Simon TDI Sport
Everything posted by Simon TDI Sport
  1. It was only a couple of months ago. Dealer was Johnson's of Wigan.
  2. I recently replaced mine at a cost of £83.16 from local Skoda dealer.
  3. Ordered a replacement chrome external trim for my superb mk3 sel executive on the passenger rear door from Skoda. Nearly choked at the price £83.16.
  4. I have 2 x 225/45/18 Khumo PS 72 brand new never fitted want £120. These are Collection only or arrange your own courier. Collection from Wigan. these have now been SOLD.
  5. I use car scanner. Can use it for any car.
  6. Another vote for AAWireless. Works perfectly in my 2016 Superb.
  7. Have you taken the right side window switch and connected to left side? Does it work? At least then you know if switch is faulty or not.
  8. Sounds like you need to tell the car you have Bluetooth fitted. Are you using vcds to program the car.
  9. My car is 2011. Coding was needed to allow sat nav and phone integration.
  10. I've done the same thing bought an RNS315 with dab and fitted the Mic and dab antenna. That's probably your easiest route.
  11. I believe you need to have a couple of wires added to the body control module. Have a search in here for it. A member Dilligaf I think has done it and got it working.
  12. If you need a switch let me know as I have one spare that works. I'm in wigan.
  13. I have a MK2 vrs bought it in June. Have an issue with main beam flash not working without headlamp on. Works okay with lights on, doesn't work when lights off. Been told by an auto electrician that it's possible wrong headlamps fitted. I have the single bulb H7 headlamps. Is this right or should they be the twin bulb H4? Thanks for any help.
  14. Should be a straight swap as long as you get the code with it.might need it coding for the sat nav to work.
  15. Light up green but then Amber when selecting each position.
  16. Auto Headlight switch for sale brand new never fitted. Please see photo's for connection type. This is plug and play. £40 Inc p+p
  17. I believe that the MIB3 unit updates OTA. You will need to connect your car to your WiFi. Then start the update.
  18. If your using vcds then go into can gateway list and tick 37- navigation, then click write coding that should be it. You should then get navigation in the maxidot display. I've just installed Amundsen+ into my fabia vrs.
  19. Don't think you can. You will need to buy an Amundsen+.
  20. @ApertureS should be able to help you with the questions you got.
  21. Check all internal lights aswell, as it also monitors them.
  22. Have you tried fleabay or Aliexpress.
  23. Sounds like you got a problem with wiring or connectors. Check those first.
