DieselMonte
Everything posted by DieselMonte
  1. Not much to report. A few thousand faultless* miles so far. Had it in the UK in July, 35°c , air con cold as ice and getting unbelievably good fuel economy. Wasn't too long after getting it all back together so was a bit nervous but it drove flawlessly. Few small things I managed to sort. New bushes for the shifter in the cabin, one from the SDi originally. Tightened it up some more. Also found a "6 speed" knob on Amazon so snagged it. Was only 15 or so quid. It's basically the more modern VW gear knob with a boot to suit a mk2 fabia, it looks standard and considering it actually is a 6 speed now, fits perfect. My old 5 speed one was in bits this ages. Got a new set of spotlamps too, my old halogen ones were in bits this while, treated myself to a set of led spotlamps. Fit well and came with their own wiring loom. Now has a switch in the dash as well as coming on via high beam. Some disassembly required. Also replaced the fan resistor with one from a parts car. It hadn't worked on "1" in a year or so. Did a track day start of Sept at mondello. Car felt great, was able to stay out for much longer at a time and the new sway bars and other changes have made a pretty major improvement to how it felt on track. Without compromising too much on driving it every day. Gearbox felt much better suited to task than the 5 speed. Feels like Its finally where I've always wanted it to be. Still many much faster cars on track. One thing I only noticed recently with the colder weather coming in, it was struggling to get up to temp, staying mostly around 65-70°, heat wasn't great and would cause the coolant temp to plummet further. Should have realized at mondello when it wasn't getting past 90°c. So thermostat most likely, have one from darkside ready to go. Seems a bear to do in situ, and probably something I should have done when it was in pieces a few months back. Not doing big miles currently so not relying on it. Had to replace a CV boot a few months back but sounds like a joints about to go. Really wish the shaft I got when I was doing all was good, would save me a lot of hassle.
  2. Mine was mk1 fabia vRS box to a MK2 1.6tdi fab You'd want to find a 6 speed petrol box for whatever petrol Ibiza/polo of the era. Bet an altea box would have different mounting points and wouldn't fit to the chassis without major reworking. Wheel speeds done by abs so no issue there Hubs/driveshafts fit fine It's basically a case of swap EVERYTHING over, flywheel/clutch, driveshafts and bolts for such etc. Really wasn't hugely difficult vs just changing a clutch. Most of my problems was fitting boost pipes over the new, much bigger gearbox. Ive got a braided clutch line from darkside, 5 speed one won't work and the 6 speed pipe was pretty poor. Shifters in the cabin are all the same, mine currently has a mk1 fabia sdi shifter box as it was in better shape than the original one in mine.
  3. A/C regassed and working for the first time in years 5 out of the 6 years I've had it, aircon was bust. Figure I may post a Modlist of it as it is now. Power: 175hp/260ft lbs Engine: 188k mile CAYC 1.6 TDi GTC1549VZ Turbo Universal Front mount intercooler Darkside hardpipe kit Darkside 2.5" downpipe Ulter 2.25" backbox RamAir Foam filter *temporary* Water sprayer for intercooler (inop atm) Gearbox: Mk1 Fabia vRS 6 speed (HDS) Standard vRS DMF/Clutch kit Braided Clutch line Solid shifter bushes PowerFlex purple Lower mount Strengthened OEM engine mounts. Mk1 fabia shifter box Suspension/Chassis: ST shocks and springs Powerflex Top Mounts Superpro Caster Increase bushes Superpro Steering Rack bush PSB rear axle bushes H&R F+R Swaybars Deadset kit Baf K brace Brakes/Tyres: Mk1 fabia vRS Rear Axle (Disc conversion) 312mm Front brakes 256mm vented Rear brakes Mtec Braided brake lines Mtec Drilled/Grooved discs Textar Pads Standard Wheels 2x Sets (Normal set) 215/40/17 Bridgestone potenza S001 AO (Track set) 215/45/17 Nankang AR-1 Other: Red Monte Carlo seats (grey originally) Mk1 vRS handbrake (original broke) Boost gauge Halogen spotlamps in the grille Passenger seat storage box Sunglasses holder Wireless car play "RCD330" (clone) head unit. Wind deflectors Mudflaps
