uses the same 215/65R17 tyre size that the Duster MK3 uses. Alcar 9006 7Jx17 ET37 5/114.3 66.1 steel rim (from Nissan Qashqai 2021-) https://www.mytyres.co.uk/rims/details?vehicleId=1330466244213609586&rimCode=ALCAR9006
Space saver to the rescue!
There are two different foam and jack kits depending on whether you have a Karoq 2x4 or a Karoq 4x4, as shown below. Karoq 4x2 front wheel drive 57A093860B (foam and jack kit) (includes everything except for the space saver wheel) (2449CZK is about £85.82) https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57A093860B Karoq 4x4 four wheel drive 57A093860C (foam and jack kit) (includes everything except for the space saver wheel) (3479CZK is about £121.92) https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57A093860C
Replacing Yeti
I hadn't replied because I wasn't sure what the tyre and rim specifications will be for the new Duster MK3. However, it's looking like they will be 215/65R17 and 215/60R18 so this reply assumes this to be the case. If the rim specification is similar to the old Duster, ie. ET50 5/114.3 66.1 then it should be possible to use non-standard 215/70R16 tyres on the old 16" rims...if high sidewalls are your thing. As you can see in the chart below, both the 215/70R16 and 215/60R18 tyre sizes have very similar outside diameters to the 215/65R17 tyre size, ie. so close that the difference is insignificant. Outside diameter of tyres 215/70R16 707.4mm (-0.5% compared to 215/65R17) 215/65R17 711.3mm 215/60R18 715.2mm (+0.5% compared to 215/65R17) Here's some examples of tyres in the 215/70R16 size. The below examples are all under £100 each (not including shipping), except for the Michelin which usually tends to be a bit more. Michelin Primacy 4+ 215/70R16 100H https://www.camskill.co.uk/m62b0s13231p210229/Michelin_Tyres_Car_Michelin_Primacy_4%2B_215_70_R16_100H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_69dB Uniroyal RainExpert 5 215/70R16 100H https://www.camskill.co.uk/m62b0s13231p212997/Uniroyal_Tyres_Car_Uniroyal_RainExpert_5_215_70_R16_100H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_71dB Vredestein Quatrac 6 215/70R16 100H https://www.camskill.co.uk/m139b0s12700p201645/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_215_70_R16_100H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Yokohama Geolandar AT G015 215/70R16 100H https://www.camskill.co.uk/m62b0s13231p148267/Yokohama_Tyres_Car_Yokohama_Geolandar_AT_G015_215_70_R16_100H_RPB_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_70dB
Looking at Mk3 fabia estates probably monte carlo
The Monte Carlo won't have the bigger front brakes if it's only got 95HP. There's nothing special mechanically about the Monte Carlo.
Wheel Identity
You should be able to order the below hub caps from any VAG parts department, quoting the below OEM part numbers. 6U0601151L MHB (149CZK is about £5.22) (earlier design) https://eshop.skoda-auto.cz/cs_CZ/nahradni-stred-kola/p/6U0601151L+MHB 5E0601151 FOD (219CZK is about £7.67) (later design) https://eshop.skoda-auto.cz/cs_CZ/ozdobny-stred-kola-/p/5E0601151++FOD
One thing you might have overlooked when comparing the Fabia MK3 1.0TSI with 95HP and 110HP engines is the size of the front brake discs, ie. the 110HP model has bigger front brake discs as shown in the chart below. So the mechanical differences aren't just limited to the 5 or 6 speed gearbox. Size of front brake discs Fabia MK3 1.0TSI 95HP 256x22mm Fabia MK3 1.0TSI 110HP 288x25mm
Replacing Yeti
wheel-size.com lists the Duster as having either 215/65R16 or 215/60R17 tyres. autodoc are listing the 16" Duster steel rims, as shown in one of the links below. Vredestein Quatrac 6 215/65R16 98H (Euro label C B 71dB) (all-season tyre) https://www.camskill.co.uk/m139b0s8008p202133/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_215_65_R16_98H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB 6.5Jx16 ET50 5/114.3 66.1 steel rim (Dacia Duster) https://www.oponeo.pl/felga-stalowa/alcar-kfz-8873 https://www.autodoc.co.uk/alcar/14750790?search=ALCAR+Rim+(8873)
Alloys
The 19" Kodiaq tyres are size 235/50R19. The outside diameter of this tyre size is far too big for the Superb MK3, as shown in the chart below. Outside diameter of tyre 235/40R19 670.6mm 235/50R19 717.6mm (7.0% bigger outside diameter compared to 235/40R19 Skoda do an alloy rim accessory catalogue. Prices are much lower (perhaps 60% less) than the normal prices. The below alloy rim is listed at 5459CZK (about £190.87). This is just one example, as there's a huge range of alloy rims in the Skoda alloy rim accessory catalogue. 7Jx17 ET40 5/112 57.1 alloy rim RATIKON (from Kodiaq) 565071497A 8Z8 https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-ratikon-17-kodiaq/p/565071497A+8Z8 The alloy rims listed on "skoda eshop cz" are from the accessory catalogue. You can tell by the format of the OEM part number. xxx701xxx is from the accessory catalogue. https://eshop.skoda-auto.cz/alu-kola/c/alloyWheels
