The new owner of the "Silver Beast"
Could be a coilpack failing, common problem on the 1.8T.
Not a huge issue then, are they expensive and is it a stealer only item?
Not that expensive, any VAG dealer will do to get one. Seat, VW, Audi, Skoda all use the same ones and have the same issue with the 1.8T.
You really need to get the codes read though to confirm the problem, and also if its one of the coilpacks which one is playing up. A failed coilpack could lead to unburnt fuel entering the exhaust system and that may explain the smell.
I wouldn't touch these with a barge pole! :mad:
Why not matey? Would I be better off going for Vagcom?
if its a coil pack wouldnt it run **** like on 3 cylinders
if its try these OEM - Coil Pack "E" - Single: TT Stuff
and this is the link to the liquid gauge you wanted
Awesome > Your Search Results
Tom I assume?
One of the lads up her hooked it up to Vagcom and it had these codes....
http://briskoda.net/diagnostics-vag-com/octavia-1-vrs-codes/143590/
Basically they are carp and will fail under load, stick with the VagCom idea.
Hi & welcome to Brisky!
Nice colour mate, by far the fastest colour RS!!
Steve:thumbup:
Ah, thank god it found a new owner... I still think of it fondly :)
