3 button Remote Fob ebay replacement for 2 button
Yeah use you're blade and immo in the three button fob
  • Replies 57
  • Views 10.3k
  • Yes they sure do........ Well it depends on what you have replaced. I used my original 2 button key and connected it into the 3 button transponder and I think it started working from there. By the
  • So long as you have the rear hatch lever by the drivers seat/door   You need the complete remote (bottom) half inc the three button pcb board inside.....so one bottom half casing, one three button r
  • .Sorry...................forgot you don't have the lever but according to the previous posts the conversion should still work.......just follow the instructions in one of the previous posts in this th
So you could you use this?
Could and How would you get the immobiliser coded with a blank blade half?
My keys getting a bit mankey and thought I would buy some new ones!
Edited by Pot Of jam
Ah, can you order the Skoda badged ones from that ebay seller? I didn't see an option to on his auction.
Nope but you can get the emblems seperate - see HERE
i must be thick or not following this properly :wonder:
how did you get the immobiliser to work with this new fob then? and did you put the two button key and end on the 3 button one?
cheers
Use the new 3 button remote half - with your old half with the key and immobiliser chip in
TBH my actual key's weren't the problem just the remote pad - so i havent needed to reprogram a new immobiliser chip(which i think can only be done thru vagcom) or get a new key cust
I did wonder whether its possible to move the immobiliser chip itself into a new 'case' - but i hear that they are very fragile and usually glued into the cases when manufactured, and once broken they are useless and you have no choice but get a new one and reprogram it
Steve
cool cheers for that, i think ill have to do this aswell :thumbup:
Mine arrived this morning and everything is working now with the new fob.:thumbup:
How easy is it to fit a solenoid so the boot will pop open when the fob is pressed?
Received 2nd remote from seller - again no problems :D
also received some emblems
and found it harder to get the worn emblem off the back of the remote (without stabbing /slicing/severing something that i'm sure i'd miss) - than the whole remote reprogram process :D:rofl:
Steve
How did you do it ???
I tried and failed about two years ago lol
Steve
Yep tell me about it...Did the same
I found best way was to get a pin or tweezers about carefully lift up one side. If is very hard not to damage the badge
You can get replacement emblems quite easy
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160469664043&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
What jaymd said, key came and works a treat, just need the boot to pop open when you hit that new middle button!:think:
Did you press button down and hold key for few seconds, then you should here the boot unlatch.
Few folks don't hold button long enough.
If not repeat the reset procedure listed above.
  • 1 year later...
Sorry to bring an old thread back up,but does it have to be a genuine Skoda three button key for this to work or will one of the replacement ones you can buy on eBay work(if I transferred all the gubbins over?)
Cheers in advance
Lee
Search again there's another post from a few weeks back, i'm sure it had a link to the golf4 forum instructions.
Is this a wind up?
took my key fob apart and there are only two buttons on the circuitery board, thought well what i read is it works so put it into a newly bought 3 button fob and as expected it COULD NOT work what a waste of money and time. this was for a 2 button fob of a 1.8 elegance 2002 model.
Is this a wind up?
err did you just buy a case?
You need to buy a complete key fob with the correct 1j parts code to do it.
I brought item number 250979938125, took the bottom bit apart, swapped transponder and blade then programmed it in. And it works fine
Now understand - read it as getting a 3 button key fob, now know to get a Complete intact 3 fob, thanks RAF for clarrifying this for me.
Tis ok m8 easy mistake to make, just make sure you get a 1j one. You don't have to take the main body apart just the bottom bit when you split it in half. The transponder is a lil black thing that looks like a grain of rice be careful with it! If you get stuck with owt just give me a pm and I'll help you as much as I can m8
Why take the transponder and blade off the old key?
The lower moulding is the same for both 2 and 3 button keys.
lol cos the key I got was as described! Ie like a brand new key no marks nothing. Plus my flipper was worn.
Fair point, well put :giggle:
  • 1 year later...
Can't believe that the Octavia also has this "hidden" feature as well! Did the two button fob to three button fob swap to my Fabia about 1yr ago after reading a MKI Fabia owners thread. .............
http://www.briskoda.net/forums/topic/248942-daves-fabia-14-16v/?p=3053010
http://www.briskoda.net/forums/topic/260977-second-remote-key/
Got my bits from this seller who several of us in the Fabia section have used & very good!
http://www.ebay.co.uk/usr/key_service
.........Skoda............ :wall:
My mates got a MKIV Golf with a two button remote & was wanting to convert to a three button but as I can't find a rear hatch lever by the drivers seat I presume that he doesn't have the correct release mechanism to enable this "hidden" feature"?. Only asking this as Octavia is based on MKIV Golf.......................also his is an "X" plate.
The hatch release on the MkIV Golf is mechanical, unlike the Octavia and some Fabias which have electronic releases. Your mate should have bought a Bora as it is possible to do the three button upgrade with them :happy:
Thanks for confirming my thoughts................................... :thumbup:
.............So now I just tell him the bad news.............................
"that three button remote is going to cost abit more than £20 & the car might look a bit different".............. :giggle:
So, all that's needed is the 3 key section off another fob, then a quick recode? And use the top half of my current fob? A quick look on eBay shows the 3 button fobs ( just buttons no electrics ) for a couple of quid. Really?
You need the complete remote (bottom) half inc the three button pcb board inside.....so one bottom half casing, one three button remote pcb board for inside................and NO recoding.....NO VCDS............
Get the bits from this guy as very good...email him as he knows his stuff!!! and he has done video guides etc
http://www.ebay.co.uk/gds/VAG-keys-VW-SEAT-SKODA-key-info-/10000000019533053/g.html
I and many others on this forum have used him over the years..............
