Everything posted by numskull
- Windscreen Rain Deflectors on A-Pillars
Superb Sportline or L&K 272 or 280
We have a March 2016 reg LK 280 and love it. It’s the best, most comfortable and fastest car I’ve owned bar none. Don’t bother thinking about economy if you’re in the market for one of these, as in true urban, I get around 25 (and even less if you blip away at the lights now and again!) and the very best mpg I’ve got is about 37, on a 1k round trip.
Windscreen crack, no obvious damage (chip): Is this common?
Let me be clear about what I meant. You are not actually “repairing” a windscreen with injected resin, you’re providing a cosmetic finish to mask the damage and to stop water penetration, but the actual structure of the glass remains compromised in that position and that’s why there are rules on the sizes of a fix applied to damage. Granted, things have probably changed, but when I worked with them, neither AW or AG would repair anything over 40mm, so 1.5 inches in the D Zone and they would never attempt a repair if it emanated from anywhere on the outer edge either, as it would inevitably just continue to spread with the constant stress the glass is under and in the case of an airbag deployment or should the car turn over, this could cause the glass to fail completely which is not something you want in either scenario.
Most insurers use reputable glass installers as the costs of getting poorly fitted units rectified is high, especially those which are heated and have camera units fitted, which need to be set up and adapted to the car. Unfortunately no, I’m afraid cracks cannot be repaired.
Enough is enough...2.5 years and still faults
Interesting comparisons, albeit comparing the Arteon, A6 and 5 Series to a Superb is a bit ridiculous, on RRP alone. Is the Enyaq really that expensive; I thought the coupe vRS was around €65k? (Which is still utterly ridiculous). IMO, the tyre roar and transmitted noise, so potholes and expansion lines on the M25 concrete section, were the most annoying “features” of the 280, but now the original P6’s are off and the Conti All Season are on, I estimate both have been reduced by 70%.
In the mid ‘80’s, I got rid of a 2 y/o Fiat Argenta as it was such a lemon (and Fiats biggest dud I should add) and I had a Friday night cocar Escort XR3i which was SO bad, Ford took it back. I see you’ve kept the Superb and it hasn’t put you off obtaining another. 😊
Well, to be fair, Skoda products have been in the top 15 of the U.K. JD Power Reliability Survey for the last 10 years so I guess that’s not too bad. Kodiaq was #1 this year for reliability and #5 overall. Warranty direct state Skoda comes 4th overall in their experience for reliability, with the Superb being the most reliable model.
I never understand the illogical decisions MM’s make regarding warranty replacement of faulty parts. The damage it does to the product reputation of the is immense, any possibility of a repeat purchase is dramatically reduced and the actual cost to the two companies (dealer and manufacturer) is huge; financially and in terms of poor PR. If they’d just replaced the unit when it was identified it was faulty, the time and money saved would’ve more than covered the replacement cost. And of course, the customer is delighted. 20 years ago, Skoda was fantastic in all these areas and now there the same as all the others. What a bunch of idiots….
Center dashboard Ambient light not working
It could be related to the replacement mirror unit, but as fat as I know, that’s on a couple of block connectors. I have no idea where the strip is connected, but I’m sure someone will be along to advise you shortly….
I use the 12v socket in the boot, into which I leave the CTEK plug attached to the CTEK 2m extension lead. It’s quicker and more convenient in my case, as I always reverse park onto the drive so I open the boot, take out the extension lead and attach it to the plug from the charger, which I leave hanging down from the closed window with about 15cm of lead and once inside, I switch on the charger. I should add that I do have the battery cable with the socket permanently attached to the battery too, as this is easier to use in some locations.
Nice one. I wonder what’s added to these units make them fully compatible with the car? Are these the same units as are used in the boot area of the hatchback, AS?
Thats good. Does that include not giving a “Boot Open” warning on the dash when you open the glovebox?
Best battery for 2016 stop/start 2.0 superb
Exactly what Varooom said. There could be nothing wrong with it, but it’s just taken a battering over the past few days when it’s been so cold. Have a look at my earlier post on this subject, when I thought our battery had had it. Knowing it’s time could be up, I took out battery replacement cover with the RAC this year. Here’s what happend… https://www.briskoda.net/forums/topic/506817-new-battery-time-recommendations/?do=findComment&comment=5715148
^^^ What varooom said, plus you may not need a new battery either.
I would hasten you to use the charger asap, as that will keep the battery in its best state at all times. I’ve just returned after a 1100 mile trip and I’ve put straight onto the CTEK charger.
Deposit placed 👍
Before you drive off, get them to do it.
Speaker sizes??
Petrol leaks 280ps
Ahhh, so the noise of the air entering the tank when I open the cap is good, inasmuch as it shows the tank is sealed, which creates a vacuum as it empties?
Auto Hold system - always ON ?
I’m guessing these changes do not affect the brake lights when using ACC?
Engine Management Light Help
The RAC man I had out a week ago to check the battery said the have the kit to code a new battery correctly. Interestingly, he also said he’d replace the current EFB with an AGM as they’re more reliable and should easily exceed their 5 year warranty.
More dealer boolocks. They crack me up. 🙄
Superb SEL driver seat for tall drivers
Oh and BTW, our son is 6’5” and he has no problem driving the 280. Seat adjusted all the way back, the height adjusted so his head is around 1cm from the headlining, the front of seat raised up to have a bend at his knees and wheel all the way into the dash. .
Errr… how does the rake or size of the windscreen affect the seating space in the cabin? A greater rake angle will reduce the headroom, nothing else. Although the Passat is 9.6cm shorter, more importantly, its wheelbase is 13.2cm less than the Superb. That’s how they squeeze so much space in the cabin.
Petrol leaks 280ps
And I guess it fixed the problem??
