Stonekeeper
Everything posted by Stonekeeper
  1. Probably the new powertrain from the Passat that increased electric only range to 62 miles
  2. https://www.honestjohn.co.uk/real-mpg/
  3. https://ownersmanuals.blob.core.windows.net/ownersmanuals/en/Octavia_5E/05-2015/Amundsen_Bolero_Navigation.pdf Page 39 onwards
  4. Not all usb cables are the same. Genuine phone cables supplied with the phone usually charge and transfer data but some third party cables only provide power. So initially i would suggest trying a different cable
  5. Salt water (sea) and freshwater (rain and rivers) have very different properties? https://socratic.org/questions/why-is-seawater-a-better-conductor-of-electricity-than-water-from-a-freshwater-l
  6. Many after market dashcams are set to switch off when the ignition is turned off/stops receiving the 12v feed.. You can sometimes change this setting in the cameras menus to allow the camera to continue to record for a period of time.
  7. i don't think Smart link is needed for the phone to work for calls. If you have changed phone you may need to remove the old ones details first Here is the manual https://ownersmanuals.blob.core.windows.net/ownersmanuals/en/Rapid_NH/05-2015/Amundsen_Bolero_Navigation.pdf From page 30 watch for prompts on the phone as well as the unit whilst pairing
  8. hola charly. Bienvenido al foro de mensajes. Obtendrás más respuesta si eres capaz de traducir tus publicaciones al inglés.
  9. It is not compulsory though is it? Does the car still have smartlink to connect your own phone to use your own existing data plan if you have one? Personally if a car doesn't have integrated satnav i won't be buying it. I have very limited resources for paying non-sense subscriptions.
  10. It has a towbar and skoda have won towcar of the year awards many times with the caravan club so it's a good bet.
  11. I would not rev the engine of the donor car whilst jump starting either. If the leads are decent quality and properly connected it should not be necessary. Your starter motor is connected to the donor cars battery. Positive to positive pole and negative to chassis earth point
  12. Depending upon how hot their exhausts were when diving into that cold water, the emissions tests next mot time will be interesting with possible failed catalytic converters
  13. I don't think i would be worried about the tyre, on the rear at 60,000 miles it could be an original that has just come to the end of it's life after hitting one too many potholes or been underinflated when towing the caravan. It appears to be a long way from you though for you to go and have a look. The mot and timing of sale is probably just to get the best price for the car, The one owner has done roughly the same miles each year too which is consistent. has always took it for an MOT ahead of it's expiry date which shows some evidence of care. You could do with seeing some interior pictures and service history?
  14. I think it's £72.99 per year for up to 60gb
  15. Is there a spanner next to the sos button? If you have paid the subscription i think you can push the spanner next to the sos button?
  16. Sorry to hear of your issue, glad it sorted itself out, Is the SOS button you refer to different than the one that calls emergency services in the event of accident or need for medical assistance?
  17. 2' 6" deep, They are mad
  18. I have had similar when it turned out to be a mis-shapen tyre.
  19. If you format the card and then just drop all the tracks on to it with no structure at all i think the system would struggle to sort it out. Described in the thread i highlighted above Format card/stick Create one folder on the card/stick Put one single track in the folder first Then put folders by artist or album into the first folder but do not have folders within the artist/album folders (shuffle gets lost amongst them) You can then find the individual track and press shuffle, the system will shuffle everything Or select a folder and press shuffle and it will shuffle the folder. Hope that helps. The difference between your computer reading the card and the car reading the card is that the car cannot "read from root" so only looks for files it can see. Finally. make sure the tracks are not DRM protected . Your computer can play them but the skoda system will not play "Some" drm material. All the acceptable file suffixes are in the manual
  20. There is a thread here that might help, also has a link to the manual
  21. Sorry Graham you are reading something that hasn't been written Assuming you mean "Obviously we don't know exactly how well-sealed other parts of the Model S are, but it's safe to assume that the battery pack—which contains lithium, which bursts into flame on contact with air or water—is fairly impenetrable. The fact that the Model S has a "bioweapon defence mode" also suggests that the cockpit at least is very well-sealed." It does not say that the pack will burst into flames if water gets in. The sentence says that they assume the battery pack to be fairly impenetrable. it also states, as you do, that Lithium bursts into flames on contact with water. You changed it by ignoring punctuation.
  22. Boat mode 😉 https://arstechnica.com/cars/2016/06/tesla-model-s-floats-boat-video/ Anyone driving through a depth of more than 5 inch is taking a gamble
  23. When you say you managed to break it within 5 minutes. Did you just pull it down and it broke?
