Octavia LED tail lights
Should have asked me mate I could have given you links to LED SMD bulbs that slot in and work ( I have them in my car )
Would have cost you about £30 for 2 cars worth.
A picture if you'd be kind enough.
  • Replies 61
  • Views 21.5k
The new golf GTD now has LED tail lights. Come on Skoda.
and the golf R..
Why would I want LED rear lamps and LED internal lamps? What is wrong with original stuff?
I've now got the LED internal lamps fitted and they are a LOT brighter. :thumbup:
Not only are they brighter but they are a nicer colour:
Here's a pic as i changed the outside reading lights to LED and left the main light. (now changed also)
Available on Alibaba.
Mininum order quantity: 50 pcs... :doh:
Looks like they are manufactured (and available) only in China.
but they can produce just over 82 pairs every single day of the year emoticon-0140-rofl.gif
Are your sidelights on as standard? do you have a vRS with DRL's or did you wire up the sidelights yourself?
Break Elegance Pack 1.6 TDI CR
Sidelights are 2 led SMD CAN-BUS
Interior are 2 T10 SMD and 36/39mm tubolar SMD( one should be CAN-BUS, if you let the lights go off they all do, if you close the car with the remote they come one judt a tiny glow, put one tubolar CAN-BUS and resolved the situation.)
Plate lights 36mm SMD CAN-BUS (their are lamps can-bus with a small heat dissiper on back, donnot but them they get really,really hot. Always SMD leds)
Mirror single led T10 SMD
Uploaded with ImageShack.us
Also put a 21w white led lamp on the DRL but it shows error on maxidot. I´am awaiting SMD CAN-BUS.
Edited by alberg
Wondering if the alarm will still go off with LEDs running at a much reduced wattage.
As the interior lights don't ever need to be auto enabled, using LEDs can't possibly affect the alarm. Also, following your theory, if an (oem) interior light was to blow then that would mean the alarm also failed. :S
Carl, does putting LED bulbs in the interior lights affect the operation of the alarm? Does the alarm work on a voltage drop, or is it triggered by the CANBUS when the door is opened?
Mike
The alarm can indeed be set off by leaving an interior light on (something i found out last week on SWMBO's MK5 Golf), not sure if it is also triggered by the door micro switches as well?
Mike
The alarm works fine on both my cars with LED interior lights :thumbup:
Hello, i am a new member of this forum . I saw that some of you are interested in buying LED taillights for Octavia Liomusine. Is there still any interest?
Depends on the price and how they look.
how they look you can see here http://www.skodacommunity.de/skoda-forum/skoda-octavia-ii-forum/57384-led-rueckleuchten-skoda-octavia-1z/index5.html or also here http://mlc-tuning.jimdo.com . On the first link are some pictures to see from my test here in Greece.the price per set is Euro 220.You have 2 years guarantee and if one damage,for example if you ave an accident, you can order also only one half price.
These LED Taillights are also available in Smoke and Chrystall.
Edited by Lambro
Genuine OEM Skoda is the only way to go.
LED tail lights are fitted to a Far Eastern version of the Octavia.
A lot of the patent versions do not have the vertical strip of LED's that form the traditional Skoda "C" shape.
I am surprised no one in the UK has managed to find and fit some by now...
Edited by silver1011
That's right. But the taillights i sell are having the original "C" shape. You can see that on the pics in the link from skodacommunity further up. The only problem we had when we tested them here was,that the 6 LEDs vertical were not lightning. This problem we solved and now all LEDs are lightning.
It's about time someone made these for the Superb Combi :rofl:
Also this Project we started and also for the Skoda Octavia Combi we are starting soon with our production. For the combi there will be also the flash in LED.
And for the Skoda SUPERB Combi??? :thumbup:
Yes,also for the Superb Combi.But still right now i can't tell you when they will be available. The only thing i can say is,that we are in the process of this project.
Edited by Lambro
  • 6 months later...
Any news? Some cars from Russia and Ukraine heve got it...(but not with full "C" lighting)
