what model turbos fit??
Hello all, fair enough people say the pd130/150 garrett turbos fit on the fab VRS but what codes are these turbos??
Does a Garrett GT1544 T15 turbo fit?? bit random but just what i have been offered
GT1749VA & GT1749VB
The VA is the PD130 and VB is the PD150. So far as my memory persists!
Im running the VA on my ibiza as my KKK was shot. VB is better for hybrid treatment. (these are bolt on bolt off turbo & manifold jobbys).
GT1749VA & GT1749VB
so you have to change the manifold aswell ??
They come complete as one unit. All i had to do was rotate the housing for the intercooler hoses. Really simple.
those two turbos are correct.
There are also a handfull of KKK turbos that will fit. My Hybrid was a KKK from an 07 Ibiza PD130. You just have to make sure it is from an 8V PD block and it will bolt on.
All of these turbo numbers people are giving are just generic terms used for the different PD engines. If you are wanting to fit a PD150 Turbo from a golf, then that turbo is the GT-1749VB, and the actual part number that matters is; 721021-5006S.
Hope this helps.
