varooom
Everything posted by varooom
  1. When checking on the parts program, you can see 2x entries for the rear wiper blade. 565 955 425 - Pre facelift 565 955 425A - Facelift (I have not found which Bosch blade fits) If you look here you can see that the same blade part, the OEM number should be 565 955 425 for a Bosch A 331 H Which you are saying doesn't fit, so you might be needing a facelift blade
  2. You will need to hold down the Menu/Setup button for about ten seconds to enter engineering menu with Software Train information. Post up that image.
  3. You may want to check the Soot measurements before/after your run to see if the values are in a nice range. Just in case this broken sensor has stopped the regen process from happening correctly.
  4. Thanks @john999boy for the clense. @ErnestoMc I will send you a link via forum PM I didn't want some web bot scraping your email address off the site to spam you god knows what!
  5. I put in the current value from your VCDS scan for existing gateway as the starting point in the parts program, and if you keep clicking on the supersession of the parts, you eventually should end up with the 7N0 907 530H value. So in theory that should be the correct part (you can ignore the Audi/VW badge as they are all over your car already!)
  6. Sorry to hear you caught COVID, not what you need with this to deal with. That car is seriously chomping on the oil, and it's the oil itself that is source of the oil ash material that cannot be burnt off. Your local VAG specialist is bang on, but sadly driving the car to clean exhaust is now practically an impossible task, the oil will just keep clogging up the work's.
  7. There are no change logs provided, so we never know what is added. I always assume bug fixes. I can PM you a link and destructions should you wish.
  8. @ErnestoMc Software Train = MSTD_EU_SK_Pxxxx will be MIB1 you have (99.99% sure) MSTD_EU_SK_P6230 MU 0490 is available as an update
  9. When you hold down Menu/Setup key for about 10 seconds you enter the engineering menu, the Software Train will tell you what version you have easily.
  10. There used to be a little white pair of tweezers, but maybe not there or supplied. Try fingers Needle nose pliers Tweezers
  11. Top left (empty) is fuse 1 Second row is fuses 2 through 14 Third row is fuses 15 through 24 (small fuses) So third row 15 is empty 16 is the first 7.5Amp fuse 17 is empty 18 is the first 10Amp fuse seen 19 is the second 7.5Amp fuse to the right of a Green 30Amp in row two
  12. You won't normally loose any coding changes, it's just some values like how many miles since resetting fuel trips and windows one-touch. Clear out codes, do the window reset and you will be golden. You can dispose of old battery at Halfords FOC. And also, yes a shout out to Tanya for being well packaged and fast.
  13. I think the 👑will go to @pab567 for doing most of the postings, but thank you. I will PM you an update to 0369
  14. Hi
    varooom replied to V1xster's topic in Hellos and Goodbyes
    Welcome, hope you have a good time 🤝
  15. I documented the changes yesterday, all the sections to be changed. Hopefully helpful to anyone that checks this current thread.
  16. My maps are different to yours, this is AFAIK correct way.
  17. If you put the correct maps on a USB drive for the cars without SD Slot, then it should automatically update as you drive in background. That's the theory.
  18. You have a PM, but the update will not add smartlink, you need separate process to add the code to activate. I will send you a link to 0480 version via PM
  19. If you start with the number of your gateway now from your scan, it goes like this... (it's a long path) 1K0 907 530E <-- Your current 1K0 907 530F 1K0 907 530K 1K0 907 530L 1K0 907 530Q 1K0 907 530S 1K0 907 530AD 7N0 907 530 7N0 907 530C 7N0 907 530H <-- Final replacement in theory From your VCDS Scan Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 E HW: 1K0 907 951
  20. Yes I am busy, so unable to reply. Check PM in a few minutes time.
  21. @BillyParkerdoes your existing battery have the fabric heat shield around it? If not you must fit that to keep heat away from AGM batteries.
  22. Well it sounds like an 096 size AGM to me. Varta are one of the OEM suppliers to VAG vehicles, that's what I replaced mine with.
  23. Get a picture of existing battery and this can be checked, I doubt you will have issue fitting that replacement.
  24. Press and hold your menu key for about ten seconds. You will enter the hidden engineering menu with Software Train information in. Odds are update to 0369 is available.
  25. varooom replied to Yety's topic in Skoda Yeti
    With the right tools you can find out your max oil ash value yourself.
