BCM module
Hi guys
need some help if possible.
I have a Skoda Octavia mk3 2019 hatchback. A few days ago I’ve had to replace the rear wiper motor as it had a minor leak and my dashboard was lighting up constantly and beeping saying my boot was open. I noticed few drops of windscreen fluid on the boot opening switch. Since changing the wiper motor cleaning the boot switch I’ve now lost the interior lights and also on my dashboard and stereo the lights are dim. From what I’ve read on this forum that a new bcm will need to be installed and programmed by Skoda.
My question is can I buy a second hand bcm and get someone to program this in by copying data via vcds from the old bcm to the replacement bcm?
also would this sort out my interior lights issue?
also wanted to know if anyone knows what the bcm model number would be as I gathered there’s 4 different version. My car comes standard with LED HEADLIGHTS and I’ve got heated seats.
I’ve got vcds and I am getting Component Protection error
Edited by Aakayamy
Fixing errors
A VCDS scan will show you the BCM part number.
Here's what it shows on my 2016 L&K:
Quote
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
Component Protection removal requires access to the Skoda servers, so can only be done by a dealer or an independent with online access to them.
I’ll check my vcds now.
I spoke to an electrician specialist at a car garage who said he can do this if I can get him a bcm module even if a 2nd hand one. He said he charges £240 in total to change old bcm to replacement and can program this. Skoda wanted £994 including vat
Mines is showing
SW: 5Q0 937 084 DC     HW: 5Q0 937 084 CF
So I would order the one ending with DC?
If you're only getting a Component Protection error, then the BCM might be fine but something has caused CP to get upset.
Post a full autoscan up from VCDS :)
I'm wondering if the BCM is confused due an electrical short.  If water leaks from the washer sprayer due to a split hose or something similar, then that would collect at the bottom of the boot, and splash all over connections inside the boot.
This would potentially fry some of the drivers in the BCM or just cause random electronic shorts.  Either way, you either have to clean up all the connector and/or replace the hardware.  I'm not sure that grabbing the appropriate config from a BCM that is potentially corrupt is the way forward.  You might need to get Skoda to recode it for you from factory defaults. 😞
On the boot lock wiring it there was only a few drops of washer fluid on it but enough to get the boot lock wiring connection wet.
here is my vcds scan
Tuesday,10,December,2024,18:37:20:14836
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: TMBBG7NE3K0145182   License Plate: 101224
Mileage: 155814km-96818mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 20 42 44 4B 52 5F D6 D7
VIN: TMBBG7NE3K0145182   Mileage: 155814km-96818miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DGTE)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 HT    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 6591
   Revision: 22102001
   Coding: 01254832432501090000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM16TDI03004L906056HT 004006
   ROD: EV_ECM16TDI03004L906056HT.rod
   VCID: 06546A76B8A4B27A65F-8052
   VINID: 91D4925C77950DB001105048084C90878B
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 043 E    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1603
   Revision: 00005008    Serial number: CU501901266503 CVN: A8376DEB
   Coding: 0014
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021.rod
   VCID: 392ED18AB9DA0D8258D-806C
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 ED    HW: 5Q0 614 517 BM
   Component: ESC           H45 0107
   Revision: 00000000    Serial number: 60269000002168
   Coding: 24078A91102409714078060860C5242451089002600624723041F070D0024B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod
   VCID: 77AA17B2CF4EDBF26E9-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 0111010400211001100500480010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 74B020BEDE38B0EA4BB-8020
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
2 Faults Found:
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [00001001] - Mechanical Failure
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 155272 km
                    Date: 2024.12.07
                    Time: 15:41:04
                    Voltage terminal 30: 14.0 V
                    Outside temperature: 9.0 °C
                    Pressing a button-Defrost: Not operated
                    Pressing a button-Recirculating air: Not operated
                    Pressing a button-Rear window defogger: Not operated
                    Pressing a button-AC: Not operated
                    Pressing a button-Left heated seat: Not operated
                    Pressing a button-Right heated seat: Not operated
                    Pressing a button-OFF: Not operated
                    Pressing a button-Parking heater: Not operated
                    Pressing a button-AUTO: Not operated
                    Pressing a button-SYNC: Not operated
                    Pressing a button-Menu: operated
                    Pressing a button-Footwell air distribution: Not operated
                    Pressing a button-Upper body vent air distribution: Not operated
                    Pressing a button-Air distribution up: Not operated
                    Pressing a button-AC MAX: Not operated
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [00001000] - -
          [PTC-Reduzierung durch MSG]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 155790 km
                    Date: 2024.12.10
                    Time: 09:39:43
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 0
