Everything posted by vfr
Estate Boot lip protector
I bought this and fitted it to my current Octavia Estate and have been very happy with it. It wasn't hard to fit either. https://www.ebay.co.uk/itm/375279768181
Unidentified Wire
Nope, I had it on my previous Octavia that didn't have the remote opening boot. I also have it on my current one that does
Infotainment issues 13.1
I posted this on your other thread on this, My first point of call would be back to the dealer, they then need to do some proper investigation and not send you away with an obvious fault. Have you been back to them, it certainly shouldn't be doing this?
- Probleme infotaiment 13.1
Broken washer nozzles
Is there a reason why you're not trying your local Skoda dealer, if they don't have them in stock is it not something they can order in?
New software available version 1989
A factory reset will reset the infotainment back to a clean status without any users associated, apps installed or any personalisation. It will keep the currently installed version of the firmware though, this isn't possible to rollback.
Cracked Headlight Casing
Hmm, just noticed this too on my car. When you say known problem, does that mean they have taken ownership of it and are replacing them?
Skoda connect renewal?
Yes, that is the case, it's a one off cost to add the features.
Haldex oil change
The question would be, does the lease company expect it to have been done? I have a personal lease, but with a maintenance plan with them, so everything that the lease company wants to be done is done.
Protruding wire/metal in boot catch
The plastic flap is missing part of it. That is designed to go on both sides of the catch to stop stuff dropping down inside. That part is a spring to fold it back up
Google maps volume
You can adjust it using the scroll wheel on the steering wheel when it is making a navigation announcement. If you do it at any other time it will just be the radio/media that gets adjusted. The display will show a different icon when you are adjusting the navigation volume.
- Usb c port displaced
The same happened to mine, I was temporarily plugging my dash cam into it untill I got the fixed wiring in place. As soon as I pushed the cable in, the socket did what yours had. I managed to lower the plastic cover and push it back into place. I haven't tried since, so don't know if it is a permanent fix.
Please add max 1qt oil. You can drive on.
If it is still only half way up the dipstick, then it would be a good idea to add some more. Do it in small stages to give it time to flow down. As it stands just now, starting and running it may clear it. But, personally, I would prefer it to be at the upper level.
Air conditioning sometimes freezing windscreen
What settings do you have for the rest of the air con other than the temperature? Are the condensation patches on the inside or the outside? You mentioned that they were two patches, but this has now extended to the condensation on the whole screen, has any water been spilt in the car, had it recently been valeted etc?
Remove vomit smell from Suedia seats?
Oh, never good. valet pro enzyme odour eater is a good product and should clear it up, but may need more than one application. If you have access to a rug doctor type carpet/upholstery cleaner, then that will help tremendously as it will pull liquid out of the seats too.
Washer fluid level warning
That surprises me, they didn't misunderstand and think you were asking about headlight washers?
According to the online manual you should have a warning message for low fluid level. It sounds like it's a fault. I had the same fault on a nearly new Passat I owned. https://digital-manual.skoda-auto.com/w/en_GB/show/74c16e67a62fd18b0088d10d1a760e7e_2_en_GB?ct=2d07bf56b150add4ac1445251cafd1ab_2_en_GB#titled58112657e40606
Bought approved used car require advice on issues
How have you got on, has there been any more progress?
Traffic sign recognition error
I'm not sure the explicit consent part is true, if you were involved in a serious accident where speed was being considered as being a major factor, then I believe the police could apply for a court order to obtain that information. But it isn't routinely shared and would also need to be demonstrated that the speed Skoda identity is actually the real one.
If you are doing it for evidence to present to the supplying dealer, then it would be very easy for them to dismiss it as it isn't their or a Skoda trained technician's view. So not going to help much. Ultimately you have a 30 day / 1000 mile exchange. If it's condition and your concerns means you won't ever bond with this car, get it changed for one you can.
Stop start thoughts
Yes, that is the case. If you have adaptive cruise control set, it is possible for the car to set off and maintain distance from the car in front too. Very convenient in stop start traffic on a motorway.
Satnav forgetting destinations, favourites and settings
Yes, that is an issue that is fixed by getting the software updated.
Wireless Apple CarPlay disconnects at specific locations
I had the same issue for several months in my previous Octavia and my current Octavia running Android Auto. This is a residential location that I would pass at least 3-4 times per week. For the first 2.5 years of owning the first car, I would pass this point without issue. Then for the last 6 months of the first car and the first 3 months of the second car, the connection would drop for a couple of seconds and reconnect always at exactly the same spot. I then had cause to approach this area from a road from the opposite side to how I would normally and it did the same. Then it suddenly stopped. I put it down to someone having a rogue bit of IT kit that was affecting the wi-fi connection from the phone to the car, or someone intentionally had a signal blocker in one of the houses in the location. Fortunately, it stopped without me having to dig any deeper.
Quick Q about wheels!
I'm surprised at the need to change for comfort. I'm on my 2nd MK4 Octavia, the first (SEL) had 17" wheels and my current (VRS) has 19", so a bigger jump than what you are suggesting. I wouldn't say that this one is less comfortable then the previous car..
