what bulb for octy 2
Hi, one of my headlights are gone, what bulbs would fit in my octy 2, year 2005
Main beam or dipped beam?
it's the dipped beam
^^^ There you go :)
thank you...
and why in the hell would skoda make it so difficult to change a bulb?!!!!!! argh.. my first dissapointment with my skoda!
It's not difficult. It's the most easy and straightforward bulb replacement I've had in a long time, including previous Skodas. Follow Andy's guide, pop the whole light unit out, change bulbs :thumbup:
How easy would you like it to be? :)
Also, for others - PowerBulbs - Car Bulbs, Headlight Bulbs, Xenon Bulbs from Philips and Osram, including Philips Xtreme Power and Osram NightBreaker globes. has a useful 'what bulbs do I need' section for all cars (and if you're a Freedom member, remember about the discount available).
Steve
I know what he means though. Some modern cars make it increasingly difficult to do the simplest things, such as bulb changes. Take the outgoing version of the Megane for instance, you have to remove the wheel to get to a flap in the arch, in order to gain access to the headlight to change a bulb!
In comparison then, the Octy is child's play!
I would like it to be this easy:
1. remove bulb holder
2. switch bulbs
3. put in bulb holder
that's how it's done in a volvo... no messing with disassembling the whole headlight unit.
I think that the headlight, indicator and dipped beam bulbs on the Octy II are pretty easy compared to most other modern cars, although the older cars I had were a lot easier I admit.
The sidelights on the other hand are a complete and utter ****.
i changed the bulb and must admit it wasn't that tough..... easier on a volvo though....
You have to send me a donut if you used the guide :thumbup:
Too fecking right - I intended putting my free Philips blue sidelight bulbs in after fitting the Extremes, but gave up because it looks like a few bits need to be removed before you can get to the bulb - probably have to go to the dealers or other expert. :mad:
Hmmm, interesting about the sidelights. I don't remember having any trouble :rubchin:
They might have been a bit tricky to get at, but past that....
And I don't have the most delicate of hands either!
Steve
You wanna try and MX5 with pop-ups! :-
Pop lights
remove fuse
undo screws and remove pop-up surround
undo screws and remove headlight retaining ring
remove headlight
remove connector
remove rubber cover
remove spring holder retaining bulb
REPLACE BULB!!!!
replace spring bulb holder
replace rubber cover
replace headlight
replace retaining ring and do up screws
replace pop-up surround and do up screws
replace fuse
put lights down!
ALL other cars are easy in comparison - including my brother-in-laws PT Cruiser that needs baby sized hands to get to the bulbs via an access cover in the wheel arch!
I think changing the side light bulbs on my last car, a Smart Roadster, must take the prize! The basic process & slightly shortened version of the instructions are:-
release bonnet catch & lift bonnet
undo all screws holding headlight surrounds in place & remove
undo all screws holding headlight units in place & remove
undo all screws holding side wings & front bumper assembly & remove
Yes folks, you basically have to remove the entire front of the car to change the side light bulbs!!!!!
Meganes are good too (at least RenaultSport versions) - that really requires the removal of the bumper for bulb changing, despite the inclusion of an amusingly small access hatch in each wheel arch :)
Steve
well i must admit i used the guide :thumbup:
And doesn't changing spark plugs require the removal of the rear bumper?... Way to go Mercedes!
  • 9 months later...
worst ive had so far was my last car a mazda rx-8 front bumper both wheels arch linnings just to get to any bulb.
My old volvo was a piece of cake as stated before apart from the spring clip could hurt your fingers when it was cold
With a slight redesign of the headlight you could possibly change the bulbs without removing the whole unit, they need to leave enough room to get your hands in.
to change the sidelight ones remove the whole unit, then get a pair of long surgical clamps (I got mine from a fishing tackle shop) press both lugs in and pull, while there fit LED no dash warning ones then forget about them for the life of the car
Steve
Also on standard models....had one in 2007. Absolute crap how they made it on them....mind you, the whole car was terrible crap....