                    Auxiliary heater: in stages-Target value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001903101082 Dataset Number: V03935287LZ 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CA0089EF668F8AA03B-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 181223  051 0916
   Serial number: 887253F0401835702353
   Coding: 1E4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SAY19M02D04H20M46S19
   Coding: 00885D
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY182843M84
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0314
   Serial number: 00002856223982650587
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 B    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000017121808491061
2 Faults Found:
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [00001000] - Alert Emergency Activation Stage 1
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 2
                    Mileage: 155272 km
                    Date: 2024.12.07
                    Time: 15:45:54
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Automatic high beam assist: operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 13.2 V
                    Outside temperature: 9.5 °C
15360512 - Component Protection
          U1101 00 [00001001] - Active
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 155272 km
                    Date: 2024.12.07
                    Time: 15:41:04
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    last_wakeup: Pin A54 Klemme S
                    Voltage: 14.4 V
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419619031 Dataset Number: V03935274DU 0001
   Coding: 0601050011
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000_009_SK37.rod
   VCID: 4ACC9E46EC3C961AC17-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Dataset Number: V03935269HY 0001
   Coding: 3300608141FFC728949C810500400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D0B07ECE18406A3BB-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2P0HMN42 Dataset Number: V03935283UZ 0001
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0B425B42A3C6CF123A1-805E
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 801 19
   Component: SideSensor_Df  008 0887
   Serial number: 357000000002130D3835
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 301 19
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000005146C973K
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 454 802 401 19
   Component: SideSensor_Dr  301 0148
   Serial number: 351001E437D17000000G
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 601 19
   Component: SideSensor_Pr  301 0148
   Serial number: 3520022708C170000006
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 912 18
   Component: FrontSensor_D  304 0149
   Serial number: 35500C879EF16000000%
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 951 G    HW: 5E0 920 951 G
   Component: KOMBI         312 2700
   Coding: 27A502082980860001886B011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B02FBC24386AF12DA1-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009102873 Dataset Number: V03935289UD 0001
   Coding: 030100045F087300EB00024A1C0F00010001070000000000000000000000
   Shop #: WSC 31000 790 00234
   GVL: 01463C0000000100400C80000000C80000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013025
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E8432D6B0149A3ABDF-803A
   Generator:
   Component: 0-00-00-00-00
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0170
   Serial number: 000000000C2724210119
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1051
   Serial number: 7588600300190124245B
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 23
                    Reset counter: 218
                    Mileage: 155272 km
                    Date: 2024.12.07
                    Time: 15:41:04
                    Terminal 30 power supply: 14.1 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 57A 857 511     HW: 3G0 857 511 G
   Component: FLA           H10 0010
   Revision: AA001001
   Coding: 0404010700000100000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 688844CE92F0440AF73-803C
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000363487848  Dataset Number: V03935292LE 0001
   Coding: 00110020D001020000001100
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 48C8A44EF230640AD73-801C
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000026970765
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935289WB 0001
   Coding: 81170000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 31011910522458 Dataset Number: V03935283ZQ 0001
   Coding: 000000070900046600003D01010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 3536DDBA95C2E9E2BC5-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000361633478  Dataset Number: V03935292LG 0001
   Coding: 00110020DC01020000001100
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 47CAA772FF2E6B72DE9-8012
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000026917811
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0480
   Serial number: SKZAZ2W0253750 Dataset Number: V03935311CB 0001
   Coding: 03730101FF00000041111201008800002F0208C601200500CF
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 3430E0BE9EB8F0EA8BB-8060
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: SKZ6ZHW0340171
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 G    HW: -----------
   Component: ECE1 2022/23  --- 1810
   Serial number: --------------------
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EA40296E074EABA2DF-802A
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
   ROD: EV_LEDPLUSRightKEBODVW416.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.1V)-----------
Anyone care to have a look at my vcds scan please and share any thoughts.
