DieselMonte
Everything posted by DieselMonte
  1. Bumper clips are different too Prefacelift only does prefacelift bumpers Facelift and vRS are the same clips.
  2. Worth keeping in mind AnnoyingPentiums car is 15-16 years old and only has 50-60k miles on it. It wouldnt be too hard of a stretch to guess its got the original oil in it. Plenty of time for that oil to degrade, or maybe get low what have you. If you're going to the hassle of topping it off its not much more to just empty the thing and refill from scratch.
  3. Once its mapped out, technically I dont think you have to remove all of it. Egr cooler is on the back of the engine and meant to be a massive pita to remove itself. I mentioned before about restrictor plates, if you got the egr mapped out you could just put a blank plate in that spot and leave the stuff on the back of the engine where it is. I do think darkside stock a delete pipe for the stuff on the back of the engine, but just blanking it here should suffice.
  4. Reverse usually isnt synchronised anyways so if it crunches sometimes going into reverse, but still goes in I wouldnt be too concerned either.
  5. 1.6 tdi is either a CAYA/CAYB/CAYC code for a 75/90/105 model respectively. Egr needs coding out if you're removing it completely, or a simulator as Pip has said. If the egrs still working you can put a restrictor plate on the pipe leading to the intake manifold, it'll keep a lot of the egr gunk out of the intake system and it wont throw the car into limp mode.
  6. Mine does the same still I wouldnt worry too much about it. I've since changed the gear oil on mine and I reckon it was low, I got more in it than came out of it anyway. If you're changing the gear oil don't expect to get absolutely every drop out though there will always be some of the old oil in it somewhere. Linkages made the biggest difference on my car, gear oil made some difference on its own too. Pretty sure VW gearboxes are a "lifetime fill" so they dont have a specified interval. Won't do any harm changing it though and its peace of mind. Just my 2cents.
  7. Out today and I got the one side nearly done. Absolutely horrible job by far and away one of if not the worst job I've ever done on this car. Left this side here for today, not even going to touch the other side just get this side put back together. When the mk2 needs shoes putting on I'll get a disc axle for it. Honestly it cant be any harder to just swap the whole axle than it is to do these brakes. Painted the drums with some leftover paint to freshen them up too. I really hope atleast the handbrake will work again when these are done.
  8. Wasnt doing anything this morning so went and did a bit of "Maintenence" on this. Really I just wanted to take another look at the egr piping and what not and give it another clean. Fairly scummy but seems like the restrictor plates doing its job. Took a look at the asv and said I may as well take it off for a clean too.Thats the top of it where it meets the intake manifold. Heres the bottom side thats joined to an intercooler hose. I thought it would be worse but the only real dirt was that buildup you can see in the photo. Took a bit of scrubbing to get it clean. I used this pink stuff paste with a scouring sponge and it came off fairly easily. Cleaned up the egr bits again before putting them back on. Dont need to be perfect just cleaner than what they were. A lot of the dirt I was finding was mostly oil i'm guessing from the breather, wasnt too hard to clean. Got a shot up the intake manifold and it doesnt look too bad, I was expecting worse. Happy I've cleaned up the asv even though it shouldn't make any difference to its running. Think I've mentioned before about fitting a catch can and I think its time I actually pull my finger out and do it, it won't harm anything.
  9. I blew out the driveshaft and drivers wheel bearing on my sdi not long after I got it, and put used ones on. Its lasted for a long time but I think it'll need replaced before It goes back on the road proper. If a used parts in good enough shape then theres no reason not to buy it. Atleast it keeps the car on the road for a bit more and allows you to save up for if it goes again.
