100 cpi CAT buying advice ?
:wave: hello and good evening
Are 100cpi CATs still available for the classic Octy RS ?
If so, where from ?
Motorsportworld list a Milltek CAT but don't say what spec.
http://www.motorsportworld.co.uk/
I can't find anything on Jabba's site (do they make their own maybe, or was that GB a limited run?) or Forge for that matter, AwesomeGTi doesn't come up trumps either, or JBS Auto Designs ??.
Any ideas? ... to give you a flavour, I want to mate a race downpipe and CAT with a custom CAT back exhaust, I'm on holiday in three weeks time so that would be ideal an ideal time to get it all sorted and fitted ... vroom vroom :)
Any useful suggestions would be really really appreciated :thumbup:
It might be worth giving jabba a call,i got mine on the group buy but i would think they had more made than was requested but if they havnt got any left then it was blue flame that made them so you could try them
I got mine from Jabba and it wasn't on a group buy, had them in stock
  • Administrators
IIRC 100cel's were prone to failing. Thi might be a red herring heresay, total rubbish...
If the worse comes to the worst I still have the cat from the RS in the kitchen...I'm sure it can be made to fit.
IIRC 100cel's were prone to failing. Thi might be a red herring heresay' date=' total rubbish...
If the worse comes to the worst I still have the cat from the RS in the kitchen...I'm sure it can be made to fit.[/quote']
Thanks for the Blue Flame tip guys :)
Colin, I keep :coder: :coder: the above and ... I'm lost ? Are you offering me another standard CAT ?
I'm not a cat person myself ;)
I've got the 100cel one from Jabba and half way through my holiday the engine warning light came on and went off again about 3 or 4 days later (after some hard driving) - weird?
Andy
  • Administrators
Colin' date=' I keep :coder: :coder: the above and ... I'm lost ? Are you offering me another standard CAT ?[/quote']
I guess I am, don't know what comes over me sometimes.
Thought you were stuck for a CAT. BTW I have had no cat and now the miltek 200cel, not much performance difference if any loss, save for the noise :D
I dont have the Jabba D/P with cat but I have seen it in the flesh, its very well made and good quality. The 100 cel cat is I would describe nearly a de-cat, you look through one end and can see right through to the other. As said its made by blue flame, try jabba 1st if you want one they had a few a couple of weeks ago when I was there. Then see if you can get it at the group buy price.
Thanks for the replies guys.
Before I asked the question here, I was about to order a Milltek...
Now it's Blue Flame all the way. Maybe from Jabba, maybe direct... just have to see how the calls go tomorrow.
Thanks again :)
Pete
Before I asked the question here' date=' I was about to order a Milltek...
Thanks again :)
Pete[/quote']
Jabba should have dp/cat in stock.....should have had 10 from the original order and Briskodians bought 5.
If you already have an aftermarket cat back you may well have some sort of reducer to join to the standard dp/cat. Check out what you need to connect the two system together.
That said if you get Jabba to fit they'll sort it for you.
If you go to Bluemflame direct you may have to wait as I'm not sure they will have any in stock....they may have to do a new build run.....
...don't forget to mention Briskoda if you go Jabba route....5% discount.
thankyou please :)
know its not a skoda but the sports cats been fitted to the clio 172's have been having a few problems with engine lights coming on etc etc but when fully dectted not a single problem
with the octy the problem seems the other way round, decatted we get the engine light and a fault code that suggests that one of the lambda probes is faulty. We dont get it with the sports cat because there is a difference in the emissions between each.
1.8t golf, revo code, no cat, no cel, no problem
