Everything posted by SouthernComfort
MK4 vrs clima question
I think you might be right, a possible problem going on there. Certainly would be a shock if we had 6c during summer π₯Άπ₯Ά. Not unheard of in the southern regions in mid winter though, very early am or late pm
π It's not too hard to follow, with the clima you get what you set, it will either warm up or cool down to the temp you set. If it's only 5c outside, of course it will blow warm to reach mid teens. BTW, this continent has many climates ranging from Alpine to Tropical, but I'm sure you knew that. Somewhere here we have one very similar to Hampshire!
MAF Sensor?
The timing seems rather coincidental and the requirement for a new turbo seems a bit extreme, anyhow if they're going to 'gift' you a new turbo then it can only be a bonus for you. I agree with @Breezy_Pete, the MAP sensor is more often the one to become gunked or sooty. I've never yet had to replace the MAF in any car, but my previous car did need the MAP regularly cleaning (using one of the proprietary sensor/throttle body spray cleaners). Regardless of what the dealer does, I'd make sure the MAP is checked.
Same here, I leave mine to 22c auto year round and never have an issue. If the ambient & car interior temps are hotter, it rapidly cools down to the set temp i.e. gets there within 2-3 mins. As always, mine did so this morning with 35c ambient and hotter still in the parked car. If those in cooler climes are setting to 16c when ambient temps are much lower, then the clima will heat up until 16c is reached as it's designed to do. There's nothing quirky with the Mk4 clima in my opinion, in fact I think it works brilliantly. As an aside, these cars (and all VAG cars AFAIK) are built with either a 'Cool' or 'Tropical' specification. The factory data sheet will show either code 0Y2 (Tropical) or 0Y3 (Cool) according to the car's import climate. I know mine is Mine 0Y2 Tropical and I imagine northern European countries would be set to Cool. Having said that, I don't think it has anything to do with the Clima calibration, I believe it designates the coolant type i.e. lower freezing point temp in Cool climate vehicles and possibly a higher boiling point in warm climates. Happy to stand corrected on it, but that's what I've been able to discover about the differences so far.
Shelf in glovebox
The slot is to hold the owners manual. The dealer pointed it out to me when I took delivery.
How to find exact spec....
Most likely the case. Photos often misrepresent real life colours/shades. Mine is white, so there wasn't much to doubt!
I bought that report for mine last year from the same source, quite useful to have. Curiously two or three items are in German, easy to translate so no big deal. For 3 Euro ($5 in my language), it's a bargain.
Issues playing music from USB stick
P.S. Looking back on the posts, my method seems to be much the same as @Novascape described. Numbering each track in the folder is important for the playing sequence.
I don't know how orthodox my method is, or even if I'll be explaining it clearly enough, but I have a simple Sandisk stick and have arranged music into Folders saved to the root. I've individually named each folder as either a dedicated album name, or a compilation name to contain a selection of tracks. From my PC I just drag the tracks (mp3) to the relevant folders on the stick. I don't try and save an entire album by album name, instead I copy all the tracks from an album into the relevant folder. Everything works fine and plays in the order I've saved them, any relevant track or album data shows on the screen as each track plays. When plugged into the car's C drive (using the innermost of the 2 console sockets) , the infotainment menu recognises the stick as 'Partition 1', I click on that and the list of folders appears on the screen ready to open, I can then choose to either 'play all' or scroll down to specific tracks. I ignore the infotainment's 'album' and 'track' menu, and only open 'partition 1'. Never had any issues with this method.
Difficulty finding the right drivers seat position
With any new car it takes a few readjustments to find the perfect position. The infinite combinations of rake, lumbar, distance and height settings, plus steering wheel height and reach means a lot of fiddling. Manually adjusted seats generally don't have the same micro-adjusting scope as powered seats, but persist with it and you'll get there. Octavia's seats are among the best of any car I've had.
Reduced performance before service
I'm not experiencing this phenomenon, but inevitably conditions and fuels do vary by region. What I can't understand is why those factors would cause a steady deterioration in performance which suddenly improves after servicing, unless very dusty conditions progressively / prematurely clog the air filter. If the performance improves after a service where the air filter hasn't been changed, then it's a bit of a mystery.
Quoted Β£1400 to fix code E313
So are you're saying you're still under warranty (i.e. factory warranty)? If so, I'd be expecting it to be fully covered.
