FAO Ross clarke
Hay ross, trying to remove the alternator belt to replace it and the tenisioer, BLODDY hard job.......... :rofl:
Do you need a special tool for the tensioner to release its tension? or am I just being thick :D
Any help would be greatfull, as i have lots of blood on the wing of my car right now :eek:
Pete
Sorry 4got to say it is and octy Vrs :thumbup:
On the top of the tensioner there is a outward lug. A 16mm or 17mm spanner fits on that, you can then pull the tensioner over and lock it through two holes with a 3-4mm drill bit. If you cant lock it dont worry, just makes refitting it a bit easier.
cool, cheers ross, will try that :thumbup:
Can I just pick your brains again :rofl:
When fitting the pollen filter, can you remove the black cowling from the bottom of the window or do i just force it up?? As this seems to be a right ****, my hands now have 3 plasters on lol :eek: :D
Pete
Diy master lol, maybe not
They are tight, yes you can remove the scuttle panel but normally I just pull it up, hold it and slide the filter out. Be careful though when slotting the frame and new filter back in, the lugs that are on the bottom of the frame at the back must slot into the housing, if the fillter doesnt fit flush you will get water leaks.
cool cheers ross, godsend....
The alternator noise that i had was from the tensoner, it had a plastic wheel and the new one has a metal wheel, must have been an upgrade....
Once again thanks for the help :thumbup::thumbup:
Pete
Anytime :)
Ross YOU the man :thumbup:
i could have told you that ;) so because ross is a master tech does that mean i'm not wanted any more :mecry: :mecry: :mecry:
K look at it the other way...
You can put your feet up & drink beer, and let Ross answer all the Technical stuff :rofl:
Big K is too modest tonight to mention his tip of using a hairdryer to warm the scuttle panel before trying to remove or bend it. This helps to reduce the risk of the plastic cracking.
K IS STILL THE KRUISE KONTROL KING :D
K IS STILL THE KRUISE KONTROL KING :D[/size']
I could not agree more
You can put your feet up & drink beer' date=' and let Ross answer all the Technical stuff :rofl:[/quote']
damn i like that idea :rofl::rofl::rofl:
These young whippersnappers....... :rofl:
We are all a good team.
Dont know another forum where there are so many knowledgeable people.
K is the Kruise daddy, ive done a very small amount compared to him ;)
so does that make me the Briskoda Pikey Fabia Mod daddy? :D
You my son are very honoured having both of us working on your car ;)
You're just a Passat Killer :D
:D
