Drop Links
Afternoon All
When i collected my Fabia in November there was a very audible clonk from the front passenger side suspension.
On putting it up on my mates ramp it was diagnosied as a loose drop link, which was replaced and all was good....
...until I had my (also knackered) bushes sort out in March.
They were upgraded to a Cupra and Powerflex combination and are much much better that the split and crumbling OEM's that were there!
However i gained a light knocking from the drivers side which i just put down to slightly firmer suspension.
This has got progressively more pronounced and sounds very much like the initial drop link knock.
Wheels to full lock and a hefty yank on either side's link and there is definitely movement in the drivers side one where the passenger side one is solid as a rock.
I know when my mate changed the passenger side one it was only about £15 so i'm not too worried about the cost but where do i get them from?
From memory i'm sure all that was neeeded on the previous one was undo two bolts - remove old one - put new one in - do bolts back up - is it really that easy??
Cliff
Get them from dealer or independent VAG specialist. 10 minutes to swap out, nice easy job mate.
I can source them for you Cliff if you wanted :)
Go on then let me know the damage (bear in mind that i am sure it was about £12 for the last one! ;))
If the car's lowered you can also use the drop links from a mondeo - they're shorter than the fabia's apparently. Do a search on here for the exact specs....
It isn't lowered Bas, but it BLOODY WELL SHOULD BE! Eh Cliff? :D
i priced up some droplinks for my vrs recently and they were about £19 + VAT each from Skoda parts...
Thanks Basil but its on standard "lofty" suspension :D
Ok I'll PM you the info later today when I have it (could be early tomorrow), I expect it will be a v.similar price to this to be honest:
Fabia Anti-roll bar drop Link Stabilizer Bar - £19.99 : Skoda Parts, Jorily, The Skoda Parts Shop - Probably the UKs largest independent skoda parts supplier
Cheers Ed - hmmm maybe previous one was £20 then not £15!! ;)
Shut it you or you'll find that coincidentally your drop links go missing :P
Edited by PastyBoy
:eek:
Suspension thief :mad:
ive also noticed you can drive without one in one side lol...
I couldn't say. I've been selling both brands for a long time and both have been fine.
Also might be worth getting some new locking nuts if they dont come with them.
Just standard self locking M10 if I recall.
I changed them myself from memory you'll need a 17mm spanner and a Torx bit - I think it is a T30, if its the genuine skoda ones that is.
The bottom one can be a touch fiddly due to the arch liner but just takes a bit of patience.
