RADIOTWO
Everything posted by RADIOTWO
  1. First I have never heard of Z-beams. But have you got the Matrix lights ?
  2. You say it is a 2020 but why have you got 2021 in your profile ? Very confusing.
  3. You don't have need for left/right dipping these days as there is no "kick up on the lights as they used to. So with the matrix lights if cuts out the light that could dazzle someone as needed
  4. What position have you got the controls at ? (from bottom to top) first position is off, the second is on(but intermittent(and of course won't wipe when stopped) the next one up is constant, then the next it higher speed, and you also if you flick it down once it will just do a couple of wipes. So from rest one up and it will wipe when driving and will get faster the faster the rain comes down
  5. You are at it again ! you are not putting a description in the title, Just you user name !!
  6. Yes Go into S1 and start using the paddles and it will stay in Manual
  7. How are you trying to set the destination ? also have you updated the maps ?
  8. Does it not only do the lights when the headlights are on ! (not just the DRL's)
  9. Cannot help with diagrams but I think you will find the Mic in console near where the front courtesy lights are
  10. Open the glove box, then towards the back on the sides press in and release the plastic clips, but be careful as there is a device to damp the opening and when you drop the lid down this device will drop out, but all you have to do is reinstall as you push the lid back up
  11. It sounds like the sensor that is sticking, if its still under warranty take it to the dealer to sort it out
  12. Which side of the VC showing the half full?
  13. I think a lot of dealers are the same, I had similar problems with Stockport, in fact they asked me "Did I buy it from them" I said no but what difference does that make, and they said none but they must have asked for a reason
  14. Which dealer was it ?
  15. Have you got tons of money ! it will cost a fortune, poss cheaper to buy a car with it all on
  16. You are in the wrong group this is the Mk4 You need to post in the Mk 3
  17. As far as I know only two
  18. I would think they are default from the factory, although they are possibility different for each country , and would not think you can change them
  19. Have you tried TPS ?
  20. That sounds cheap I would go with that
  21. it does not work it still shows US Gallons
  22. Its a pity the Us Gallon cannot be changed to UK Gallons
  23. What does the car its self say ?(in the infotainment centre)
  24. The thing with Adblue it uses more or less depending on how you drive, so might not use as much on some journeys as others. and just checked my range and it is 2,174 Miles !