It looks like something has triggered component protection to kick in but I can't imagine what.
I'd probably start by finding a dealer or local independent using ODIS with online access to reset CP. Guess you could try disconnecting the battery for a few minutes to see if restarting everything helps first.
Certainly isn't anything obvious to suggest the BCM is faulty...
I’ve disconnected the battery but still the same. I’ve managed to find a guy who has access to the servers. I would imagine he has Odis. I’ll report back next week with an update as that’s the earliest he can book me in. I appreciate your help.
Did you change out your MIB / Head Unit for anything?  That has triggered out Component Protection for a number of modules.  This can only be cleared by an hour's labour at a Skoda Dealer.  Make sure that if you have a remanufactured Headunit e.g. updating to later MIB 2/2.5 Columbus/Amunsden system, it will need to have the CP removed.  The only other thing is: the boot handle button has failed.  This is a common failure and is easy to replace.  Its a possibility that the screenwash has shorted out the switch too.
Edited by varaderoguy
Everything was working fine and issue started when my speedometer started flashing and beeping saying boot is open. Once I inspected the boot I noticed few drops of screen wash fluid on the boot lock mechanism wiring. That’s when the interior lights all went off and radio and speedometer lights went very dim. I got a new rear wiper motor installed in and used contact cleaner on the wiring for the boot lock mechanism. That never helped too. Spoke to Skoda and few other independent specialists who all say bcm unit has failed.
Boot handle still works as normal. No I never changed the head unit or anything else on the car. Problem only started with the drips of screen wash in the rear wiper motor.
Would you recommend that I change the boot switch and lock mechanism? And then try vcds to clear the component protection?
VCDS won't clear CP.  This is explained in this Ross-Tech thread . My concern is that if the boot switch is still working okay, then you either have an intermittent switch issue or the screenwash has got into the electrics and has caused the 09 gateway driver module to either short out (in which case, it is expensive to replace) or think there is still a short in the switch.  A tech looking at that series of codes would look at the switch and probably replace it, then retest.  Get a second hand switch, connect it up, clear out the codes and try again.  If that doesn't clear out the codes, you'll know you have a problematic driver in the BCM.  The only other thing I can think of - is the screenwash has capiliaried itself up the wiring harness to another connector and has caused a short there too.  Download the wiring diagrams from ELSA (its about 7euros for an hour's access, download all the info for your car) and start checking there.
  • 4 weeks later...
Do you have anything permanently plugged into your obd port?
No I never leave anything plugged in to on port. I got a replacement 2nd hand BCM Unit from online and got an independent garage to change this for me today and also update via Skoda servers. All working good now.
That's good to hear. Don't leave anything plugged into the BCM permanently as there is a technical bulletin saying how it can fry the BCM.
I had a tracker for work that plugged permanently into the OBD that fried mu BCM and I couldn't read my virtual dash. Work had to stump up the best part of £800 to sort it out.
2nd hand BCM plus installing and programming in cost me no more than £300 from an independent specialist
Skoda wanted £1000 Inc vat.
@Aakayamy How did you find a specialist? We are having the same issue after replacing the boot catch and Skoda are quoting the same.
I found a specialist in Glasgow. I bought a 2nd hand BCM with same part number off eBay for £40 and Took it to a specialist who charged me £280 for installing it and programming it.
so total was £320. Skoda quoted me £1000.
where is it you stay?
I'm in the east midlands near Burton. Having trouble knowing what to look for specifically - we took it to a non-dealer garage who have ODIS but they were also quoting the same ~£1100 or so.
Did the specialist you used need ODIS too or were they just a general auto electrician?
My guy used Odis. Do you have vcds? If yes you can get your bcm part number from there. If no then you will need someone with vcds or maybe odb11 and get you the part number so you can buy on eBay. Once you have that you will need to find an independent VW/skoda/audi/seat specialist who can install the new bcm unit and program this.
by any chance has your stereo and speedometer lights gone dim? Also your interior lights won’t work?
I’d have helped you with vcds as I have my own cable but I’m based in Glasgow.
We had the exact same issues with interior lights. Thanks for the help
