Everything posted by Chetnik73
Retrofit new style steering wheel to Superb MK3
- Clockspring replacement help
Just pay for the original part. I bought three with the exact part number but were for other vw models it turns out. Managed to track down a skoda model online for much cheaper than the dealer and it works perfectly. Needed to code back the original code so make sure you take a scan before you remove it- Retrofit new style steering wheel to Superb MK3
I only replaced the steering wheel and added the LIN adapter in behind the airbag. It's only small so fits away nicely and enables all gestures on right side of steering wheel. I have the steering wheel with paddles but unsure of the model number- Clockspring replacement help
It seems this may be a software issue. In my original scan the middle had software 3Q0953521BD This corresponds to the skoda stalk I have in my superb. it seems the 5Q0953569A i have been sold contains different software 3Q0953521CS despite being the same part number. I think this software corresponds to a passat stalk. This part number is across multiple models in VAG group, golf, passat, octavia and superb. does anybody know if it is possible to update the software to the correct model I have or do I need to buy a 5Q0953569A for the superb only ? Software versions are not listed anywhere and am trying to avoid the dealer cost of $1000 for the unit- Retrofit new style steering wheel to Superb MK3
I sent you a PM- Clockspring replacement help
not sure if this helps https://tinypic.host/image/Screenshot-2023-10-06-15-36-40-583-com.voltasit.obdeleven.9X7Y9- Clockspring replacement help
Thanks. Unfortunately i only have OBDELEVEN. I didn't think it would be this hard- Clockspring replacement help
No offence mate but have you read the post? My clockspring failed so i replaced with exact same part number. Unfortunately the new part although identical, needs updated coding to work. Hence the problem. It won't let me change to the code which i originally had 6410. So i don't have ACC and I'm getting warnings as a result. The steering wheel is not communicating properly with other modules including engine etc It only allows 0410 and says 31 function not supported when i try to update via obdeleven to 6410. If the part number matches the original and also the one quoted by skoda according to my VIN, then i can't work out what else it could be- Clockspring replacement help
My OBDEleven scan shows 0410. The original code is Long coding: 6410 when i add the clockspring it returns the coding to 0010. I am able to update to 0410 which adds rear wiper but not anything to do with the ACC which i previously had (that is the 6 in the 6410)- Retrofit new style steering wheel to Superb MK3
I've done this. I have a spare LIN adaptor as per the picture above I'm happy to sell if you need one. They plug into steering wheel and air bag cable and enable all functions on right side of steering wheel- Clockspring replacement help
Sorry to resurrect this thread, but I cannot seem to resolve this. I have bought three separate clocksprings (squib) thinking they are the problem. They are all Valeo branded and OEM 5Q0953569A . This is the part number as quoted for my VIN. It's just the coding. I try to return the code to the original code of 6410 and get 31 function not available. My question is there any other modules or adaptions I have to change to re-enable ACC? Thanks- Retrofit new style steering wheel to Superb MK3
Sorry to revive the thread, but has anybody got instructions on how to do this?- Clockspring replacement help
So i bought another 5q0953569a, thinking that the replacement had dated software. No dice. I still have the exact problem. Error 31 - function not available. I'm using OBDeleven. I'm wondering if another control unit or similar needs long coding changes to support unit 16. If somebody has a recent scan can they please let me know if their superb has both the same part and software number. as always, any help is appreciated- Clockspring replacement help
Ok makes sense. Still no idea why i can't code the steering column back to 6410. It allowed me to code it to 0410 (rear wiper) but not the 6 (ccs). So frustrating- Clockspring replacement help
Yes. I also saw that ross tech wiki. The thing i can't get my head around is that the failed part was 5q0953569a. According to the Ross tech wiki that doesn't support ccs/acc however the cruise control worked absolutely fine with this part number. Also when i rang Skoda, they also quoted the above part number based on my VIN Im stumped See attached- Clockspring replacement help
