Project minter gti
Surely after all this you will be putting a replacement air filter in - that one looks minging!! emoticon-0140-rofl.gif
  • Replies 350
  • Views 54.9k
  • I've got just the thing you need for your engine, looks like your inlet manifold is a 50mm jobbie. In which case, how about this to bling up the engine? Smoothed and chrome plated, very nice, wa
  • :gay:?
  • Got one almost finished and the other three in varoius stages. Managed to find the proper mk2 stereo blank at a dealers in germany after a lot of searching but finish's the dash off i think. Test
Looks fecking perfect.
Not long til you can drive it then!! :)emoticon-0148-yes.gif
I wish lol. Working in oxford for a month now and may get a weekend off but will not be getting much time now for the next 5 years due to work. Spent ages clearing out the garage at home and putting the engine back in so i could get the car in the garage out of the way.
Whats the long term plan for the car then?? Despite all the work, it deserves to be driven!!
Sell it to me. :)
I dont do long term plans as i dont keep them long enough :yes:
Still got loads of jobs to do and bits to sort out, inside and out but have to see what happens. Still want to build a super charger vr6 or R32 mk2 though.
Sell it to me. :)
I think there would be a few peopl interested in buying this........... :thumbup:
Well if you fancy a decent base for charged VR6 let me know ;)
Not touched the golf as not much time but did play with the daily.
Since i purchased it i found it came with a dealer fitted zender rear spoiler and 16v rear lights looking at the original bill of sale.
Lights were not a problem but the spoiler was rare and the boot was already drilled so i was going to replace the boot but ebay came up trumps.
Spent all day restoring the spoiler and re-making 2 of the 4 mounting points as it was 22 years old.
Bolted down in the old holes in the boot then the rest bonded on with a bit of tiger seal.
Looks better than the old grommets filling the holes. With it all the mounts done and cleaned up could easy double what i paid for it :)
Edited by Monkey Boy
Todays list of jobs done.
Gearbox filled and speedo cable with new seal fitted.
Engine oil put in.
Remaining coolant pipes fitted and filled with coolant.
Routed new washer jet pipework just waiting for my T piece.
Hella sticker put on spot lights.
Oem tyre pressure sticker placed in drivers door shut.
New wiper arms fitted.
Drilled rear arch's for G60 arch trims then test fitted to alloy me to trim the lips.
Connected and tested front lights
Reset door catchs to pull doors in.
Hopefully get the arch trims bonded on if the weather is ok.
Couple of pics.
That is just brilliant mate!
Managed to get all 4 of the G60 arch trims bonded on so just need to bond on the sill trims.
Made a new boot loom for the side lights, head screen and boot pop.
Cleaned up loads of spray dust and crap off the dashboard.
Then started on the engine bay. Got the rocker cover changed and started to fit the shiny bits.
Got the loom all connected just need to tape up the loom now i know all the final routes.
Looking good fella!
I think it could do with some black paint dropped into the lettering on the inlet manifold.
Looking good fella!
It's on my long list of jobs.
Nearly there now but it's fighting me the last bit lol.
Outside it's almost done as got both sills boneded on.
Had to make a power steering hose to adapt the raddo pipes to fit the mk2.
Engine back together now. The ISV i polished does not work so had to put my nice rsty one on. Needed a new battery as well due to using a octavia started i needed a battery with a higher cranking amps.
Car now turns over but does not start. Seams to be only firing on cylinder 4 but coil is fine. Dizzy cap looks a bit corroded so ordered a new cap and rotor arm.
Still got a couple of bits i need to paint.
It really is looking minty, and nice and complete!! Whats left on the to do list?
I hope you'll be getting a pukka photo shoot done when its complete, it certainly deserves it! Oh, then you can sell it to me :p
Very very nice!
Out of interest, how much did the paintwork cost?
AIUI he did the bodywork himself! Looks amazing mind.
Even top coat?
Did the whole lot even top coat :thumbup: . Happy with 95% of it just going to do a couple of small bits again.
Still have a long list of jobs to do but mostly interior now.
Got back from Oxford early so got a couple of bits done tonight.
Boot pop and relay installed. Fully working from my key now just needs tidying before i put interior panels back in.
Drivers side central locking motor all mounted and tested.
New reverse light switch installed and tested ok.
Sorted cables i need to cut into for central locking module to flash indicators.
Fuel pipes painted again but still need another coat.
New dizzy cap and rotor arm installed but still not starting.
Care to share the equipment you used? :)
Re not starting, what state is the metering head in. Are the injectors delivering fuel?
Maybe worth popping these out of the inlet manifold after cranking to see if they are
wet. Looks good nevertheless!
Just spent most of my dindins hour looking at this rebuild and reminded me of when i did mine
Its kinda giving me the nudge i need to keep the car and start working on it again.
Rather than getting another toy
Got what looks like a weak spark. Fueling is fine as all the plugs are covered in fuel when i looked at them after turning it over. Quite a common thing on 16v's.
Re earthed everything and all metering out ok. Tried the coil off the 8v and still the same. Could be the ignition amplifier.
Managed to get some other stuff done today though.
Used sound proofing paint on the doors.
Made plastic menbrane and all done. Central locking motor all done along with speaker wires
Passenger side all done as well.
Painted inlet manifold.
Pic of car now outside is somplete.
Absolutely amazing.
Stunning!
Managed to get the golf running at last but needs the timing setting up.
Started to clean up the interior and put it back in the car.
Boot all cleaned and fitted.
Sound proofed o/s rear quater and fitted trim panels
Power cable run into place with remote on and 3 RCA's so i can hide amp in rear quater panel.
Front all cleaned up and door pads fitted.
Got around fitting my eq only to find it will not turn on. Looks like it's got damp and all corroded. Another thing to buy lol.
Shame about the EQ, but its all good progress mate!! Can't be much more left to do surely?
