Everything posted by Hardy1812
Engine coolant replacement inquiry?
🤣🤣,, I came with a part service history but they was ages ago and the last time it had it changed was with the cam belt in 2015. Guess if you say old coolant could be rusty colour guessing that’s why then 🤣🤣
I’ve done some googling and it says G12 red coolant,, the coolant at the min almost looks like rusty water 🤣🤣
Good morning peeps,, since owning the car a couple of weeks now, I’m going to change the coolant as it look more like an orange than a red colour (guess it’s not been done for a while 🤣). my question is???? is there a plug/valve anywhere to drain the water or is it just pull off the bottom rad hose ??? Fill with water a couple of time to flush it a bit,,, (ain’t got a hose long enough to flush it) then top up with the G12 coolant?? thanks peeps oh is there any do’s or don’t’s 🤣 It’s a 2010 vRS diesel log book says CEG for engine code if that helps
How to get radio code ??
Had a look and can’t see nothing under drivers seat 😢,,
Ahhh cheers mate,, I’ll go and have a look for any kinda box thing under the drivers seat and get back too you
Morning peeps,; I’ve just had a thought 🤣,,, my car has the bolero radio and I was scrolling through the settings and noticed it says activate Bluetooth audio ?? But my iPhone can’t find the radio ?? Is there a module needed as I can’t even add my phone for phone calls?? This is when I thought does this radio require a code should battery fail ?? would I need to go to Skoda for this ??
Spline socket size anyone ???
I will do mate. my motor has started to lock up so I’ve purchased a new one £65 with the adapter, delivery hopefully Monday so weekend I’m hoping to do it. I will be completely removing the manifold hopefully to replace and see if it needs a good clean. Have a new gasket and a long reach T30 plus the spline socket so I’ll either fix it or break it 🤣🤣
Thanks so much gents,, I’ll do the measuring tomorrow and hope it’s in the kit I’ve just bought 🤣🤣,,
Thanks mate,, Did look at them sets but was unsure if any would fit. Looks a big ish spline so I’ve taken pot luck but gone for a big set M10-M18 so hope one of those fits
Don’t really know anything about it 🤣,, just had the P2015 didn’t know what that was until now paid £2300 for it with 124k 2010 VRS really nice and tidy just needs a bloody good clean inside 🤣🤣
Not sure on engine code but it’s a 2010 Octavia VRS only had it about 2 weeks 🤣
Morning peeps, would anyone know what size the spline socket is that holds the fuel rail down on top of engine ?? changing the inlet manifold motor thing as mine keeps locking up so need to replace it and add that P2015 stop thing too thanks peeps
Calliper painting time 😬
I’ve always just used hammerite,, just 2 coats with an artist’s brush but as yours are Brembo I’d powder coat em,, my last 4 cars have always been done in hammerite smooth finish,, focus 1.8 mk2.5 blue —- calliper red Mondeo st mk3 performance blue—-calliper red focus st170 mk1.5 imperial blue—calliper red focus 1.8 mk1.5 panther black— calliper yellow never had any problems with the paint coming off and unless you take it on a track the brakes don’t get super hot and scorch that was the ST170🤣🤣 Oh wheel colour is Audi Daytona Grey on ST150 alloys
DTC code help???
I’ve bought the DIY fix,, that aluminium bit that bolts on to stop the lever moving to far forward. cheers mate. Hope this works it’ll save me a couple pounds. I guess if it don’t it’ll be a complete unit
DTC code help???
Cheers mate just had a butchers and it looks like I need the plastic manifold type just ordered one but it also looks like I have to remove the manifold as the screws are round the back unlike the metal manifold,,, Grrrrrrr 🤣. Let’s hope this works. do you know what it actually does or doesn’t do to cause the EML?? 🤣,, does it have to do with idling or revs ??? sorry noob here but I’m learning thanks to you
DTC code help???
anyone have an idea what this is or where it’s located 🤣,, hopefully nothing disastrous 2.0 VRS 2010 thanks peeps
Another key fob question
Cheers mate I’ll have a look and clean
Tried 5 different make of batteries and it still doesn’t flash if you press a button 🤣,,, so kinda thinking it’s toast I read somewhere about pressing button and unlocking car door with key is how to sync it back again,, but I’m not sure if that’s correct mate
Can any used key fob be synced to my car,, if I changed the board internals as this board I think is fubar,, or would I need to go to Skoda for a new fob or a cheap eBay one with a board chip etc thanks peeps
Timing belt what sort price ??
Thanks mate really appreciate that and yeah like you say at least I’ve got a starting point
Afternoon peeps, what sort of price would I be looking for a timing belt change ?? 2010 VRS would there be anything else to replace like the water pump ??? cheers gents
Key fob not working VRS
No joy I’m afraid but I will still buy another just to rule out a dodgy/flat battery’ thanks for taking the time to help mate really appreciate it
Put in a Panasonic CR2032 and the light still doesn’t flash mate,,, guessing that means the circuit board bit must be bad,,, is it possible to buy the board part and replace it with this faulty one or even a secondhand key and put my blade and chip in that
Ahhh so the lad I bought it from has put the wrong battery in as it had CR2016 not a CR2032. I’ll buy another battery and see if that helps Any particular brand ?? Or will any do mate.
