bud 1950
hi could any one tell me how to set the tappets on a felicia l3 lxi plus n reg as the noise is driving me mad. plus should the clutch pedal be the same level as the brake pedal.it would be great for help as this is my first ever skoda.:thumbup:
See http://briskoda.net/forums/favorit-felicia-fun-forman/tappets/114876/#post1331805
On my car my clutch pedal has been higher than the brake one and it's not bothered me, although they are both quite easy to adjust. The brake pedal height is adjusted by the nut behind the brake servo (which should be adjustable with everything in place) and the clutch height is adjusted by the adjuster on the clutch cable on top of the transmission housing.
cheers for that info
If the clutch pedal is very high, check that the pretension spring on the pedal is not broken
