Crucian
Everything posted by Crucian
  1. Are you sure its not the door wiring harness at fault ?
  2. @varooom Haynes manual (electronic) not the best
  3. Regarding VCDS coding to clear (You can cure your 19 - Gateway fault by coding out/in 56) Just starting out with VCDS any assistance welcomed, I have updated the Infotainment with a Seat Amundsen + unit. Separate topic ??
  4. Thanks, how do I access it to test ?
  5. I have access to a basic wring manual, I'm a qualified leccy with electronics and vehicle wiring experience. I don't know how to access the control module for testing purposes
  6. Sunday,11,December,2022,12:03:20:50405 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: TMBFP65J1F3038497 License Plate: Mileage: 141100km-87675mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 5J-SK25 (6N0) Scan: 01 02 03 08 09 15 17 19 25 2E 37 44 56 VIN: TMBFP65J1F3038497 Mileage: 141100km-87675miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: Not registered 0001 ------------------------------------------------------------------------------- Address 01: Engine (J623-CTHE) Labels:. 03C-907-309-V1.clb Part No SW: 03C 906 026 J HW: 03C 906 026 J Component: 1.4l R4 TSI H02 6413 Revision: LNH02--- Serial number: CVN: C2C35212 Coding: 00250012000400000000 Shop #: WSC 65535 000 00000 ASAM Dataset: EV_ECM14TSI01103C906026J 001006 ROD: EV_ECM14TSI011_SK25.rod VCID: 270B05781F615A638A8-8072 VINID: 91D49680615A0560C00C81091C29118C32 No fault code found. Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 0AM-927-769.clb Part No SW: 0AM 300 062 H HW: 0AM 927 769 D Component: GSG DSG AG7 431 6562 Revision: 00043014 Serial number: CU501407176139 Coding: 0000020 Shop #: WSC 01147 002 1048576 VCID: 313FEB202D2514D354C-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb Part No SW: 6R0 907 379 BJ HW: 6R0 907 379 AS Component: ESP9.0i front H03 0001 Serial number: -------------- Coding: 43DC487D432602C8C2181272C258408D0909 Shop #: WSC 13765 031 00016 ASAM Dataset: EV_Brake1ESP90iBOSCH 003020 ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod VCID: 074B65F8FFA17A63AA8-8052 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb Part No SW: 5J0 820 045 E HW: 5J0 820 045 E Component: Man AC H02 0202 Revision: 0005SH02 VCID: 270B05781FE15A638A8-8072 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb Part No SW: 6R7 937 087 R HW: 6R7 937 087 R Component: PQ25 BCM H30 0570 Revision: -1------ Serial number: -------------- Coding: 25980B3808C93400922808002C2B08C00040420F60000000020010000000 Shop #: WSC 45341 001 1048576 VCID: 53F381A87BF906C3060-8006 Subsystem 1 - Part No SW: 6R0 959 802 AN HW: 6R0 959 802 AN Labels: 6R0-959-802.CLB Component: J386__TSG_FT 006 5210 Serial number: 13202556140716005458 Coding: 030000 Subsystem 2 - Part No SW: 6R0 959 801 AL HW: 6R0 959 801 AL Labels: 6R0-959-801.CLB Component: J387__TSG_BT 006 5210 Serial number: 13102561140710232750 Coding: 020000 Subsystem 3 - Part No: 5J0 951 172 Component: DWA-Sensor H03 H03 1211 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 H05 1501 Subsystem 5 - Part No: 5J0 951 172 Component: DWA-Sensor H03 H03 1211 Subsystem 6 - Part No SW: 5E0 919 719 D HW: 5E0 919 719 D Component: E221__MFL-PR6 H03 0130 Serial number: 000000000A0526250614 Coding: 010000 1 Fault Found: 03580 - Terminal 30 for Outside Mirror Heating 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 3 Reset counter: 116 Mileage: 138893 km Time Indication: 0 Date: 2017.02.09 Time: 11:05:11 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 L HW: 6R0 959 655 L Component: VW10AirbagT2C H10 0020 Revision: -------- Serial number: 003GY00C2B91 Coding: 003243 Shop #: WSC 13765 790 00021 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW25.rod VCID: 4BC399C8A3495E034E0-801E Crash sensor for side airbag: driver side: Serial number: 3495RRB404P2SIIADP9R Front Passenger's Side Airbag Crash Sensor: Serial number: 3505RRB401G52LK2G0RK Rear Side Airbag Crash Sensor (on driver's side): Serial number: 3515RRB405J2SLKAKH9J Passenger side rear thorax airbag crash sensor: Serial number: 3525RRB405J2SLKA6PPU No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 5J0 920 941 J HW: 5J0 920 941 J Component: KOMBI H04 0709 Serial number: 00000000000000 Coding: 410A01 Shop #: WSC 13765 031 00021 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod VCID: 323DE42C24A32FCB2D6-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 6R7 937 087 R Component: GW-K-CAN TP20 H30 0570 Revision: -1------ Coding: 032300 Shop #: WSC 13765 790 00021 VCID: 70B92E24EAAF5DDB1B2-8024 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 132 Mileage: 138893 km Time Indication: 0 Date: 2017.02.09 Time: 11:05:11 ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0709 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6A8D3C4CCCF3A70B556-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7666464924 Coding: 010100 Shop #: WSC 13765 790 00021 VCID: 2B03F94803097E036E0-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 5P0 035 191 J HW: 5P0 035 191 J Component: RNS315-EU H55 0321 Serial number: