Octy vRS fault
Hi guy's,
My bro-in-law has a Octy 1 vRS with a fault in the engine torque sensor :confused::confused:
Can anyone tell me where this is on the engine ? A pic would be great but a desciption will suffice. Also is it a DIY replacement or is it a VAG/Skoda job ?
Thanks again
I dont think they have a torque sensor as such :rubchin:
Is'nt torque calculated by the ECU which uses info from the MAF, throttle body, boost pressure, charge air temperature and engine speed :confused:
Sure someone will be along soon..... and prove me wrong :D
HTH
I've a feeling you're right - what's needed is a set of fault codes, as it's not the sort of thing you arrive at by accident...
oops !!! we deleted the fault code and didn't make a note of it as it had done the limp mode thing twice but as far as i know it hasn't come back again since:thumbup:
If it comes back i will make a note of it then Doh!!!
