Gunson eezibleed. Will it leak? (poll)
Will this cap on the Gunson eezibleed leak? 1 member has voted
  1. 1. Will this cap on the Gunson eezibleed leak?
    • Yes
      100%
      3
    • No
      0%
      0
Please sign in or register to vote in this poll.
Last time I bled the brakes I couldn't get it airtight no matter what. Have tried to apply plenty of layers of silicone sealant on the inside and plenty on the outside. Seems likely it won't leak, but I didn't think it would have leaked before :(
Do you think this will leak? Place your votes now
Are you using too much pressure?
I think I used about 22 PSI as instructions suggest to use more pressure to test than with brake fluid.
There should be a brown fibre washer fitted to both sides of the cap where the pipe fits through it ,perhaps these washers need replacing . I used one a few weeks ago after changing the pads , i changed the brake fluid . At about 15 PSI .