  4. So it's finally done Setback, after setback. Got it tracked, driving lovely now with the new swaybars, caster increase bushes back in it and deadset kit. Was driving it (VERY gently) to bed stuff in, making sure it wasn't gonna leak etc. bone dry. Had to use a cone filter for now until I can sort the standard airbox. Replacement hardpipe from darkside fits much better. Took a day of work to get it mapped, hoped to trailer it up as the place that would do it is in ballymena. Which is about 90 ish miles from me. Didn't happen, so drove it up, carefully. Still with the new box it was sitting happy at low revs 60-70 mph no problem. Got 64mpg on the way up. Probably the hottest day of the year so far, 30°c had torque running but temps etc were perfect, drove great etc. Left it for a few hours and came back to 175hp and 260ftlbs of torque. Which is very solid for original injectors, and a 188k mile engine. Got even better fuel economy from ballymena to lisburn, picked up the pace on from there. For a hot, humid day it behaved extremely well, I know dynos are corrected for temp etc, but it was making that power consistently. Haven't noticed any smoke, was told the same when they were tuning it. It is running very clean, making strong power and getting somehow even better economy, undertrays etc aren't even on. 6 speed box feels well matched to the car, standard mk1 vrs dmf/clutch. Braided clutch line. Clutch feels great and changing gears is much nicer now (mostly due to the less scuffed shifter box originally from the sdi. For a car that's mostly kept looking standard, and a lot of the changes are ultimately standard VW parts from one car or another it really has come out decent. I don't need a low car, or a reeky car etc. Older pic from years back but still All the little bits and pieces but unless you had one side by side you'd struggle to see much different, even in this pic there's nothing really obvious. Got a lot of help and advice from a number of people and places, Amd87ts was a great source of info Max en caisse pointed me in the right direction with boost pipes and a few other odds and ends. Darkside were very helpful getting the right bits I was missing, and with stuff previously on the vrsdi. And autotune in ballymena have done a fantastic job on it. Wouldn't have the stones for it if I didn't have a forum like this to research on either. Few small jobs left. Hopefully all the a/c needs is a regas now, it's pretty dire without in this weather Need to fettle with the backbox it's hitting the axle over speed bumps, just slightly. Want to get my phone charger working again, it's been dodgy of late. Boost gauge (all it needs is 2 slightly longer hex bolts) Redo the fog tints and new spots etc. Small stuff, never ending.
  5. Should say it's had new rear shocks (kyb monotube ones), swapped back to the shorter, softer St rear springs and some shorter bump stops. new rear wheel bearing, front hub and bearing, and went back to the power flex top mounts with new bearings there as the rubber ones had compressed to the point where the front was too low for my use. Looked well, but I need ride height for the roads I'm on.
  6. Nearly there. Hardpipe kit from darkside arrived, fiddly to get it to sit right around the box, but I think I'll have it sorted. Way it wanted to sit left me with the same problem of interfering with the shifter. Got some bushes for the triangular up/down piece of the shifter, cleaned all down had to sand the pin that it pivots on the box as whatever grease was on it had hardened and bonded almost to the pin. Hard to describe but cleaned up well, new bushes for it and the squarish slider piece on the end. Slight improvement again and much improved over the previous setup. I'll order a bush for the gear stick and do it later on, it's decent but could be better, sort of last piece of the puzzle. The selector on the box with the weight will not come off so I'm "stuck" using it, not that I mind too much. New top part of downpipe on too. Spent some time touching up the undercoat I did end of last year. Wasn't bad but we had some ridiculous flooding start of the year and the plastic floor covers were filled with rocks and silt, was all off anyway and cleaned so. Touched up the wax coating, more schutz stuff around the exhaust tunnel (mostly for a bit of sound deadening and it was all out) Shot any holes full of lanolin too to keep on top of everything. Did some repairs to the lip, it'll get painted properly again at some point. Patched up best I could. Apparently fiberglass ones are being made now so could see me just replacing it at some point. Have repaired and repainted it before But it does get hammered on quite a bit Lovely road rash on it. Is running and driving on the lift, changed the oil, new coolant etc. it is very close now. Have videos I might link later. No leaks or anything either thus far. Not many more parts to go back on considering. Very happy with the hardpipe kit, was struggling immensely but think I've got it figured out. Tried fitting bigger spotlamps however they were too big. Have to reuse the old ones for now but not hard to change them. Old ones been on there long enough they'd seized, fortunate I had the crashbar off to get access and heat/soak them enough to get them loose. Will end up changing them at some point but at least for the summer there's no real need. Want to try get some (very gentle) miles on it before it gets mapped if it will let me. Bed in the clutch and make sure it's holding all the fluids it should. Trackings gonna be miles out now so that'll need sorting too.