  10. My comfort had the one on the passengers side and nothing not even a blank under the drivers, weird.
  11. You absolutely can swap them I took the underseat storage from my mk1s seat and put it into my mk2 a while back.
  12. Not my proudest moment but felt I should share. Lately I've noticed a bit of a clunk from the front which I took to be either something with the arb, or a driveshaft going bad. Someone suggested I check the engine mounts and I did. Lo and behold the drivers side mount (which I've only replaced a few months ago) had a lot of play in it, more than the mount in the mk1 even. I didnt want to be driving with it over christmas and I figured I wouldnt be able to get a mount for it again because of christmas. So I took it upon myself to bodge the original mount and put it in. I put the original mount in a vice and squeezed it in to make room on the top of the bushing. Then I got the tigerseal out and proceeded to shove as much of it as I could into the gap I made. Left it to set for almost a week like this. And put it in. Not the prettiest job but it has solved the clunking.Made a noticeable difference when you put your foot down too, it feels like the engines not moving about as much compared to the other mount if that makes any sense. I'll try warrantying the other mount and see what they say. I don't expect this to hold up for long but it just needs to last long enough for me to get another mount in. For the sake of a few euros worth of tiger seal I can't really complain . I wonder if VW made a stiffer version of this mount, I believe the diesel mounts stiffer than the petrol ones but I wonder if there exists one stiffer than that.
  13. Straight swap as Annoying Pentium has said. Do you have any pics of the seats out of curiosity?
  14. Or breakers either, and cars being broken for spares.
  15. Not too sure about the slam panel, most of the places you could mount to are plastic and I don't know if it would be as good of a job. Crash bar was the only place secure enough to put them I found. Its not as big of a job, honestly I used some big nuts put together to raise the spots up enough. Not the most elagant way but it worked and they havent moved at all.
  16. Stealthy If you mounting it where I've mounted mine beware I found the crash bar very hard to drill through, and I had to make a big spacer to get them to sit high enough to be visible.
  17. I've a pair of led spots on mine. On my car the wire I tapped into to switch the relay with the high beams was a white wire on the headlight loom, from the passengers side headlight. Don't look like much but they put out a decent amount of light even behind the grille. Dirt cheap too, I got my two for around a tenner but the same seller sells 10 of them for ~£26.
  18. I've wired spots to come on with the high beam, didnt need to run wires into the cabin then. But a good bet would be to run your wires through the same grommet the bonnet cable goes through, should be able to see it running down the passengers side of the car. IIRC it goes under the scuttle panel for the wipers and then in past the firewall so you might want/ need to take off the scuttle to make it easier to run them through.
  19. Never seen a car take so much abuse and keep going. Hit hard enough to break the starter in two, put a new starter on it and it fires up after being sat for over a year like it was nothing. The matrix that replaced the mk1 couldn't hold a candle to it there.
  20. At a good speed too, that fields very hilly and because it doesnt have much power I got to gunning it going downhill and putting it into a slide to carry as much speed as I could when I looped around to go back up it. It was a while ago but I think I was going about 50mph when I hit the drinker. More or less I was in a slide, hit the drinker head on, sent it flying and spun out. Not really, that field hadnt been used in a long time and the drinker was covered over by grass and weeds. I had a loop made for myself and I guess I kept slowly working my way inwards over time. You can sorta see the dirt track I'd carved out, was particularly thick with weeds near the middle of the field conveniently hiding this wacking big drinker under it.
  21. Big concrete cattle drinker
  22. Weird, I always thought the reason you had to change the axle for discs was because the drum axle didnt have the mounts for a caliper carrier. So thats why everyone who swapped for discs just swapped the whole axle out. If those mounts are useable to mount carriers to I'd probably get brakes, lines etc to go onto it and put it into my mk2.
  23. No the one with the rarb is my mk2. The mk1 axle is the first one. Its not as easy to see with all the mud but theres two "ears" coming from the axle that arent on the axle under the mk2.
  24. And unless you set them really low they'll ride just fine.
  25. Its got a vRS block, a 1.9 litre plant, its got vRS wheels, vRS supensions, "vRS" seats. Its a model made before DPFs so it'll run good on veg oil...