Alloys
The 7Jx19 Kodiaq rims have an offset of ET43, so only 1mm different from the 8Jx19 ET44 Superb MK3 rims. 7J is too narrow for the standard Superb MK3 19" tyres, ie. 235/40R19, but you could use 225/45R19 instead. However, 225/45R19 would raise the gearing by 2.2% compared to 235/40R19. Here's an example of an UHP summer tyre in the 225/45R19 size. Goodyear Eagle F1 Asymmetric 6 225/45R19 96W XL (Euro label C A 69dB) https://www.camskill.co.uk/m55b0s5063p210965/Goodyear_Tyres_Car_Goodyear_Eagle_F1_Asymmetric_6_225_45_R19_96W_XL_FP_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_A_Noise%3A_69dB
Alloys
19" Karoq alloys are 8J, not 7J. As you can see in the ETRTO chart below, a 235/40R19 officially needs at least an 8J rim width. ETRTO approved rim widths 235/40R19 8.0-8.5-9.5
Bought a Karoq Today (2)
The 17" Karoq rim has a specification of 7Jx17 ET45 5/112 57.1 The 16" Octavia MK3 rim has a specification of 6.5Jx16 ET46 5/112 57.1 As you can see in the chart below, the outside diameter of the 205/55R16 tyre is 5.4% smaller than the outside diameter of the 215/55R17 tyre. This is quite a big difference. However, 205/55R16 is sometimes used as a spare on the Superb MK3 and that car also has a 215/55R17 tyre size. Notice that the 125/70R18 space saver tyre also has an outside diameter 5.4% smaller than 215/55R17. Notice also, that the 135/80R18 space saver tyre has almost the same outside diameter as the 215/55R17 tyre. Outside diameter of tyre 215/55R17 668.3mm 215/60R16 664.4mm 205/55R16 631.9mm (-5.4% smaller outside diameter than 215/55R17) 125/70R18 632.2mm (-5.4% smaller outside diameter than 215/55R17) 135/80R18 673.2mm (+0.7% bigger outside diameter than 215/55R17) A 135/80R18 space saver tyre could be fitted to the same space saver rim that the more common 125/70R18 space saver tyre uses. 135/80R18 space saver tyres https://www.camskill.co.uk/m129b0s7672p0/Temporary_Spare_Tyres_-_Space_Saver_Tyres_-_18_inch_R18_inch_-_135_80_18_135_80R18_R18_inch_-_135_18_135R18 6Jx16 ET43 5/112 57.1 steel rim (from Karoq) https://www.autodoc.co.uk/alcar/14750540?search=ALCAR+Rim+(6665)
Winter/All Season Tyres Question
The 235/35R19 gives a little more protection from potholes and kerbing damage. Still not great though, compared to 225/45R17 fitted to a 7J rim width. Here's an example of a good all-season tyre that you might consider fitting to an Octavia MK3 VRS. Continental AllSeasonContact 2 225/45R17 94W XL (All-Season tyre) https://www.mytyres.co.uk/rshop/tyre/Continental/AllSeasonContact-2/225-45-R17-94W-XL-EVc/D-127991 Notice that the above 17" tyre is a lot cheaper than the far more expensive and less common 235/35R19 tyre size. Continental AllSeasonContact 2 235/35R19 91Y XL (All-Season tyre) https://www.mytyres.co.uk/rshop/tyre/Continental/AllSeasonContact-2/235-35-R19-91Y-XL-EVc/D-128033
All terrains on a Yeti
Spacers reduce the offset, so fitting 10mm spacers to rims that already have an ET33 offset gives an effective offset of ET23. The ET33 offset is already on the low side for the Yeti because it's a large 12mm difference to the standard ET45 offset. 215/65R16 and 235/60R16 both have just over 5.5" of sidewall height, which is quite a lot. Notice the different 70dB vs 72dB rating of the below two tyres. Yokohama Geolandar AT 215/65R16 98H (Euro label E C 70dB) https://www.camskill.co.uk/m62b0s426p148189/Yokohama_Tyres_Car_Yokohama_Geolandar_AT_G015_215_65_R16_98H_RPB_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_70dB Yokohama Geolandar AT 235/60R16 100H (Euro label E C 72dB) https://www.camskill.co.uk/m62b0s425p148190/Yokohama_Tyres_Car_Yokohama_Geolandar_AT_G015_235_60_R16_100H_RPB_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_72dB
The standard 19" tyre size on the Octavia MK3 is 225/35R19, not 235/35R19...although those that have tried this 10mm wider size do appear to be happy with their choice. As you have the big 340x30mm front brake discs, the smallest rim size you can use is 17". So either 205/50R17 or 225/45R17 tyre size. For the 205/50R17 tyre size, you could use 6.5Jx17 ET38 5/112 57.1 steel rims from the Kodiaq. ET38 isn't a Skoda approved offset for the use with snow chains with this tyre size, but they should be ok if you're not going to use snow chains. ET45 and ET48 are the two approved offset for the use of snow chains with this tyre size. See the owner's manual for full details. Alcar 9021 6.5Jx17 ET38 5/112 57.1 steel rim (from Kodiaq) (11.58kg) https://www.autodoc.co.uk/alcar/14750807?search=ALCAR+Rim+(9021)
