i can't believe it
that no one has yet complained over this cold spell of water leaks into their cars from leaking windscreen washer pipes , maybe they haven't all thawed out yet , it used to be every other thread on the forum a couple of years ago
well i've just had to strip the tailgate trims off to refit the pipe onto the rear washer , PITA to pull the trims off , but i must say i have been lucky as its the first pipe to come off in 4.5 years, had to do the job as the rear latch/switch gets soaked every time you wash the rear screen
I had mine pop off yesterday, the connection in the engine bay though, not in the tailgate. A very simple fix.
-Duggie
-Duggie
same here, the one from the bulk head :P
You still have your rear windscreen wiper attached? Odd, very odd. ;)
my washer jets all froze solid for 3 days, but thankfully due to it being a "dry freeze" I never needed them seriously. Thawed out today for the first time. No popped off pipes though. :)
I had the engine bay one pop off the other day too.
AHHHH is that whats happened, tryed to wash my rear wiper this morning and there was water ****ing out the engine bay, i asume the pipe has come off the motor?
Although the front one is still working, is there seperate motors?
See post 3
theres seperate pipes at least. look between the air box and the engine cover at the bulk head. there will be a pipe sticking out and one hanging gushing out water when you use the jets. just reconnect till it clicks back on. I used one hand from beneath and one from above... doing it with one hand is nigh on impossible.
Mine keeps popping off in the engine bay, i re-connect it, then it's off by the next day again, so i've given up !
Try fitting a small Zip tie ..
Dean
Dean
Never thought of that ! :D
If i can get my hands in..i'll try that !
Well Ric I only discovered the other month that infact my car does leak through the rear doors. Only took me 4.5 years to notice. :(
If you're subject to an Epic Fail and run out of zippies after dropping them all into the bowels of your engine bay, you might get away with snipping off the last 1/2" (no more) of the pipe, as it may have split or stretched. But only do this if you're sure that your shortened pipe will reach!!! :doh:
Mine just reaches and no more, i expect thats why it keeps popping, as it's so tight. :(
Mine came off at the pump last year... Pain to get at through the wheel arch and liner
Mine was popped off behind the rear seats when i bought mine in November (plus having now washer jet or cover) and last week it popped off in the tailgate.
What a PITA to sort that out!!
Didn't bother getting the whole trim off I just yanked the top of the trim away far enough to get my hand in and jam the pipes back together.
Although i think they've been frozen for a couple of days now so likely to find more popped joints at the weekend! :thumbdwn:
My vrs has been in the garage for warranty work for 3 weeks. I got i back today still awaiting the CD multichanger back from the company fixing it and to top it off it is leaking washer fluid in the boot.
When I rang the garage back (D M Keith Bradford) I was told that the washer pipe pops off as a 'safety feature' to stop the pipe splitting in cold weather:confused:!!!!! WTF????? So as a safety feature my boot fills up with washer fluid? I think not.
After telling them I was a member of this site and I was aware of this problem they said they will fix it as a goodwill gesture!
To be fair D M Keith have been good to me but I felt they were trying it on telling me that!
Well, famous last words for me. Came to use my rear wash today for the first time - nothing. Definitely thawed out down here so clearly it's come detached somewhere. I suspect at the pump. :D Something to check at the weekend.
:rofl: i knew my thread would bring all the washer pipe problems to the fore :rolleyes:
bloody jinx, i went to use mine after reading this and yup, u guessed it, **** all!!
Happened in my old Passat, it rogered the alarm switch so it kept going off every night. Glad I had vagcom else I'd never have diagnosed it!!
Just tried my rear washer and nothing :( need to check it at the weekend
I use VAG washer fluid at the -16 option through winter and touch wood have not had any problems other than strange looks at the dealer when I bulk buy, get 10% off though.
That said I am in the warm north and we only had -8.