So the old clockspring has software id 195 1879 and the unit was manufactured in 2015 The repacement unit has software id 235 1265 and the unit was manufactured in 2020 Is it possible the units software is too new?- Clockspring replacement help
Ok. So i managed to replace the clockspring. That was pretty easy to do. Just needed the right spline tool to remove steering wheel. But then i also tried to update the coding in control module 16 (steering column) via OBDEleven from 0010 to the old number 6410. Unfortunately i get fault code 31(the function is not supported) Does anybody know what to do here? I've tried security code 20103 which was accepted, but still f didn't let me change to the old code- Clockspring replacement help
Thanks. It's that simple eh? I thought there was more to it then that and there was impacts to steering wheel angle sensors etc Ok now just have to work out how to unclip the airbag given i have start/stop button and no key to unlock the steering- Clockspring replacement help
Hi I got the dreaded airbag warning light and neither my steering controls or horn work. I've ordered clockspring part number 5Q0953569A and plan to replace it. I have an OBDEleven but have no idea what i need to code to get all my steering controls and cruise control working again. I read somewhere that i just need to copy the steering long coding but I'm sure there is more to it then that. Any help or guide to what i need to do on the OBDEleven would be appreciated. Ive added my most recent scan if that helps OBDeleven data log Date: 2023-03-21 09:40 VIN: TMBKD8NP6G7023835 Car: Skoda Superb Year: 2016 Body type: Estate Engine: CHHB Mileage: 66688 KM --------------------------------------------------------------- 01 Engine System description: 2.0l R4 TFSI Software number: 3G0906259 Software version: 0003 Hardware number: 06K907425E Hardware version: H13 ODX name: EV_ECM20TFS0203G0906259 ODX version: 001006 Long coding: 0C1D00324464010B3000 Trouble codes: P261000 - ECM/PCM Internal Engine Off Timer Performance Intermittent P305400 - Starter does not turn Mechanically blocked or electrical malfunction Intermittent U112300 - Databus error value received Intermittent U015500 - Lost Communication With Instrument Panel Cluster (IPC) Control Module Intermittent --------------------------------------------------------------- 02 Transmission System description: DQ250-6F MQB Software number: 0D9300041C Software version: 4901 Hardware number: 02E927770AQ Hardware version: H53 Serial number: TFK01509031637 ODX name: EV_TCMDQ250021 ODX version: 001001 Long coding: 0014 Trouble codes: No trouble codes found --------------------------------------------------------------- 03 Brakes System description: ESC Software number: 3Q0907379AB Software version: 0723 Hardware number: 3Q0907379G Hardware version: H42 Serial number: 62545000004064 ODX name: EV_Brake1UDSContiMK100IPB ODX version: 034036 Long coding: 1E07929C34222B6F077F060341C84978492CD4E0608292F53841F0B8C2A9 Trouble codes: No trouble codes found --------------------------------------------------------------- 08 Air Conditioning System description: AC Automat Software number: 3V0907044AL Software version: 3601 Hardware number: 3V0907044AL Hardware version: H32 Serial number: 00000B00021688 ODX name: EV_ACClimaPrehVW37X ODX version: 002009 Long coding: 12110004000100011005100000101102 Trouble codes: No trouble codes found --------------------------------------------------------------- 09 Central Electrics System description: BCM MQBAB H Software number: 5Q0937084AS Software version: 0175 Hardware number: 5Q0937084AN Hardware version: H24 Serial number: 01061526100265 ODX name: EV_BCMMQB ODX version: 015001 Long coding: 0FD39A46C2C72AFB17844086B10C572C0800000000000000000000000000 Subsystems: System description: 48x RL 150130 Software version: 0121 Hardware version: 032 Serial number: 00000001501280601396 Long coding: 165DDD System description: RLHS Software version: 0059 Hardware version: 037 Serial number: S5Y15M09D26H09M06S02 Long coding: 00084D System description: Sensor, DWA Software version: 0316 Hardware version: 005 Serial number: 000000000ZY152081B57 System description: Sirene, DWA Software version: 0311 Hardware version: 004 Serial number: 00000000000033226232 System description: SysNameFanLin Software version: 0101 Hardware version: 014 Serial number: ESE0100039 System description: SysNameFanLin Software version: 0101 Hardware version: 014 Serial number: ESE0100758 System description: SysNameFanLin Software version: 0101 Hardware version: 014 Serial number: ESE0043417 System description: SysNameFanLin Software version: 0101 Hardware version: 014 Serial number: ESE0100766 Trouble codes: No trouble codes found --------------------------------------------------------------- 13 Adaptive Cruise Control System description: ACC BOSCH MQB Software number: 3Q0907572B Software version: 0192 Hardware number: 3Q0907572B Hardware version: H04 ODX name: EV_ACCBOSCHVW48X ODX version: 001008 Long coding: 320067CB55FFC428949C804D Trouble codes: No trouble codes found --------------------------------------------------------------- 14 Wheel Dampening System description: DAEMPFUNGS-SG Software number: 5Q0907376A Software version: 0120 Hardware number: 5Q0907376A Hardware version: H17 Serial number: 24091541350105 ODX name: EV_DRCONTITEMIC ODX version: 001019 Trouble codes: No trouble codes found --------------------------------------------------------------- 15 Airbag System description: AirbagVW21 Software number: 5Q0959655AE Software version: 0130 Hardware number: 5Q0959655AE Hardware version: 005 Serial number: 003NSR1390LT ODX name: EV_AirbaVW20SMEVW37X ODX version: 002146 Long coding: 88FCC0C0000000005C54000000C800000065 Subsystems: System description: BeltPretRevFL Software version: 1032 Hardware version: 106 Serial number: 3V0857701C0261P01474 Long coding: 80000D System description: BeltPretRevFR Software version: 1032 Hardware version: 106 Serial number: 3V0857702C0261P01779 Long coding: 80000D System description: SideSensor_Df Software version: 0887 Hardware version: 001 Serial number: 35700000000126747616 Long coding: 2D2D2D System description: SideSensor_Pf Software version: 0887 Hardware version: 001 Serial number: 3580000000096315F61J Long coding: 2D2D2D System description: SideSensor_Dr Software version: 6149 Hardware version: 001 Serial number: 3510002A31D1B5D4525+ Long coding: 2D2D2D System description: SideSensor_Pr Software version: 6149 Hardware version: 001 Serial number: 3520002A31D1B5D2325 Long coding: 2D2D2D System description: FrontSensor_D Software version: 6149 Hardware version: 001 Serial number: 3550002B51CF1D33312% Long coding: 2D2D2D Trouble codes: B10001B - Driver airbag igniter Resistance too high static Date: 2023-03-20 11:15:28 Mileage: 66686 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 --------------------------------------------------------------- 16 Steering Column System description: Lenks.Modul Software number: 3Q0953521BD Software version: 0195 Hardware number: 5Q0953569A Hardware version: 075 Serial number: 20150921501011 ODX name: EV_SMLSVALEOMQB ODX version: 001015 Long coding: 6410 Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dashboard System description: KOMBI Software number: 3VD920790 Software version: 1710 Hardware number: 3VD920790 Hardware version: 505 ODX name: EV_DashBoardVDDMQBA0 ODX version: 001031 Long coding: 25A5091A7F8000080188620B5001000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 19 Gateway System description: GW MQB High Software number: 5Q0907530AF Software version: 2224 Hardware number: 5Q0907530M Hardware version: 212 Serial number: 19091510803166 ODX name: EV_GatewConti ODX version: 013020 Long coding: 030100346F085900EB00025E9C0F00010001070000000000000000000000 Subsystems: System description: J367-BDMHella Software version: 8050 Hardware version: H04 Serial number: 4648657703 Trouble codes: U108E00 - Control unit in steering wheel No Communication static Date: 2023-03-20 11:15:30 Mileage: 66686 km Priority: 2 Malfunction frequency counter: 5 Unlearning counter: 159 Supply voltage, terminal 30: 14.5 V Terminal 15: On --------------------------------------------------------------- 2B Steering Column Lock System description: ELV-MQBB Software number: 3Q0905861 Software version: 0031 Hardware number: 3Q0905861 Hardware version: H05 Serial number: 15000091454004 ODX name: EV_ELVMarquMQBB ODX version: 001007 Long coding: 0800000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 36 Driver Seat System description: Sitzmemory Software number: 5Q0959760A Software version: 0009 Hardware number: 5Q0959760A Hardware version: H06 Serial number: Y0006OHL14815 ODX name: EV_SeatMemorDriveSide ODX version: 001015 Long coding: 001400000000010001A080808080000000008181000000D4 Trouble codes: No trouble codes found --------------------------------------------------------------- 3C Lane Change Assistant Right System description: HRE_Master Software number: 5Q0907686B Software version: 0071 Hardware number: 5Q0907686B Hardware version: H11 Serial number: 0378302380 ODX name: EV_HREntryHella ODX version: 001028 Long coding: 