  7. Lots of work done last few days Pics out of order a bit but: Engine bay cleaned down, new coolant bottle on, darkside braided clutch line on. New caliper sanded, primed and painted Came out very well for once. Whiteline rear anti roll bar off, keeping it for the SDi. H&R bar is non adjustable, but powder coating seems fantastic on it vs the whiteline, have to say the clamps for the bushes were a bit of a nightmare to install. Bits of rust treated and painted up. Standard dual mass 4pc kit gone one, new slave cylinder, bolted up lovely Foreshadowing Swapped out the shifter for the one out of the SDi originally, as it was in better shape than the one in my car, in spite of being 11 years older than the car, and having more miles. no matter what I did to it, I could never get it to feel as tight as I wanted it to. Shifters are different but bolt up the same, otherwise fit and work the same, figure I can get a new bush for the SDi shifter and be golden. Had solid shifter bracket bushes and was able to work my solid cable end bushes on the 6 speed. It works, and it feels fantastic. New bleeder for the clutch also, it's bled up perfect, and feels brilliant so far. Brakes all bled fine etc Starter connector is different, easy to swap them considering I had both cars to hand. Currently stuck waiting for hardpipes, standard boost pipe no longer fits because the 6 speed is that much bigger, no way of working it and I did try. Also found a pinhole in my downpipe Least it's not split fully at the welds. Seeing if I can just get a replacement top piece vs welding it, again. Changed the gear oil on the box too. And pulled the vrsdi asunder for its subframe. Painting the subframe from the monte became a mess, it will not stick, and paint stripper just turned it into a sticky gooey mess, horrible. Plus is it'll be back on its caster increase bushes, and I get my wishbone ducts back. Not far from being done But still a bit left to do. Couple other trick things, least I have time to sort some of them given it's gonna be down for a while longer. Forget if I ever did a modlist, but I'll do one up after this. Power will be whatever the injectors are capable of, but cross that bridge when it comes to it.
  8. Lot of work going on Engine and all out Front off Shed load of parts to go on 6 speed has been taken from the vrsdi Spare 5 speed box from another monte gone in, bolts straight in etc, provided you swap EVERYTHING, works just fine. New shafts and all going in this. Finally the Cr170 turbo ive been sitting on for years being put to use Took some bits down to powerwash, intercooler came up insanely well, bit of polish and itll be golden. Subframe being stripped and repainted, again. Be touching up some bits of rust etc, very slight but its all apart so its being done. Turbo off. Box off. Currently at 188k miles. Clutch has had its day anyhow, never slipped never gave me any trouble, original clutch all along. Springs rattling around in it so was due in anycase. New rad and condensor. Rad was weeping slightly and not had working ac in years, used compressor going on also.
  9. How've you found the deadset kit? Any difference?
  10. Sorry for the bad rec Any chance someone could have put a different flexi on it before? I'll get a pic of how mine sits in a bit. Had friends get axles off them for different cars and all been perfect. Braided line may be longer than a normal one fwiw. Or one off a mk4 golf etc IF youre going that route. Be the same fit just different length
  11. Not used them but have heard nothing but glowing reviews about them, they do loads of makes and all seem top notch
  12. 100% find a new one Once got quoted 300 for one out of a scrap ibiza when i was swapping for discs Got one out of a mk1 vrs for 60 and refurbed it. £140 is a bargain bushes and all
  13. Not much to report. Off the road still driving fine. Got 4 new ad08rs for it. Will need a bit of work for mot which is up in feb, not be using it till april on so aside from the chassis it should be ok. Needs a Y pipe, few bulbs *possibly wiring, rear fog switch etc nothing catastrophic aside from the chassis. Probably shouldnt fail on it, i'll be doing some more undercoating anyhow. Provided it passes mot i'll do belts and all after so im not sinking huge money into it beforehand.
  14. Not much else Stripped rear suspension out of parts car. Siege removing the bushes, found they had a metal sleeve that will not come out of the wishbone bushes, so cant fit them. Then moved onto the trail arm bushes, found they weren't right so cant fit them either. Also this. Thank god i stripped the parts car FIRST. So leaving the rear suspension be for now. Touched up some undercoating and refitted the exhaust, shockingly all the gaskets were totally wrong so i used exhaust paste FOR NOW. Few small things to finish up and alignment, but it is basically done and driving fine. Payed far too much money for an nos clock for it too.
