Vrs_Dta's intercooler job so far
right this started at the beginning of this week like this
then on tuesday night i put my car in the garage, put it up on stand and removed the front bumper n the crash bar
on doing this i then tried various methods to mount the intercooler as it is not a forge because i couldnt afford it lol and came up with this
this is on mock up brackets, i used the front bumber mounting to go off as it seemed to be the ideal place
so on doing this i offered up the crash bar to see if it fit and IT DIDNT lol so i marked it all up and done some measuring and found i had to take just over and inch out for it to fit snug
So any way i took it to work to get some modifications done but i couldnt resist on putting the bumper back on with out the crash bar it looked imense lol
BUT i wanted the crash bar on even tho it looked so good just for peace of mind that it is there as i dont know if the chassis legs would move when cornering of the likes and if i had a crash lol which i must say is not the greatest thing to do!
So any way here are some pics of the modified crash bar
i made proper brackets aswell while doing this it was just some 3mm ali plate cut to size
so any way seen as it fit i took it to work and welded tubes in the holes to try and keep a bit of strength and the painted the bar in black
as of finishing this well i am awaiting pipes to be derlivered to work and i am getting a forge map sensor pipe so i will let you knw how get on and i will post more pics heres one with the bumper back on cheers for having a look and feel free to ask any questions dave :rofl:
nice work looks good with the fmic bet u can tell a difference to the standard one :thumbup:
well not yet as it is not plumbed in yet as i am waiting pipes but hopefully it should help towards the 200hp mark when i get it properly mapped but i am wanting a clutch and turbo nest before i visit jabba sport :giggle:
Looks good! What FMIC was that suppose to be on?
its off ebay it was ment to be for a celica i think i just measured the job up and got as cclose to the measurements as icould
It looks good. :thumbup: I guess when you plumb it in you will remove the existing SMIC, although you could if there is enough space, run both. :yes:
I wonder if you will need it remapping again or weather the ECU will just adapt to the cooler air. I hope you get it all done by the end of the month, as I can't wait to see it at the Moors met (If you're still coming)
Looking good. Are you planning on running the outlet side back under the cooler and up the oem route to the inlet?
looks sweet - gj :thumbup:
Looks nicely done :-). Always liked the Fabia with the "Big mouth" mod. Shouldve been that way as standard IMO, good work ;-)
well the plan was to make a flater bit of tube and run it underneath but i am looking in to running it up past the power steering pump and that way but it makes sense to just go back underneath what do you think and while i am on the case where did you get your sandwich plate for your oil cooler and sensor :giggle:
how we doin jim yea i wil be comin it wont be mapped yet though i am saving for a paddle clutch and turbo but the intercooler should be piped in and in action B)
Looks good :thumbup:
I want to remove the crash bar but like you I was wondering if the front of the car would flex when cornering etc ?
How have you fixed the mesh in your bumper ?
I'm wanting to sort mine as its not exactly the best of jobs !!!
Did you put the vrs badge on the grill ? got the part numbers ?
The first pic of the cooler mounted without the crash bar look absolutely awesome.
Great work :thumbup:
how we doin richard erm the front grill is held on with silli gastket aka instant gasket sealer lol and the vrs badge is off a new octi i got it from telfords it was about 11 quid i think its just on with double sided sticky tape it does the job. i think when jabba do the crash bar the cut it out or half the size i have seen some with it gone like but i jus drilled holes in and welded tubes in :giggle:
any progress with pipes?:)
nope still aint here i am waiting for silcone bends 6 to be exact hopfully beginning of next week and then i will order the forge pipe for the map sensor :thumbup:
If it was me i'd spray i'cooler black. more stealth looking as the crash bar looks odd lol
any updates :D
lol nope still waiting god knows what is going on down the other end its been over 2 week now am ordering the forge pipe this coming thurs so whould have it done for the yorkshire meet if any one is going
do you mean map sensor pipe? Other pipes are recieved yet?
i am waiting for my 6 silcone hoses which are getting made via work so they are to come i have the ali pipe and i need to order the map sensor pipe from forge on thursday :smirk:
RIGHT i am finally done for those who are waiting its takin fekin ages lol but there here the pipes lol
this is as tight 180 i could make so thats the reason y it hangs down on one end it can only be reckitified by moving the cooler up but that means cutting the bumper mounts off :giggle: and i wasnt doing that lol so i cut the bottom of the front bumper out to let it sit nice :rofl:
i must state dont intend on doing this over a week end IT DOES NOT HAPPEN :'( lol but it does get done eventually just need a turbo and clutch the off to jabba for some mapping :giggle:
cheers for looking feel free t ask
dave
Nice! that looks like it took alot of effort to fit that in! :thumbup:
Just a random idea (though u might've already tried this), is there space put the pipe behind the raidator?
Edit: (brain working backwards atm, not phrasing things properly..)
Edited by JLneonhug
Nicely done, really love the look without the crash bar, looks evil! But none the less a very clean job all round :thumbup:
looks like you've went to a fair bit of bother to fit that in!!
a twin pass fmic would have been a far better bet though, seat sport or similar ;)
