Which engine
Hi all :)
Can anyone tell me what engine is in a 2006 Audi A4 Avant S line 140bhp ? Is it a PD engine? Any issues with it? Also what is the the 170 bhp version like in the SE model?
Kit :)
If it's an 06 model, I would say PD
Anybody? Somebody?...nobody? :(
K:)
I'm pretty sure that it was 2007 when Audi switched to Common Rail diesels, but I'm not 100% certain on that...
Almost 100% sure it's PD......
[edit] 2.0 R4 TDI PD 47-103kW
identification
parts code prefix: ???
engine configuration & engine displacement
inline four cylinder (R4/I4) Turbocharged Direct Injection (TDI) turbodiesel; 1,968 cubic centimetres (120.1 cu in); bore x stroke: 81.0 by 95.5 millimetres (3.19 in × 3.76 in), stroke ratio: 0.85:1 - undersquare/long-stroke, 492.1 cc per cylinder; compression ratio: 18.5:1
cylinder block & crankcase
grey cast iron; five main bearings, die-forged steel crankshaft, fracture-split forged steel connecting rods
cylinder head & valvetrain
cast aluminium alloy; two valves per cylinder, 8 valves total, timing belt driven single overhead camshaft (SOHC)
aspiration
turbocharger, intercooler
fuel system & engine management
Pumpe Düse (PD) direct injection (DI): engine-driven vane-type low pressure fuel lift pump, four camshaft-actuated (via roller rocker arms) high pressure Bosch 2,200–2,400 bars (31,910–34,810 psi) Unit Injectors with solenoid valve injection nozzles, Bosch EDC 16 or EDC 17 or Siemens VDO SIMOS PPD1 electronic engine control unit (ECU) with altitude compensation, EU4 compliant
exhaust system
diesel particulate filter (DPF) (not on Industrial variants)
EWG-rated motive power & torque outputs, ID codes, applications
47 kilowatts (64 PS; 63 bhp) @ 3,000 rpm; 200 newton metres (148 ft·lbf) @ 1,750 rpm — Volkswagen Industrial Motor - 447 (CBH: 05/07->)
55 kilowatts (75 PS; 74 bhp) — Volkswagen Industrial Motor - 455 (CBJ: 05/07->)
63 kilowatts (86 PS; 84 bhp) @ 3,000 rpm; 250 newton metres (184 ft·lbf) @ 1,750 rpm — Volkswagen Industrial Motor - 463
74 kilowatts (101 PS; 99 bhp) @ 3,000 rpm; 285 newton metres (210 ft·lbf) @ 1,750 rpm — Volkswagen Industrial Motor - 474 (CBK: 01/07->)
DIN-rated motive power & torque outputs, ID codes
100 kilowatts (136 PS; 134 bhp) @ 4,000 rpm; 310 newton metres (229 ft·lbf) @ 1,750-2,500 rpm — ???
103 kilowatts (140 PS; 138 bhp) @ 4,000 rpm; 320 newton metres (236 ft·lbf) @ 1,800 rpm — ???
applications
Volkswagen Golf Mk5, VW Jetta Mk5, Volkswagen Touran, Volkswagen Tiguan, VW Passat B6, Audi 8P A3, Audi B7 A4, Audi B8 A4, Audi C6 A6, SEAT Leon, SEAT Altea and XL, SEAT Toledo, Å koda Octavia, Volkswagen Industrial Motor, Chrysler Sebring, Chrysler Sebring (convertible), Dodge Avenger, Dodge Caliber, Jeep Compass, Mitsubishi Lancer,
Think the 2006 A4 is 'B7' variation :)
Cheers folks :) Well i hope its good as ive just bought it!! :) ...Picking up on tuesday :)
Kit :)
Nice engine where did you get this detail from. To the OP enjoy your car!
Looks like a cut and paste from WikiPedia to me...
