Electric Door Mirror Gremlins
Hi all. I have an '04 Fabia with electric/heated door mirrors. When I attempt to adjust the right mirror glass the left mirror glass moves as well. When adjusting the left glass, only the left glass moves (as I presume should be the case!). Does anyone know what may be causing this, I did think maybe a blown fuse (as similarly in the winter when my wiper fuse went, switching the front wipers on started the back one going which was cured by replacing fuse 15? seems a similar coincedence?). Have looked in the handbook and the fuse it stated for mirrors (I think) in my car is blanked off (no.11)? Thankyou.
Edited as I had a senior citizen moment and was talking Horlicks
Edited by MoggyTech
I have a 2001 Elegance and this is supposed to be how the mirrors work AFAIK.
The Right and left mirror are adjused together (the middle position on the kn0b IIRC) and the left one can then be adjusted independently (the bottom position).
HTH
Right moves both right and left and left moves left only so all is as it should be!
Thanks for your (very prompt) replies! All is fine then, I had faith my Skoda wouldn't let me down ;-)
No probs. remember you can hit the "thanks" button it on each post at the bottom down here----------------------------- >