  15. All finished off gloss white with wax coating on top. Car passed clean sheet this time. Normal exhaust painted and back on. New fitting kit for the rarb, painted it yet again. Fixed a few other things, cb etc, refitted brace too. Also got a few things off skoda parts, including an old irc sticker, always wanted one.
  16. Mk1 and mk2 bolt up the same. See if IM axles on ebay do them, i think they do. Reasonable prices and meant to be top tier but ive not used em yet
  17. Trip to the Uk was brilliant, 10/10 experience, honored to have been involved in some small way. Fella is probably the best driver i know, just got caught out at the worst time. Hope I can get invited back again. Nearly 183000 miles on my car now. Going pretty well. Suspect i damaged a boost pipe as its a bit more whistly now. Easy sorted if i can find the bugger.
  18. In next week for NCT so in preparation mode for that. Have to change backbox anyway so stripped all off to tackle some rust. Wired all back best i could. SOAKED in kurust overnight. Started with Anti corrosion zinc primer. Then etch. Then stone chip. Will be sprayed white and then waxoyled once this sets overnight. Slightly better floorpan covers and brand new genuine undertray, again. Rarb has to come off. As does kbrace. Also have a flat sheet of metal I intend to do up a cover for the exhaust. Hide the downpipe better. Will fail on something. Im just giving them as few excuses as possible.
  19. Car wasnt going to be lifted until saturday morning so we left late friday for scotland. Drove straight back up and crashed on a couch until the ferry came. (Not my pic but how it was lifted out) 4 new tyres for the MX5 AD08RS almost identical to what was on it years before i had it. Worked out about 1250 miles before i got home. So a lot of driving in a few days. Rac does 2 legs so starts in carmarthen and finishes in carlisle. Mate went off on the last day of the welsh leg. Either way we would have been driving to carlisle atleast. Would have worked out handy ferry wise, but not the end of the world. To be honest looking at how the northern leg went, probably did us a favour in a strange way. Took it out a few days later to assess what id done. Full deep scrub underneath especially. 2 trips on the irish sea and salted welsh roads had me worried. Have a video but too long so bullet points. Rubbed the underneath raw, broke undertray. Floorpan covers damaged slightly, backbox/fuel tank all rubbed slightly Undertray missing. Some of the mountings damaged. Exhaust mounts tweaked on downpipe. Damaged the lip mostly areas id fixed earlier giving way. Was gonna repaint it eventually so no big deal. Floorpan covers i had spare from a parts car, my old ones will be fitted to the sdi eventually. Sorted some rust underneath. Not too bad. Sprayed all white over it and used wax coating on top. Sprayed the floorpan brace also. Doesnt need to be much as it is covered.
  20. Atleast in fresh snow it acted like a snow plow of sorts. But was embarassing to have to be pushed for so long until we hit road. Thursday night the stuff in the middle was turning to ice and needed to be pushed a bit again. Friday morning wasnt *as bad. Needed a push to start getting out. But aside from the ice it did get onto the road mostly ok. Said ice in the middle became very hard and did damage. Not terrible but not a pleasant run over the road. Wont let me upload the video but it sounded pretty horrible driving over (on) it. Leaving to follow the service van, copped the undertray was low. Very low. Was held on at that point by 2 screws only so ripped it off. About an hour or so of driving got a call that mates car had an off on SS8. (Not my pic but its where the car ended up) They're fine. Car is done for. So diverted to near it and met with the management cars and waited, chatted with some very nice locals too. Watched some very cool stuff go by until they could get lifted down to end of stage and picked up.
  21. Thursday morning was difficult because there was that much snow the car basically high sided in the middle lifting the wheels off the ground. Pilot sports did not help. Not the car for the job. Its not very low but it is lowered a bit.
