varooom
Everything posted by varooom
  1. Along with... Roomster https://www.parkers.co.uk/skoda/roomster/review/practicality/ Yeti https://www.parkers.co.uk/skoda/yeti/review/practicality/
  2. If it is not there, then it is not there, no solution. I have seen plenty of cars without any electronic service records.
  3. I don't know, but if you assemble the correct parts, retrofit is possible with a fair few cars and many mods.
  4. You should be able to purchase the plug, or get one from a scrapper and splice further back perhaps.
  5. I presume you was asking a question as to which CV boots you have. Maybe I'm wrong, just you wrote in2
  6. 1N2 - One November Two is seen.
  7. How many sensors has yours got, 4 or 6 on the rear?
  8. Try this thread to get the values out of your car for Soot measured/calculated and oil ash content. The error is stored as the DPF regen has been trying for 3.5 hrs I believe to regenerate and cannot complete. If you just got the car, odds are someone got rid of the car for this very reason.
  9. You may have to get out the wiring diagrams to check. I made this post after my own parking sensor wire fault occurred, where mine had corroded in several places. You can buy a "mini loom" section to go from the inside of the car to the sensors if you cannot repair it.
  10. Welcome to the forum, 1078804 - Rear Left Parking Aid Sensor - B1076 14 [008] -- Open or Short to Ground So it would appear that you have a duff sensor, but most likely it will be a cable fault (mice/rats or just salty road corrosion) That's what a quick google shows for that code. Edit: Sorry @pab567 didn't even see you had made a reply, I was in another browser window.
  11. Seems there might be a hack if someone wishes to try (note the system won't import a map it was not designed to read) Make sure you check the version before, and leave it for a few days to allow it to load new database. https://www.vwwatercooled.com.au/forums/f255/map-updates-kamiq-scala-amundsen-mmi-133015.html Europe Map, needs a 32GB or bigger USB-C stick Unpack to root with 7-Zip, to an NTFS or exFAT formatted USB https://navigation-maps.volkswagen.com/vw-maps/EUR_9PR085_FCT3WS-22105_Offline_Update.tar Discover_Pro_Gen.3_November_2020.pdf
  12. Different to my part number, but if you are looking at scrapper, best get several good images of your loom colours (unless you just wanna splice in connector.)
  13. What was your PN you think, so I can compare 🤝 https://www.lllparts.co.uk/catalogs/skoda/CZ If you have not already seen that catalog.
  14. I will need to process it (pack) the release. Make sure you don't try to force it onto an earlier software train. I would like to see a picture of the Software Train, and if you can any details on the Hardware version (so we can answer the question 100%)
  15. Have you already got the new battery? What is the Ah rating on both batteries?
  16. You cannot install 0308, it's for a different hardware revision. So update 0320 begins at 0308. Taken from inside the update for the previous release "Release": "MOI3_EU_SKMQB_P30603P" "MuVersion": "0306" <snip> "SupportedTrains": [ "*_?268*", "*_?270*", "*_?272*", "*_?274*", "*_?276*", "*_?278*", "*_?300*", "*_?302*", "*_?304*", "*_?306*" ],
  17. It won't work, the 0320 release can only be applied if you have 0308 installed as seen below in SupportedTrains "Release": "MOI3_EU_SKMQB_P32000P", "MuVersion": "0320", "SupportedTrains": ["*_?308*", "*_?310*", "*_?312*", "*_?314*", "*_?316*", "*_?318*", "*_?320*"]
  18. and what is the current software train installed in the car?
  19. It was probably shoe horned into the left side gap I would say.
  20. Might be worth clicking on Instructions and Regions to see what they produce 🤝
  21. I do know the PN for my own car, but it could be totally different for your own, so don't want to send and confuse your search.
  22. On the parts catalog, it's not supposed to be for Octavia, doesn't mean it cannot be placed inside. Can you take pictures of your interior of your boot, paying attention to the left and right sides (behind the lights) @MicMac You have a message, @Arturs_L type in @ symbol, and then put in name of person to tag them in message
  23. Have you looked on the inside for a stamped part number? Be 9-10 characters long.
  24. Once you look at your existing setup, it will be quickly clear if it's the mini loom pictured, so yes indeed... a scrapper.
