Cairus
Everything posted by Cairus
  1. You don't understand the translation 100% correctly... I have no problem at all when it's deactivated. I spent days looking through the gateway's data sets to see if it can still be deactivated. I'm concerned about the incorrect information. The first post says it was tested on the vehicle and works. That's a false statement for a 2022 model year vehicle. Many people think it works and copy it, but then it doesn't work.
  2. I recommend at least adhering to the manufacturer's specifications regarding service. Also, clean the pump strainer. And please don't do a visual oil check; that's simply not possible. The clutch manufacturer's service and maintenance intervals are shorter than the manufacturer's specifications, just a suggestion.
  3. Do you know that you can now patch the 2Q camera for traffic sign recognition? And just as a note, please note the differences between coding and adjustment. The voltage trick for start-stop is an adjustment
  4. Did you also change the Haldex oil? That's the basic setup. If you do a service, you'd have to re-measure the geometry from the diff to the pinion, which isn't usually easy to do yourself.
  5. Password send me an PM https://mega.nz/#P!AgFHrxWdPBAD5Ng87rQKwKE829ntj9nW04Wt6QsfGDnKRbZYAmki0KKCKNGWXqh9tz9CzzfOVrY9i87bgubj6tAJAjvquNuRmFo0SUfoAfKCmby9y7vADpKuZCoUKoLrf49tx8nqCNI
  6. VW has integrated a CID query into the smaller MIB2 navigation systems, such as the Skoda Amundsen, which require an inserted SD card. This CID query is performed every time the system is started. Because it's software, it can unfortunately happen that the query is evaluated negatively.
  7. I even wrote an alternative solution... it doesn't help anyone if you write in the first post that everything has been checked, which isn't true. The topic is Kodiaq 1 Facelift model, built in 2022. I think it's a rumor that you can outsmart the start/stop function using the solution you described. I think the translation is also causing problems.
  8. This is about the first-series Kodiaq facelift. Model year 2022. Your voltage trick doesn't work here anymore... do you really think I need your list? Sorry, I'm correcting mistakes.
  9. I don't question their work, but it may not work in the next model year, etc., so I think control unit information is quite important.
  10. Look Here: https://wiki-online.vcds.de/de/Codierungen/MQB/Licht/US-Standlicht
  11. I would download the firmware again, first unzip it on the PC, then copy it to the USB stick and try again.
  12. I wouldn't update directly from 1806 to 1985 anyway. Where did you get the 1985 firmware? Is there a reputable source?
  13. I think that the method of changing the voltage on your model works and that the start/stop function is outsmarted is a rumor without manipulation in the engine control unit or gateway data set it is no longer possible to outsmart start stop... partly it is possible via control unit 08 and the AC conditions In addition, such a list makes much more sense if the affected control units of the coding carried out, hardware hardware version software and software version are included
  14. Do you test all the codes you specify here yourself?
  15. When the caravan is connected, does the additional indicator control in the speedometer come on?
  16. When the caravan is connected, does the additional indicator control in the speedometer come on?
  17. Why are you deactivating the assist systems? Plug the connector into the trailer hitch and start the vehicle. See what happens.
  18. Do you always get this error, regardless of whether you have a trailer attached or not? Immediately after starting?
  19. Retrofitting possible, question of effort and money. the DCC chassis is required, the control unit, wiring and programming
  20. Show the unit Informationen. You have to Patch it or buy the Key
  21. I would strongly advise against using these apps
  22. This ist the newest Version: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH2_P410_EU_202522.zip In this case, Skoda is even currently
  23. From my experience, the maps in the update portal are usually one version ahead of the most recent...and the update can be performed while driving. Repeated interruptions, etc., don't make any difference.
  24. What do you hope to achieve with this? You set this in the lighting channels in control unit 09.