02012203 Trouble codes: No trouble codes found --------------------------------------------------------------- 42 Driver Door System description: TSG FS Software number: 5Q0959593E Software version: 0041 Hardware number: 5Q0959593B Hardware version: 020 Serial number: 130915BIC21645 ODX name: EV_DCUDriveSideEWMAXKLO ODX version: 006003 Long coding: 001D0820DE01048000001100 Trouble codes: B122D29 - Lock unit for central locking Implausible signal Intermittent Priority: 3 Malfunction frequency counter: 1 Unlearning counter: 182 --------------------------------------------------------------- 44 Steering Assistance System description: EPS_MQB_ZFLS Software number: 5Q0909144R Software version: 1061 Hardware number: 5Q0909144R Hardware version: 125 ODX name: EV_SteerAssisMQB ODX version: 012140 Long coding: 9303 Trouble codes: U112100 - Databus missing message Intermittent Date: 2022-06-06 15:14:36 Mileage: 64164 km Priority: 6 Malfunction frequency counter: 6 Unlearning counter: 68 Motor status: 2 System status: Driving mode Supply voltage: 12.75 V Temperature: 51.0 °C KFC: 56 KFA: 0 Environmental conditions: 20 uAdSensI_U1V2Filtered_gdu16: 1.20 V uAdSensI_U5VFiltered_xdu16: 0.00000 V uioUdNotFilt_xdu16: 12.89 V uAdSensI_SwitchedKl30_xdu16: 12.89 V ASC_CTRL_GET_ILWS_ERR_FLAGS: 0 --------------------------------------------------------------- 47 Sound System System description: MIB2_amp_P_SK Software number: 3Q0035466A Software version: 0110 Hardware number: 3Q0035466A Hardware version: H02 Serial number: SKZ8Z1FAS00MD44 ODX name: EV_AMPMst16C5Gen2ALPI ODX version: 001001 Long coding: 0384020000AA002FAA0000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 52 Passenger Door System description: TSG BFS Software number: 5Q0959592E Software version: 0041 Hardware number: 5Q0959592B Hardware version: 020 Serial number: 230715BGM1122A ODX name: EV_DCUPasseSideEWMAXKLO ODX version: 006003 Long coding: 001D0220DE01048000001100 Trouble codes: No trouble codes found --------------------------------------------------------------- 55 Headlight Regulation System description: AFS-ECU Software number: 7P6907357D Software version: 0090 Hardware number: 7P6907357A Hardware version: H07 Serial number: -------------- ODX name: EV_HeadlRegulVWAFSMQB ODX version: 001120 Long coding: 06D602003F010000 Subsystems: System description: LeiMo links Software version: 0005 Hardware version: H01 Long coding: B20000 System description: LeiMo rechts Software version: 0005 Hardware version: H01 Long coding: B20000 Trouble codes: No trouble codes found --------------------------------------------------------------- 5F Multimedia System description: MU-H-N-RW Software number: 565035045E Software version: 1440 Hardware number: 565035045 Hardware version: H54 Serial number: A858C0JS003612 ODX name: EV_MUHig4CGen2HBAS ODX version: 001001 Long coding: 038402080000000011510002000908002F0000E641A01E00FE Trouble codes: B201A00 - Checking software version management static Date: 2022-01-31 07:50:02 Mileage: 63215 km Priority: 6 Malfunction frequency counter: 254 Unlearning counter: 55 Dynamic environmental data: 02867A10024D44554B3631392F4D61696E20202020 U111100 - Function limitation due to missing message static Date: 2022-01-31 07:49:59 Mileage: 63215 km Priority: 6 Malfunction frequency counter: 1 Unlearning counter: 114 Dynamic environmental data: 02867A184402 --------------------------------------------------------------- 69 Trailer Control System description: ConWysTrailer Software number: 5Q0907383E Software version: 0137 Hardware number: 5Q0907383B Hardware version: H14 Serial number: 00000181563668 ODX name: EV_TrailFunctGener2Hella ODX version: 001005 Long coding: 0300000200000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 6C Rear View Camera System description: RVC Compact Software number: 5Q0980556 Software version: 0100 Hardware number: 5Q0980556 Hardware version: H07 ODX name: EV_CamSysRVRVCPANAMQBAB ODX version: 005007 Long coding: 04840201A700201F000040 Trouble codes: No trouble codes found --------------------------------------------------------------- 6D Deck Lid Control System description: HDSG-Modul Software number: 5Q0959107G Software version: 0250 Hardware number: 5Q0959107G Hardware version: H12 Serial number: 30251224100000 ODX name: EV_DeckLidCONTIAU736 ODX version: 001011 Long coding: 0D88 Trouble codes: B11DF11 - Rear lid warning buzzer Short circuit to ground Intermittent Date: 2023-03-04 12:54:39 Mileage: 66626 km Priority: 4 Malfunction frequency counter: 2 Unlearning counter: 190 --------------------------------------------------------------- 