gearbox clutch BIG problem
there is a return spring on the pedal but it doesn't do an awefull lot, i broke mine off ages ago and it still works fine, from the looks of the pics above, the old release bearing is mullered
mullered????
mullered????
Broken, or possibly even FUBAR.
:iagree: what he said
Hi,
I just finished (AT LAST) the tedious job of mounting the gearbox.
- Is very smooth now.
- I did some job to the pedals: replaced the center sleeve, replaced the clutch pedal axe and refitted it's spring. At this point there are two things:
1- (minor) the clutch pedal now is too high :o
but this I could fix it very easy, just have to place a stop point where
need it to stop.
2- When I placed everything in it's correct place, I got to the conclusion
that the Cable is a tricky guy :mad: : When you feed the pedal the
cover of the cable is what really pushes the arm (and the bearing), so it
has to be a little tensed anyway. And, the way it is, there is nothing
that push it backward.
If I'm not wrong, the only thing that I can adjust with the cable is how
hard the bearing is stick to the friction plate, then I have to let it soft
enough so the bearing make no resistance to the plate.
And If it is all that way, I'm highly worried about it.
- Finally, I have a BIG ? on my head: reading other thread I see someone say that it is possible to change gear speed without using the clutch.
IS THAT REALLY POSSIBLE? :confused:
what are the chances of screwing the gearbox doing this? :confused:
Thanks for all your help in this Issue :D
Yes you can change gear without the clutch - it's all in matching engine revs to box speed :)
