Rear Bumper Squeek,any takers?
Vrs Rear nearside bumper squeeks where it adjoins the light cluster,never been molested with (or dinked) Going in for infamous brake noise too!! Am I jinxed? :confused:
I had the squeak you describe. Some nurd in a Sierra couldn't stop and shunted my old Fabia the first day I had it. To cure the squeak, I cut a small piece of clear plastic from a blister pack and eased it between the bumper and the body. It silenced the squeak, and being transparent, you couldn't see it. Where squeaks are concerned, a fraction of a millimetre makes all the difference!
Thanks for that,the War Dept has it at the moment,if it comes back unscathed I will investigate further!
Same as Martin, I notice mine when im polishing, can say it bothers me though.
interestging, mine does this too - mine seems a bit worse though as I hear it when moving but only when going over speed bumps in wet/cold weather. I've learned to live with it.
May be able to help..... Mine did the same squeaky rear bumper n/side
took it back to the dealers. The rear light lens needed lifting slightly and
re-aligning solved the problem. :thumbup:
Nice one,thanks. Its in to Whitequay Reading,8th Dec,will report on their ability to please!!
