Everything posted by Jonnyhatesjazz70
Obdeleven and XDS
@DrCorbyLee Thank you for the reply. I will activate it later, most of my driving is high speed twisty's so I will hopefully get a bit more traction. Will let you know. I have Hill Assist on also it makes a huge difference, even getting out of my long steep driveway onto the B road, no rolling back is nifty. Seat belt bongs off, whilst on private land.
Hullo all.
Welcome.
Obdeleven and XDS
Good evening. I have activated a couple of changes on my car, it's an Elegance so has a lot of coding already installed from factory but it does not have XDS activated yet. Might give it a shot. Can anybody recommend it, used it on their car?
My girl.
Very nice indeed. If you have a CCZA, just check the chain tensioner and PCV at that mileage. I love mine too mate, need to do a lot of overtaking here, it's a breeze with a 2.0 tsi! The Elegance has great little tricks, the left mirror dip is handy, and the memory seats are a blessing. Never used the self parking though. Enjoy.
Alloy wheel run-out?
Any vibration through the steering wheel at higher speeds? If so, could simply be the wheels need balancing, you may have lost a weight on one side due to a pot hole. Worth a look.
14plate: ventilation fan stopped working: Ideas please
Evening. It is a very common issue. Did the same with mine a while ago. Easy to get out and easy fix. Nice to do it yourself mate.
Changing fuel filter
Just to add a little note to my post, the jack point for the rear, is directly next to the axle stand point, which with my trolley jack is never going to happen. And guess what, the filter is inches from both points. Looks like a ramp job only sadly. Could have saved the labour costs, oh well.
Good evening. My 2.0 Tsi fuel filter is due to be changed and looks pretty straight forward, tucked neatly under the chassis, three clipped hoses to disconnect. My question is, do I need to remove the fuel pump relay prior to changing it? Or just not open the drivers door? Online has mixed messages. My local indy has done it previously during a service.
Columbus head unit issues.
Pab546 is the right man for the info. Helped many people with this very common issue.
Spark Plug Torque
Thanks for your advice mate. I put mine in at 25nm. They seemed tight enough, went with the varied online comments and went for it. Engine is as smooth as ever. New coils also.
Spark Plug Torque
Good morning. Can anyone tell me the correct torque setting for my 2.0 tsi please? I have new NGK 1675 ( PFR7S8EG) to install today, as its not raining. Conflicting info online. Thank you.
Hardwire Dashcam
Morning. I sorted it thank you. I piggy backed a start up fuse and it works very well. As its silly season up here, a dash cam is vital. Thanks for asking.
Accelerator pedal release tool
Morning. I purchased it in online from ToolsUsa. Cheaper than VW by a long way!
Good evening. I have the VW RHD accelerator pedal release tool going spare if anybody needs one. Just message and I will post it to you. It works very well and instant, saves using two small screwdrivers. Happy Easter.
Columbus In German!
I have not heard of that, there is no chance there is one already in the slot? I hope you get someone on here who knows the solution.
How to find my DSG gearbox code
I had to get mine serviced at the dealer as my local indys don't deal with them. They are very tricky to work with. Mine has always been silky smooth thankfully. Good luck mate.
If you have a 6 speed wet clutch is likely to be a DQ250. Mine recently had a service. I hope your code sheet is where mine is.
Hi there. It should be on the code sheet on the first page of your service book. Or in your spare wheel well in your boot. If I remember rightly.
Columbus In German!
Hi there. I simply put mine in and followed the prompts on the screen. You may need to put a charge on your battery as it takes a while, around 45 minutes if I remember rightly. My Ebay one did not work, a very kind chap on here sent me a link and I had it burnt onto a disc.
DSG oil change price
That's ridiculous. 4 years old! I am sure that are decent dealers out there, law of averages, sadly I will be driving a long way past my mine next time to a city.
Sadly there are only a couple of decent independents where I live and I do a lot myself. For the DSG I had to use the dealer. Long way to another 40k thankfully, the whole experience was so tedious.
Quick note, the same dealer quoted £195 under 2 years ago.
Mine was £295 last month. Oil and filter DQ250 gear box. Oh, and they half washed the car and left my air hose hanging off.
Rear door won't open from inside nor outside
Agree with @andrehj. Does the window open? It's either a broken wire or crimped. Not the regulator.
