Turbo squeal!!!
:eek: Driving around when I accelerate you hear the turbo wind up and then after it it is accompanied by a further squeeling noise not sure if it is meant to be there or not? i have revo but it did it before i got revo. Any ideas it haoppens at about 2500 revs
Tis when the turbo kicks in, mine does it aswell, a lovely noise in my opinion :)
okay you get the turbo whistle and then the other noise after it is that what you get too?
I now get an interesting whooshy-whistling noise when accelerating hard over around 2500rpm.
This wasnt there before remap but its not a squealing noise.
that might be it not good at describing sounds :D
Hope its not the noise that my Superb 130PD was making, does it also make a wooshing noise a bit like a DV valve when the revs die as you change up? These are the 2 sounds my car makes, and it has a fault in the turbo system somewhere where the turbo is turned off, until the engine is re-started.
No remap etc done on it at all, been in the dealers for weeks, Skoda are now involved
Vince
Perhaps it's something to do with the cat.
Sorry....taxi!!!!!
its perfectly normal :) its the air in the engine becoming turbulent because of restrictions in the system..
btw how you likeing the revo? ;)
is it not the wastegate creeping open or the actuator? also do the diesels have a ****ty bosch recirc dv with rubber diaphram? it may have split.
