Fuel consumption on VRS Mk1
Hi
Can any body help that has their mk1 VRS remapped? I have had it done & getting about 320-350 miles to a tank not really thrashing it but has had a remap done by R-tech to take it to 210bhp.
Is this the normal amount of miles I can expect?
G Unit:confused:
Sounds OK too me.
I get 270 per week per tank,but thats around town in traffic virtually all the time.
Edited by fatty5000
mines had a stage 2 at awesome and i got 420 out of a tank going to france with 2 adults and two kids and luggage in the boot , but thats going a steady 65 most of the way
That's pretty good I spose
Mine is standard and in the summer gets 370 miles to the tank driving carefully, at the moment it has dropped to 350 with the cold weather so I suppose 320-350 with a remap isn't too bad.
Side topic:
Why less MPG in winter? I'd have thought the lower air temp would improve matters?
ip
Currently seeing 320-360 miles per tank in mine, also remapped.
Mine is stage 2, my last tank was about 28mpg.
I don't really use it for anything but fun though, so it probably gets a fair amount more stick than average.
I think I've got 400 before (from memory) but average is 300ish unmapped. Although on a steady 80ish trip to south wales I managed 350/360 before the light came on. The trip comp says 32mpg average over the past 3200 miles which seems about right. That's been a mix of driving hard and driving for economy.
Side topic:
ip
The lower the air temperature is the denser the air is, so the more air can be squeezed into the cylinders and the ECU puts in more fuel consequently. This means you get a better combustion in the cylinders so performance improves slightly but then the mpg also drops a bit :(
Plus more load on the electrics and the colder components which create a little more drag (well until their warm)
Hi
G Unit:confused:
Bearing in mind you probably have another 5ish litres left in the bottom of the tank, that's a good figure. 30-32mpg I expect. You can just do some sums and figure it out for yourself.
55litres will take you 420miles at 35mpg, and 360miles at 30mpg. Obviously it's impossible to use 55litres in one hit though, because you'd run out of fuel the whole time! So take a guess at 50litres typical. In which case 50litres takes you 385miles at 35mpg, and 330miles at 30mpg.
I'm always happy to see anything over 300miles personally, not that I normally care too much! Give it some welly!
I've had mine on bottom of the gauge and still managed too get 57+(iirc) litres in there.
How long are the pipes too the tank lol
2L worth ! :P
2L worth ! :P
It was a rhetorical question lol
:thumbup::D
Presume you're running 98/99 RON (hope so)! I have a Jabbasport Stage 1 remap, and saw 400 miles after driving like a creaky old tortoise. Usually about 360. Also once hit an average of 49.9 mpg (see attached) whilst following a friend's truck on the A1. :thumbup:
31320.attach
Funny you say that, when i had my last Mk1 vRS, with Jabba custom map, it got a lot better MPG, than my current one, with almost identicle mods.
49.9mpg :eek: that's pretty spectacular!
If you have recently zeroed the (2) Mpg and then drive it like a granny you can get some pretty high averages for a while until they settle down.
I think the best I've managed is 40mpg a couple of times on motorway journeys to Wales or France sitting at just under 70 in lane 1 :thumbup:
cool thanks every one
now going to see how quick I can empty the tank???
G Unit
I had 350 per tank with a generic remap and it was running 223bhp... how much is a tank full? cant remember....
1.06 litre £57.00
My vrs has been custom remapped and if I use 7psi boost max, I can get just over 40mpg on my 10 mile commute which includes 8 roundabouts and 3 "T" junctions.
Before the remap and other mods, I was getting 39mpg on the same route.
But dont get a remap to save fuel....it does'nt work, if I use full boost (and its very tempting :D) mine can see off a tank of V power in just over 200 miles :eek:
Before my remap I averaged 32mpg now I average... 32mpg :P
I also get about 30mpg on average, most of it done in-city. Best I ever had was 40mpg, driving VERY light-footed at a maximum of 100km/h.
Best i've seen since my remap is 45mpg.
65mph in lane one
