Squeeking from rear - RARB?
Hi All, recently my vRS has started to squeek quite loudly from the rear when goung over bumps - in particular speed bumps. The odd thing is it squeeks when the front wheels touch the bump, then again when the rear wheels touch but the sounds comes from the rear on both squeeks.
I'm wondering if it's the RARB - I have the Whiteline adjustable fitted. Any got any suggestions or encountered a similar problem? It's started to get very annoying!
Mines starting to do the same, been on less than a year. (If I rock the car from the front you can hear it squeak at the back), unless its the springs. Will find out next week when its serviced. Will probably put some copperease on if the supplied stuff has dried already.