SEZAZ2M5601011 Coding: 040004010402000000000002 Shop #: WSC 06402 785 00200 ASAM Dataset: EV_RNS315EUV2UDS 001705 ROD: EV_RNS315EUV2UDS.rod VCID: 323DE42C24A32FCB2D6-8066 Data carrier: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_V12 0078 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 C Component: LenkhilfeTRW V278 Coding: 11241 Shop #: WSC 13765 VCID: 3039EE24236F1DDB5B2-8064 No fault code found. End----------(Elapsed Time: 01:01, VBatt start/end: 14.2V/14.3V)----------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 09: Cent. Elect. Control Module Part Number: 6R7 937 087 R Component and/or Version: PQ25 BCM H30 0570 Software Coding: 25980B3808C93400922808002C2B08C00040420F60000000020010000000 Work Shop Code: WSC 45341 VCID: 53F381A87BF906C3060-8006 Advanced Identification Serial number: -------------- Identification: KO1-MAL Revision: -1------ Date: 08.07.14 Manufacturer number: 0001 Test stand number: 0539 Flash Status Programming Attempts(application): 0 Successful Attempts(application): 0 Programming Status: 00000000 Flash Date: 2014.07.08 Flash Tool Code: 00000 000 00000 Software Diag: 01.02.04 CAN: 02.14.01 TP 2.0: 03.05.01 KWP2000: 03.00.00 OSEK Net: 03.70.03 HiSpd Net: 01.12.01 Misc. Hardware number: 6R7 937 087 R Workshop System Name: J519 End of Line Equipment Level: -------------------- Car Info Chassis Number: TMBFP65J1F3038497 VCDS Info: VCID: 53F381A87BF906C3060-8006 Labels: 6R0-937-08x-09.clb -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 09: Cent. Elect. Control Module Part Number: 6R7 937 087 R Component and/or Version: PQ25 BCM H30 0570 Software Coding: 25980B3808C93400922808002C2B08C00040420F60000000020010000000 Work Shop Code: WSC 45341 VCID: 53F381A87BF906C3060-8006 Advanced Identification Serial number: -------------- Identification: KO1-MAL Revision: -1------ Date: 08.07.14 Manufacturer number: 0001 Test stand number: 0539 Flash Status Programming Attempts(application): 0 Successful Attempts(application): 0 Programming Status: 00000000 Flash Date: 2014.07.08 Flash Tool Code: 00000 000 00000 Software Diag: 01.02.04 CAN: 02.14.01 TP 2.0: 03.05.01 KWP2000: 03.00.00 OSEK Net: 03.70.03 HiSpd Net: 01.12.01 Misc. Hardware number: 6R7 937 087 R Workshop System Name: J519 End of Line Equipment Level: -------------------- Car Info Chassis Number: TMBFP65J1F3038497 VCDS Info: VCID: 53F381A87BF906C3060-8006 Labels: 6R0-937-08x-09.clb Log-TMBFP65J1F3038497-141100km-87675mi.txt
  7. Yes loom was exact match. fault existed before loom swap (that was fitted to try and cure the led issue) I'll try to post VCDS log
  8. heated mirrors would be useful with this weather ?
  9. @varooom thanks Its an odd fault, when the fuse for the heated door mirrors is installed the LED light in the d/s door is constantly on regardless of the alarm / central locking status, I have fitted a new genuine door harness to d/s, Fault is still evident when I un plug the door P/S harness ??
  10. @varooom @UrbanPanzer Thank you, updated part number ? do we have that number ? I don't seem to be able to find 6R7 937 087 R on Skodaparts.com
  11. Thanks for the response VCDS data scan on central electronics (I assume this is the control unit I'm after) does this show the date to be 08/07/2014 and the control module part no. 6R7 937 087 R
  12. 2014 1.4 vrs anyone have the appropriate part number for the comfort control unit (under dash D/S) that control doors / windows etc Any assistance welcomed
  13. As JR replied, important that it is correctly protected at the consumer unit for example and wiring ran correct and secured appropriately, If I was installing that type of socket from scratch Single wire armoured cable would be used, you could always protect the PVC wire with conduit when retro fitting the charging point
  14. Thats just a 240v type industrial socket protected by 40A RCD, used for larger welders and 240v equipment
  15. My recent misfire (diagnosed with vcds by) was due to a faulty connector on coil no. 4 (locking clip broken), I replaced the plug and coil (as a precaution) all fine now. hope this helps
  16. 2014 1.4 tsi CTHE. Having difficulty finding which of my 4 cyls is which how are the cylinders numbered 1,2,3,4 from D/S ?
  17. We had an odd sound from the boot / tailgate area of the sons focus, after lots of trim off etc I traced it to the number plate rattling against the tailgate (crappy adhesive pads), renewed with quality items sorted
  18. @Warrior193 Reflectors appear fine, I have projector lenses in the headlights I was thinking this may help with the LED bulb output
  19. Thanks for the responses, how was the fluid drained?
  20. As my vehicle is approaching 8 years old does the power steering fluid require renewing? can't find any reference to it in the service manuals, and how would this be accomplished (is it DIY)
  21. @chimaeraThought as much
  22. I Find my headlights to be a little amber (have nightbreakers installed) any canbus white led recommendations??
  23. Fitted mine in 30-minute easy diy job, buy genuine Skoda ones, I would say definitely worthwhile
