PetrolDave
Joined
Last visited
Currently
Viewing Forums Index
Suggested engine oil for mkIV
Does is say that it meets the relevant VW spec?
Satnav update - idiot guide!
It doesn't work that way, the information that makes the SD card into a Skoda one cannot be deleted by a Format.
Manually unlocking with key blade does not unlock all doors.
Sounds possible.
AFAIK the unlock with a key blade is a purely mechanical unlock with no electrical unlock signal being generated.
Did I Locked My Keys In The Car!?
Kessy behaves differently.
What does your engine look like?
There are several different engine types -1.4TSI, 2.0TSI, 2.0TDI,... which are all different engine families and hence will look very different.
If you don't open the driver's door after unlocking the car will relock as a security measure.
Škoda G-Tec 2015 Infotainment Update
The Mk2 infotainment systems are completely different to the Mk3 systems.
- Sat Nav Update
Stuck fuel door
No, the actuator rotates to lock/unlock. Check the plastic on the actual flap for damage (my GF has an Audi A5 with exactly this problem).
Sounds like you have a MIB1 (map updates stopped in 2020 5 years after last used in production which was mid 2015), which cannot support AA or CarPlay. The only option is to upgrade the screen and Glovebox unit to a MIB2, best plan is to contact @pab567 who can usually help at better than dealer prices.
Infotainment update
The Skoda website only offers map updates, it sounds like you're looking for a firmware update?
Insurance Policy Specifying Annual Mileage
If it's a mileage estimate then AFAIK there's no problem (provided it's not a silly amount over), but if it's specifically a limited mileage policy then there's often an excess mileage charge.
CD player
You need advice from an infotainment expert like @pab567 whether you can replace the glovebox unit with a Columbus and keep the same screen - even then there will be issues of component protection, coding and adaptation.
Component protection active
Go to a dealer or an independent with online access to the Skoda corporate servers is the only way.
CD player
No Amundsen has a CD player, you will need to upgrade the screen and glovebox unit to a Columbus - and that will need component protection removing, coding and adaptation done -not cheap and if the only reason is to play CDs then I agree best to rip the CDs onto SD and use that.
ESC, TPS, Start stop, Front assist, resistance light
As said earlier, get a fault code scan done - I'd be surprised if at least one of the ABS wheel speed sensors is showing a fault code.
Replace DRLs with LED
On a 2014 the DRL bulb is an H15 that also includes the main beam filament. Replacing the bulb will almost certainly alter the main beam alignment, possibly in a way that cannot be corrected and hence cause glare to oncoming drivers. Plus finding an H15 bulb that is CE marked, and hence legal for use on the road, will be "difficult" - oh and also the headlamp itself is not type approved for any bulb type other than Halogen...
Dimming rear view mirror
If the side mirrors dim then that suggests the sensors in the interior mirror are OK since the interior mirror is the master. Which kinda says to me that the actual LCD dimming part of the interior mirror has failed - unless sombody knows otherwise?
Ryobi multi material saw
If you need it once and buying it is cheaper than hiring it, or if the hire shops only have dodgy stuff, then buy it!
I had the same problem when I first got my L&K, for me it was simply finger trouble - the interior mirror dimming was turned off! Check the green light on the mirror, if that's off it won't dim and simply pressing the switch on the mirror turned it on.
A/C not so cold.
A fault code scan will tell if there are any problems with the air mixing and distribution flaps not moving correctly, much better than trying to guess.
Enabling TSR Oct 3 VRS diesel.
Updated maps can help to get the TSR display more accurate since when it can't read a speed limit sign it defaults to using map data - but then if the map data is wrong... I've noticed it seems to default to 20 (incorrectly) on several roads near me that are actually 30, that's even with the newest Amundsen MIB2 maps.
Search for the adaptation channel by name, newer versions with UDS protocol no longer use simple channel numbers.
Tried this guide on here?
