varooom
Everything posted by varooom
  1. I didn't doubt Coding II was missing, my point was that was for CAN network Yours should be UDS, like it is in my own car. You can see this on the top left of each module you enter (tip of the day!) I also have the 2x DPF sensors (not switches) which has always been an oddity to me as to why this is. One tube from each will head before and after the DPF, and the other side vents to atmosphere 🧐 My older cars (Passats) have been single DPF sensor, as it is on many cars.
  2. Was you following the UDS instructions, and can you see it under Adaptions? I will go look at my car, I am sure it's there. Mine is UDS and I couldn't see anything to adapt it 🤔
  3. Did they send a PDF? Or just spat out a long list? Handy tip, and might save trip to dealers (as service varies a lot!)
  4. Pukka (you'll have Jamie Oliver spinning in his grave) 😁 I don't think you are coding this change! UDS Protocol (G450) procedure Key ON, Engine OFF [Basic Settings] Select Adaptation of diff. pressure sensor particulate filter [Go!] to activate the Basic Setting. After the result of Finished Correctly appears click [Stop] Select Resetting of learned values of difference pressure sensor [Go!] to activate the Basic Setting. After the result of Finished Correctly appears click [Stop] [Done, Go Back] CAN Protocol (G450) procedure Instructions should be populated in a pop-up balloon when connected to the controller in question with VCDS. Key ON, Engine OFF [Coding-2] or [Login-II] button Enter the code shown in the VCDS pop-up balloon [Do It!] Switch Ignition OFF for 30 seconds After the key is cycled back on the adaptation should be completed. If it is not completed, proceed with the next steps: These steps must be repeated 5 times. Ignition ON Wait 5 seconds Ignition OFF Wait 40 seconds Repeat 4 more times
  5. Yes to 0369, I will try to send link soon to you.
  6. @PopeyeVRS What's your engine code?
  7. You should post up what you current scan error is saying for your car.
  8. MST2_EU_VW_PQ_P0449T I don't have on me the update for the PQ series, just ZR at this location I am not sure if loading new firmware will help, if you are having hardware issues, but cannot hurt to rule it out. I will PM you a link you can try.
  9. Cheeky swines, There is a 2-in-1 release update that will take it up to 1762 Then once at this next level, the same release can take the 1762 to 1896 After 1896 updates should be OTA (they might still release offline packs for dealers)
  10. ...and some long lasting memories too, win win
  11. VCDS Can show how many times it has been flashed by OBD port, if the ECU was bench flashed, the counter can be defeated and rolled back to look like it hasn't. If the car is scanned by ODIS diagnostic then checksums are sent off to the mothership, and if they don't match, then it set's a new PR Code flag for the car TD1 for example. I don't think tuner's can fool this, could be wrong.
  12. @Johnricketts Don't forget you have an unread Private Message, top right on your screen.
  13. I shall send you a PM, you will be having to operate on your own choice.
  14. And you now wish to install this to modify your car features?
  15. Because you can see this screen, you have enabled "Developer Mode" But have you installed this? This enables you to enable missing codes.
  16. Ok, maybe language barrier is issue. I don't understand your post here.
  17. You will need Developer menu enabling, this needs VCDS or equivalent tool that can login to radio and adapt channel. After you then can use the "toolkit"
  18. The screen is often seperate to the infortainment system, though I cannot say yours is 100% this is normally the case for many systems. Glad you have got it sorted out now. Example image
  19. https://manual.skoda-auto.com Put you VIN in there, the manual for the car and radio should be a downloadable PDF file. Any of the 3 radio choices should be ok with FAT32 formatted SD Card, with an MBR partition table at 32GB
  20. It seems to come off like this. Sadly the bulbs could be one of 2x styles, so best open yourself and look/order once you have. Installation of front is in reverse order
  21. Sorry my list only knows Software Train. Are you still trying to make mirrorlink on this?
  22. @Heggedalen Link has been sent
  23. Can you please find your Software Train value from your car, usually hold down your Menu button and then find it. This is also location you will need to perform the update.