76 Parking Assistance System description: PLA 3.0 12K Software number: 5QA919298 Software version: 0161 Hardware number: 5Q0919298C Hardware version: H08 Serial number: 00030518361525301208 ODX name: EV_EPHVA2CAU3700000 ODX version: 009017 Long coding: 0371167951 Trouble codes: No trouble codes found --------------------------------------------------------------- A5 Driver Assistance System description: MQB_B_MFK Software number: 3Q0980654D Software version: 0024 Hardware number: 3Q0980654 Hardware version: H04 Serial number: 22091511P10726 ODX name: EV_MFKBoschMQBB ODX version: 001001 Long coding: 020408020000010100022347C040A00088000E100000 Trouble codes: No trouble codes found --------------------------------------------------------------- B7 Start System Interface System description: VWKESSYMQB Software number: 3Q0959435C Software version: 0710 Hardware number: 3Q0959435C Hardware version: 036 Serial number: 0380632257 ODX name: EV_KessyHellaMQBAB ODX version: 004032 Long coding: 030C0C0703 Trouble codes: No trouble codes found --------------------------------------------------------------- BB Rear Left Door System description: TSG HFS Software number: 5Q0959395E Software version: 0041 Hardware number: 5Q0959395B Hardware version: 020 Serial number: 120915BIB08891 ODX name: EV_DCURearDriveMINKLO ODX version: 006003 Long coding: 001800208001048000001100 Trouble codes: No trouble codes found --------------------------------------------------------------- BC Rear Right Door System description: TSG HBFS Software number: 5Q0959395E Software version: 0041 Hardware number: 5Q0959395B Hardware version: 020 Serial number: 120915BIB1017B ODX name: EV_DCURearPasseMINKLO ODX version: 006003 Long coding: 001800208001048000001100 Trouble codes: No trouble codes found --------------------------------------------------------------- CA Sunroof System description: SAD_STG_1 Software number: 4M0907594D Software version: 0003 Hardware number: 4M0907594 Hardware version: 011 ODX name: EV_SunRoofCONTIAU736 ODX version: 004008 Long coding: 708040648202 Trouble codes: No trouble codes found- Rear passenger air vent part number?
Does anybody know how to reattach the metal bar to each of the vent arms. My children managed to kick the vent and it fell apart. I've tried a million times and it is the most frustrating part in the history of parts. Im generally patient but this thing has me beat- Can anybody point me to a Westfalia towbar install guide?
Thanks. I have the instructions but they are a little confusing for a first time install. I was hoping somebody had a visual guide or a copy of the above linked detail they could forward to me. Installing the bar itself should be easy enough but I'm unsure of the electronics (although i do have tow bar prep pre installed)- Can anybody point me to a Westfalia towbar install guide?
The post i was referring to is- Can anybody point me to a Westfalia towbar install guide?
Hi I have a superb with towbar prep. Can anybody point me in the direction of an online guide for install? The instructions from PF Jones are a bit confusing. I saw there was a pdf and link in the forums but both are no longer available. Any help is greatly appreciated?- Virtual Cockpit Retrofit with Columbus and Canton
I have the mib2.5 and 9.2 buttonless infotainment unit which are both retrofitted. If you check the earliest post i have a file called history.txt which is all my scan and adaption history This is a pic of my setup- Virtual Cockpit Retrofit with Columbus and Canton
The frustration levels keep rising with my retrofit. Some issues below 1) For some reason i cannot see all the different types of displays on my vc. Ive got 4 displays i can choose from but am missing the single speedometer in the picture below 2) I cannot view the NAV on my VC despite correctly installing the MOST splitter and coding as per earlier post in this thread 3) I do not have the screen on my infotainment unit which allows me to personalise the vc displays I've reached out to some of the members here and they say it might be a CAN gateway issue or a BCIM issue (or both) as my car is a 2016 model (build late 2015) I've posted my scan if anybody can see what I'm doing wrong or definitively tell me which additional part(s) or coding i need. It's not a showstopper but I've got this far so would like it all to work properly Changing the gateway doesn't seem too difficult but the BCIM looks a pain in the ****. Need to know if i need to change both or just one for the items above Thanks in advance history.txt - Clockspring replacement help
