Why is my Ping so high??
I find speed test shaky at best. Wildly varying results, I don't know of any alternatives though sorry.
  • Replies 57
  • Views 5.1k
I got this earlier today. ;)
Personally speaking I wouldn't worry about your results Stu.
I would only be concerned if there was an actual problem.
netsh interface tcp set global autotuning=disabled
Also disable IPv6 in your TCP/IP settings as depending on your vista version :) or service pack level it try's IPv6 before 4
switch the whoring vista tcp auto tuning off and give it a try matey :thumbup:
Hmmm, didn't do too well there .....
global command failed on IPv4 The requested operation requires elevation.
Sorted
right click the command prompt shortcut mate and run as administrator
Not much change -
Here's a test for you.
Ping using the other machine. Then connect yours to it via crossover cat5, turn off wi-fi and try again.
Your ping should match the other machine. If not then clearly a driver issue. If it does, yet when running alone it doesnt ping well, then check your router settings.
Some routers can throttle everything but the master registered machine/MAC.
