Urrell
Everything posted by Urrell
  1. Urrell replied to daveo52's topic in Skoda Yeti
    As far as I know there are nothing to do with the key or or transponder routed through the clock-spring, sounds like you have disturbed something somewhere. Or has the fob lost sync with the car, I believe you have to hold the button down for a while to resynchronise it.
  2. Tickover raised to 1000 rpm (also usually sounding gruff) is what happens when doing a DPF regeneration, could it be that?
  3. Service manual recommends changing brake fluid at 3 years and every 2 years thereafter.
  4. Urrell replied to Golan36's topic in Skoda Yeti
    Would that Beta also have the ability to code a battery change?
  5. Urrell replied to Golan36's topic in Skoda Yeti
    You'll need VCDS Why change licence plate bulbs to LED? Why not fit good Halogen bulbs?
  6. Urrell replied to Redman99's topic in Skoda Yeti
    He's not logged on since then, I suspect it's like as kids knocking on a door and running to see the resulting reaction.
  7. G13 is now the recommend coolant and it's compatible with G12. It is pink.
  8. The only reason for condensation on cold windows is water. There must be moisture in the car to create the condensation on the screen so that must be sorted first. Is the rear screen washer working OK? on my Fabia the pipe to rear wash jet had come apart at a joint under rear seat caused by freezing. Had to run a dehumidifier for a few days to dry things out after repairing pipe.
  9. Urrell replied to Redman99's topic in Skoda Yeti
    That verges on unreadable and rude, I suggest you read JRs helpful post again, sort your above post, your details say you live in London but the post above must mean very new there.
  10. Urrell replied to Amandaw's topic in Skoda Yeti
    I bet the model is an Le&aK
  11. Urrell replied to Nate81's topic in Skoda Yeti
    How did you enable that, I thought it was standard on most Yeti's, and should it not be EDS.
  12. My take would be a failed clockspring.
  13. Urrell replied to paco's topic in Skoda Yeti
    That may work for the wife but there is no way it will take notice of me
  14. Urrell replied to paco's topic in Skoda Yeti
    I have only ever had a dash creak in very cold weather and that stops when I press on the chrome ring, could it be down to the 16" wheels with 205x60 tyres.
  15. Sounds more like a bad joint.
  16. I thought the charcoal canister was only a legal requirement in California.
  17. Nothing showing in the manual for DRLs, but 15 showing as light switch.
  18. Did you do a reset on them after that?
  19. I didn't say but the man has to be supervised
  20. Easy , it was a man packing it
  21. Mostly marine supply shops. Google is your friend.
  22. It is a plastic sheet that seals roughly the area in pic below inside the door card not the door outer seal.
  23. That happened to my Fabia that uses the same system, designed for the windows not to be watertight but to let water run thru the doors and out the bottom. Cured by resealing the inner door seals where the adhesive has come away.
  24. Will this help? https://youtu.be/jOvMUKAAcJk
  25. What will you use for the delay, only about a second or so but I take it to get up to temperature before the water is pumped through. Those fitted as standard only heat if air temperature below approx +10 degrees C.
