softscoop
Everything posted by softscoop
  1. The battery for the remote in the key will have gone flat. Easy enough to change the battery: https://www.manualslib.com/manual/375246/Skoda-Octavia-05-2009.html?page=43#manual On cars with remote locking, when you open the door with the key in the door, if you don't turn on the ignition within 15 seconds it will sound the alarm. Page 46 on the owners manual https://www.manualslib.com/manual/375246/Skoda-Octavia-05-2009.html?page=47
  2. There are few Lincolnshire folk on here. I'm in Gainsborough but often in Lincoln. I'll give you a wave if I spot you.
  3. How often do you tow? Unless it's all the time I'd spend the extra money on the removable one. Your shins will thank you as with a fixed one you'll be forever bashing them on the towball when you use the boot.
  4. All of the remaining lights, including the steering light are because of an abs fault, and won't go until the fault is fixed. The steering light will have gone on when the battery was disconnected. Turning the wheel left and right won't reset it as it also relies on the abs sensor data to do the calibration, which it can't do at the minute. If changing the sensor doesn't fix it, then have a good look at the wiring loom from the abs module to the sensor in the hub. It's not unknown for it to get broken and cause the same fault code.
  5. Check your wheels are not getting hot after a run. A sticking brake calliper will cause poor MPG, but not show in any fault scan.
  6. 1K0927903J is for cars with xenon headlights, as it has the additional connector for the level sensor
  7. I found exactly the same. All parts places even after looking at my VIN said the loom only had the ABS wire. I went on the parts diagrams and found the one that was actually fitted to the car - Both ABS and brake wear connector. 1k0927903ac
  8. On VCDS you can't simply copy the coding, you have to go through and tick all of the same options. I suspect you'll have to do the same with OBD11
  9. What was the reg? I have a feeling I've seen it around Lincolnshire
  10. View Advert Octavia MK2 Pre-FL Navigation Radio trim Bought this for my MK2 Octavia but never needed it, then sold the car. This is for cars with Climatronic air con, elegance, vRS etc. Brand new in Skoda packaging. 1Z0 858 069C £10 collected from Gainsborough Lincolnshire. Can post at cost. Advertiser softscoop Date 22/05/21 Price £10 Category Parts for Sale Shipping Estimate £3
  11. View Advert CG Lock seatbelt lock CG Lock seatbelt lock. These are now discontinued, but are still excellent. They lock the lapbelt in place and really hold you in your seat. Ideal for trackdays etc. I used to use this when I had my Fabia vRS, but I sold that 6 years ago and it's been sat in a box even since. I've no idea what these are worth, but if I remember they were £55 new. Say £30 collected from Gainsborough, Lincolnshire. Can post at cost Advertiser softscoop Date 22/05/21 Price £30 Category Parts for Sale Shipping Estimate £5
  12. View Advert Fiscon Basic Plus Bluetooth - 36946 - Octavia Fiscon Basic Plus Bluetooth - 36946 - for MK2 Octavia/Superb/Yeti with Columbus or Bolero radio. Only selling as my new Superb has factory Bluetooth. Calls show on both radio and maxidot. Comes with the loom, but you'll need a microphone as I left that in the car when I removed it. Has a normal 3.5mm mic jack, so any standard in-car mic will work These are €299 new, so grab a bargain. https://www.kufatec.com/en/handsfree-system/fiscon-bluetooth-solution/fiscon-bluetooth-handsfree-basic-plus-for-vw-skoda-36496 Collection from DN21 Gainsborough Lincolnshire or can post at cost. Advertiser softscoop Date 14/05/21 Price £80 Category Parts for Sale Shipping Estimate £8
  13. It's rubber with gripper pads, really stops things like shopping bags sliding around.
  14. I fitted this one to my estate. Would definitely recommend it. It fills the entire boot area. https://www.ebay.co.uk/itm/392089502955 My car has the rails but I never use them so took all the bits off. The rails are still there but this is flexible enough to just go over them.
  15. What bluetooth module have you fitted?
  16. You can now get full colour MFA clocks. https://m.facebook.com/aRdTechnik http://colormfa.ru/en/
  17. My old Octavia had exactly the same problem, the airbox screws rusted away. I used similar to the below from Wickes. As said they required cutting a new bit of thread into the plastic but they held fine and lasted the remaining 6 years I had the car.
  18. That issue didn't affect the Octavia engines. As far as I'm aware the Octavia engine uses a chain driven oil pump, where as the ones with the issue uses a hex bar, which rounds off, causing said issue. Only the 2.0 TDI fitted to the posher cars like the Superb and the Passat are affected. That said, I'd be surprised there are many of those with the original oil pump drive still in place after all this time. No need to worry with an Octavia
  19. Does this help? Chrome can auto-translate it and make it just about understandable. https://www.drive2.com/l/475465387685707868/
  20. I've had my Superb a couple of months now. TDI CR170 DSG estate Elegance. Ever since I got it, it never got up to temperature. Even after 20+ miles at 60mph, the temperature gauge never got over 70 degrees. In town it would eventually creep up towards 90, but as soon as I was doing anything more than 40, it would start dropping back down again. I took it to a local garage who had the car for a few hours to diagnose. They diagnosed a stuck main thermosat, as the pipes were the same temp either side of the thermostat, even well before the car was up to temperature. The car is under warranty, and the used car dealer that I bought it from have paid for the work without any quibbles, as the garage had diagnosed it as faulty. This work was done last week, but even after changing the main thermostat, it's still not much better. If I am just driving normally on 60 roads, with air outside at 15c, after 15 miles or so the gauge isn't much above 60. Thrashing the car, it rises up and does reach 90. As soon as you let off and drive sedately again, it starts falling back down. After looking on here, I'm guessing the culprit is the thermostat for the DSG cooler - but how do I categorically prove it is? Understandably the dealer I bought it from doesn't just want to throw parts at it. I could just buy it and fit it myself, but as it's under warranty, it's not something that I really want to be doing.
  21. Just to update this thread, the plastic push clips that fix the two trims to the top of the grill are : N90359101
  22. No it's not legal. Those type of bulbs will give you an awful beam pattern and will not pass an MOT. Although they will appear brighter than H7 filament bulbs, the actual amount of light thrown a distance down the road will be substantially less. The only chance of any LED bulbs giving you a decent light output is if the LED is exactly the same size and place as the filament in a regular H7 bulb. With light coming from the wrong place in the bulb, it will not be focused on the reflector, and so will just be dazzling for other road users. Philips Ultinon bulbs are designed to mimic the light pattern of a regular H7 bulb, but even they are not road legal, as they are not ECE approved.
  23. Sorted the problem. It needed a new bonnet latch. Something had broken inside, it would unlatch without any effort. Even without the cable attached. Cable was fine. I had to bust most of the plastic push rivet/clips on the trim on top of the grill. Does anyone know the right size to replace them?
  24. To fold the mirrors, either turn the mirror knob to the fold symbol, or hold down the lock button on the remote when locking, and it will fold in. When you start the car they'll unfold.
  25. Yes I think they were fitted on Fabia "2" and above on the pre-facelift https://www.autotrader.co.uk/car-details/202012177182401
