Everything posted by varooom
2023 Fabia Monte Carlo!
Looks good 👍
Air con service at 2 years?
This is yet another example of the difference from the Factory maintenance schedule and then an importer seems to decide that it doesn't matter/apply. So Factory says it's every 2 years. Skoda UK say 3 years, then every 2 years after. The same thing occurs with 1.5tsi act engine timing belts, Factory says lifetime, Skoda UK recommends every 5 years. Factory and importers should be singing off the same page, to stop all the confusion.
Hello I'm new to Skoda
Great first choice you made, good luck with radio hunting.
Satnav update...Where is.....
Was you able to update it yet?
Lost locking wheel nut key
I didn't want to point that out 😆 Welcome to the forum BTW, let's hope you can get it off now. Quite a few people don't bother with locking wheel nuts these days, not really heard of people stealing many alloys, so might be an idea to think about putting standard wheel bolt in.
Samsung Galaxy S22 series failes to connect to Android Auto
Bar Stewards!
You won't be notified of an update unless it fixes something serious. So unless you have specific symptoms that is listed in a TPI document, they won't touch you/help you.
Hi
Hello and hope you enjoy your Superb 🤝
5E0035864 - Upgrade to carplay
Must have posted at same time again 🤝
You may need to supply your VIN so have it ready. @pab567 This person is asking for a hardware upgrade if you have a moment. EDIT: As if by magic you appear.
Reversing sensors help with fitting
If you go onto erWin Skoda, and register an individual account, you can for 7 Euros (about £7.50) download your build sheet (PR Codes - helpful for parts finding) your entire wiring diagram/repair information and look up the TPI (Technical Product Information) documents that can describe issues and offer solutions. Well worth it if you are planning to retrofit a factory fit kit (ideal way) If it's too daunting, then you have @ApertureS @East_Yorkshire_Retrofits that could probably do all you need, and do a bang up job.
Missing service records in Erwin
I can only assume someone didn't do the job correctly at some point, or the garage doing the work didn't have access. I have seen VIN's where even the PDI is missing 🤔
Spare wheel
- Hello
Hello! New to Skoda ownership
Welcome Charlie, looks good there. 🤝
Amunsen MIB1 Firmware
You should hold down your Menu key for 10 seconds to find your Software Train value and post back.
A common error with VAG part numbers
So yes, what @Breezy_Pete has said about O (as in Oscar) and 0 (as in the number zero), there are no parts I have ever seen that use the letter O. AFAIK there is also no part that has I (for India) and there is only 1 (as in the number one) used in the parts catalog. Regards to the question about colour codes, here you can see a basic idea of the choices Here are some parts snippets, and you can buy some things without any colour preparation 1. 5Q0 919 275 B So this is the sensor as it comes from the factory 2. 5Q0 919 275 B GRU This is the sensor with primer only ready to paint 3. 5Q0 919 133 A seal ring without any specified colour (no longer available) 4. 5Q0 919 133 9B9 A seal ring in Satin Black 5. 5Q0 919 133 704 A seal ring in Grey colour
The SOS call/infotainment failure again. Can Skoda sort?
I have a different system, but yours will be similar to the Italian video. Just it won't update the OCU system. I do have your current version of the firmware, as well as newer. But I don't think I have ever seen a backup feature.
It will either work or not, and it has emergency boot built into it. Usually only time users have any issues is when they have a duff SD Card or USB, which has happened.
Re-joined member
Welcome back, hope you enjoy your car 🤝
Some of the firmware updates have a list which states which software trains it updates (supported) Sadly the MEN3_EU_SK370 series do the oppostite, they state only blocked trains, so it makes it hard to know if the update will apply or not. I can only send you a file and you try it. As for your problem, not sure that this will update your OCU/SOS fault, as this update I believe is not baked into this like MOI3_EU_SKMQB.
I have MEN3_EU_SK370_P0113P, which is MU SW 0469 and loads of others that might update higher than what you have
8755 Software Update - Skoda Fabia 2019 Carplay Issue
Already one step ahead of you.
I can send update and you apply yourself.
Looking for updates (I'm on Ece1 2019/2020,)
If you mean firmware, it's 0369.