  22. Long one. Gave the car another service after doing kirkistown and ahead of a long trip. Changed rear springs for my Heavy duty ones. Gave the car a quick polish and away to the uk. A friend was doing the RAC and I tagged along. Went belfast to cairnryan. Picked up a friend who lived nearish the ferry, loaded up and down in one shot to carmarthen for the start. Very cool seeing the serious amount of machinery on display. Showgrounds were huge. Stayed at a place nearish. Got snowed in. Every one else made it out but I did not. So tactical dump into a field entrance and walked back to the accomodation. Eventually got it unstuck some hours later. Snow was mostly around where we were, main roads were fine. But getting to and from them consisted of being pushed for about 2km. (Pic from the next morning)
  23. So long time and a lot of progress here or there. Went up on the lift to do new ball joints, tie rods and a wheel bearing. Wheel bearing was a siege in 100 different ways. As were the ball joints (Kept getting sent wrong ones) Basically decided "I am not taking this apart again", so knowing the flywheel was grinding worse and worse i began stripping the parts car down. Don't love having it in bits as its yet another shell to go on a pallet. Before that i rolled it down to the wash, and gave it a good cleaning. Even though it is beyond rotten I felt a bit bad tearing into it, anyhow. Stripped suspension off of it and dropped engine as a unit, split all on the pallet and got the flywheel. It was grubby and oily but in better (not great) shape Both cars the clutches were "ok" both have oil leaking from the distributor down into the box, and what was causing the clutch in mine to occasionally slip. Decided to strip the parts cars suspension to clean up for mine, bushes being 30 years old and 90k mile on them, were well past it. Knew i needed anti roll bar bushes for mine, like everything else cant get new rubber ones. However, there is a man in a shed in the US called DRW bushings who does bushes for all the older subarus. So i ended up buying the full kit for mine. Not cheap but shipping and customs from the us isnt either, so i only wanted to do it once. Bushes came quickly for being made to order, and the other side of the pond. Fella was extremely pleasant and helpful to deal with. Bushes all fit perfectly, all numbered so almost impossible to mix up, plus theyre not as hard as powerflex or such. They feel a lot like a slightly firmer oe bush. Got mine in black to keep a nice standard look. Noticed sump was leaking this while so dropped it, cleaned strainer also. Again while im in there. Primed and painted sump, resealed all fine. New clutch kit, probably mentioned before i won a new old stock subaru disc and pressure plate a while back, nice to put it to use. Cleaned the flywheel up myself as couldnt get anyone easily to machine it. Got gearbox in on my own not easy but lifted it up and put it on myself. Made a clutch alignment tool with an extension and lots of tape. In the bushes kit there were small shifter bushes which have transformed the shifter, it was really nice before but now it is extremely nice to use, very tight and direct. Back on its wheels this evening, no exhaust past the cat and needs checking and torqueing all the bolts on the ground but i did get driving it a little. Clutch feels very good but does need adjusting. Suspension and steering feels superb, very fresh. Still have to do rear suspension. Gonna do the same and strip the parts cars to refresh. This way i have serviceable arms etc from mine as spares. So shouldnt have much to worry about from the front for a while. Rear isnt too bad but id like to have all the suspension stripped and painted anyhow. Ill clean up and schutz underneath it too. I do want to gut the cat from the parts car to use on mine, being pre 95 it doesnt need one to pass emissions once its running well. Have that nice backbox too but itd require basically having a catback pipe done up to make any use out of it. Exhaust restricts way down after the resonator for no real reason. Backbox i got is the same size as the pipe between the cat and resonator. Facelift ones like mine are catted, preface is not and that brings power down from about 55 to 50. It is nippy for what it is but a "cheap" 10% bump in power would be nice.
  24. 2 more trackdays down. Did mondello on the bank holiday monday gone by and kirkistown today. Few repairs done before mondello. Fixed one of the rivnuts for the brace, got a tool from lidl for nothing and it worked brilliantly. Back stripped out, seats etc. Checking over bolts and immediately snapped one for the rarb. Managed to repair it with an old bush from the justy cut down and bolt and nut through it. Mondello went well, sort of damp, car did a lot bettet than last time. Spun it but no damage suffered. Was silly but a lot of people did the exact same on the same corner so not too mad. Amount of red flags at mondello is astounding, thankfully i wasnt one (yellow flagged for spinning) Didnt do too much except change the oil and check it over for kirkistown. Its about 100 miles each way from me and of course i was driving there and back. Car did well, was some ridiculously fast stuff there today including a manthey porsche, big body amg saloon, ferrari 599 and an m3 convertible and it was VERY busy. Weather held out amazingly. Brakes held much better than last year as did tyres. Heat management definitely a problem and I dont love not having oil temp atleast. Ran the car on HVO both these trackdays, cars took to it great but i wouldnt leave it sitting with that in it. Believe much like e10 and petrols it will rot lines if theyre not rated. Use torque to monitor coolant temps, intake temps, pressure etc. Eased off once coolant got to 100°. No clue whats a "safe limit" but figured thats safe enough. Rubbing pretty bad still. Thought it clearanced itself but guess not. Last few photos arent mine theyre from another forum, but they look cool so ill post them here too. Over 181k miles now so see how much more it will take.
  25. No reason it won't pass nct But they will fail it on something thats fine and miss everything inbetween.