Earlier VAG DSG transmissions were plagued with this problem for several production years. I had one replaced under warranty in my previous Golf. If you're out of warranty you may be at the mercy of dealer procing as I'm not sure it's something an independent VAG specialist would tackle, although it's worth shopping around to find out. If you're not long out of warranty, and given that it's well known problem, it might be worth talking to Skoda direct.
Amazing Fuel Efficiency 1.5 Petrol Estate
All AU/NZ non-RS variants are so equipped, I also understand it's the case in North America too. Shame that the Aisin box isn't available in UK/Europe. I'm not sure why the obsession exists with DSG, having experienced it in the Golf I find the 8sp a much smoother drive and better able to determine which gear it needs to be in, especially at low speeds.
Not familiar with the 1.5 and ACT, but IMHO the 1.4TSI and 8sp torque converter box is a seriously sweet combination. It's one of the best cars I've driven and a great improvement on the Golf DSG I had a while back.
I've always been amazed with the fuel economy in this car. I did a recent 800km round trip to the west of the state and on a combination of highway & freeway running (most of the journey) the car consistently returned 4.8l/100km (59mpg) on cruise set to 100/110kph. 8sp Auto, 2 adults, dog, luggage. Add on the urban driving at each end traversing city and suburbs and of course the overall average obviously gets to 5+l/100km. Even pure urban driving is still around 6.5l/100km. Very pleased with that, and 'slightly' better than my old 6's and V8's used to be π
RS IV - High pitch tone
Has it happened ever since you bought the car, or is it something that's developed more recently? I can't pick up a whistle or buzz from your sound bite, but it does sound like wind noise. From what you've described I had the identical problem in another car. One of the front windows wasn't fully closed to it's stop. It looked closed, but was about 1-2mm off the stop. A loud whistle only started from around 60kph and it was solved when the mechanic took it out to listen for himself - very embarrassing! I know you have obviously checked the windows et al, but it still sounds suspiciously like wind. Is there anything, even a tiny foreign object, stuck in one of the upper window channels that you can't see?
Kessy system, engine not starting
I carry the key in my RH pocket as a rule and it works fine, however once or twice the 'key not detected' message has popped up, so that may be the reason. Shifting it to the LH pocket is a good idea, as is never placing it in the console!
Coffee cup holders too small - any expansion adaptor recommendations?
So do I. I have a Thermos with a slim bottom end similar to the ones @TheWanderer listed above and it fits fine. Thankfully mine didn't cost anywhere near the equivalent of 25/30 UK pounds though, that is a hell of lot for a coffee mug π²
DSG, P, brake and acceleration pedal
Ok, obviously you have read the manual - good. However to cherry pick that particular maneuver is an exception I'll concede, but in performing that (usually called 'rocking' the transmission to free the car stuck in snow, mud etc.) is not the same thing as being on the move. With rocking, the movement is very short, slight and at no speed. Just don't shift between selections while driving unless it's to manually shift from D (Drive) to S (Sport), or to manually use the paddle shifters in D or S.
I agree, there's nothing to be scared of with an auto box of any kind, DSG or not. So long as common sense is applied you can't really do anything wrong that will break it (other than moving the shifter to another setting while on the move!). It always makes sense to me to double check the car has applied the ebrake for you when when parked in P, on a hill particularly. BTW, in case you haven't RTFM in detail yet, it's worth doing so, these car are very sophisticated and it will answer many questions that might be in your mind.
UK spec VRS not as good as EU
Seems the FL model may have a few minor deletions - no touch lock buttons on the rear doors, now the absence of horned rear headrests? Even my '23 Style model has the latter, doesn't need to be a VRS to get those. But then there's always been the matter of regional differences in equipment levels too.
Mk4FL Car Key Battery
My car is just on 2 years old (from build date) and the message just came up on Friday, I've now replaced with energizers in all 3 keys. The keys are kept in RFI pouches and get rotated once a quarter to achieve even wear. Lately I've noticed a very faint even 'ticking' sound coming from the car when all is quiet in the garage, it stops on unlocking the car. I'm not sure what it's related to but haven't noticed it before.
Car Locking by Itself
You're welcome. You say it's happened twice and you wanted to avoid it happening again, so you got it based on what I do myself. I never place the key in the console or anywhere else in the car, it's always in my pocket. At least until you get it sorted, whatever receptacle you have with you that you wouldn't leave in the car, is a fit place to stow the key. Sometimes you have to go 'old school' to mitigate a problem. BTW, this issue isn't unique to Skoda, it also happens with other makes.
Octavia MK4 not approved for towing.
