Anyone taken delivery of a Superb II with Columbus that was build in week 45 or later?
Hi All,
Just wondering if there is anyone out there who has taken delivery of a car built in week 45 or later, which has Columbus?
If so, I'm trying to find out exactly what part number, HW version and firmware is on the Columbus.
If you know someone with VAG-COM (VCDS), then they can extract this information. It should look something like:
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 3T0 035 680 HW: 3T0 035 680
Component: RNS-MID H03 0904
Revision: AB001001 Serial number: SKZxxxxxxxxxxxxx
Coding: 040600000000008300
Shop #: WSC 00000 000 00000
No fault code found.
The above is an example from a very early Superb II. Cars built just before wk45 look like:
Component: RNS-MID H11 1164
I believe a week 45 and above unit should look like:
Component: RNS-MID H11 2664
Revision: AAN800001 Serial number: SKZxxxxxxxxxxxxx
but I'd really like to get some confirmation of this.
Why do I want to know, you might ask. Well, it's because my Columbus is faulty, and I'm trying to persuade the dealer to order a replacement that is running the latest hardware and software (think SDHC support, voice commands etc.). I know I can achieve a similar result by flashing newer firmware myself, but it would be nice to have it done via an official route.
Cheers,
Bagpuss.
Hi Bagpuss, what problem are you seeing with your Columbus as on mine it has recently developed a fault where the display is not showing my position, but the navigation is still working through the MFD?
I have tried to a reset, but still get the same issue
Ernie
Update: Its Ok, I reloaded the base disk and then put the V5 maps on and all is OK again
Edited by erniem
