Mk1 octy vrs ecu location?
Just found this thread.
I need to remove this black cover too. I have got the wiper arms off (two pin puller and some WD40 was essential) and I can lift the cover, which is in 2 parts (left and right) from the front but it seems to be 'bonded' to the wind screen. Are there any clips or is there a technique to doing it. Last thing I want to do is break it. No worries with the cold, its the hottest October on record and already 22 outside.
Cheers
Pull it out at 90 degrees to the windscreen. This picture shows the plastic channel at the bottom of the windscreen which is "gripping" your scuttle panel.
Edit: Oh, don't be tempted to leaver anything against the edge of the glass, unless you want to potentially break the glass...
Edited by mbames
