Vrs Map on Standard 1.8T 4x4 skoda any difference
Just one thing though the car only runs around 15 psi thought it would run
around 19 to 20 psi..
Pulls alot better through the gears
Well chuffed
Regards
Pete
Standard is 9-10psi :confused:
HTH
  • Replies 61
  • Views 4.4k
I know its not the best tuned map but it was from Tunefood
My mate got it for his Vrs he is quite pleased but 4-5 psi extra
is no good for me so i'am just going to have to find a good map from somewere.
Thanks For Everyones help
Pete
cant you just get hold of the std map?
then try find a good program to tune it? I only wish i knoew what to do to tune or make a program for a cars ECU.
Try a different map if you're not happy with it. But I still maintain that you would have been better off taking off the standard map, getting that modified by a tuner, and then reflashing the car :thumbup:
Just Flashed my Elegance with the tuned Vrs file
Seems to run as before but with alot more power
The file I used had different hardware and software codes and it works fine.
Well chuffed
Regards
Pete
Can i ask what tool you are using to reflash the ecu?
iirc its the kwp2000+ thing lol
think it says at the start mate.
I've 18.8 psi in my vrs and that's with a bigger turbo. So I guess 15psi would be fine for the stock one.
what turbo do you have?
I thought we worked in Bar these days?
We do, PSI just confuses me most of the time.
I'm using willem programmer
Kwp2000 would only read the map but would not write the map back.
Turbo is standard k03s but iam looking to upgrade very soon
Just been looking at turbos not too sur which one to use..
sorry, i meant JMF :)
