Anyone know an easy way to change a 2003 VW Polo headlight?
As the title really. Any help is greatly appreciated!
Probably similar to the fabia - 2 bolts on the slam panel, one down in radiator cowl type area, and one kind of hidden down the back which is a bit of a PITA to reach and undo.
Thanks Jason, I think I will take it to Halfords and let them do it for £6 to be honest!
If you're talking about the whole assembly, you're supposed to take the bumper off. The headlamp and the sidelamp are all the same assembly which the bumper sits in front of to create the illusion of two separate lenses.
I don't think Halfords will change a complete headlight for you! :wonder:
If you're just talking about changing a bulb then that's real easy! B)
do you mean headlight or the bulb? If its just the bulb I would have thought it would just have the same attachment as the fabia which just pops off with two push in clips at the top. Push them down slide it towards the engine and then lift up simples.
