More limp-home problems on my 110
I was driving into work this morning and came to overtake a car at the of the 30 limit, as I was changing up from 3rd to 4th I felt a slight hesitation, got into Salisbury booted it and the car felt sluggish so I cycled the ignition and the car was back to normal again.
As I had to vagcom someone else's car, I did mine as well this morning, and guess what code I saw..... :'(
VAG-COM Version: Release 303.1
Control Module Part Number: 038 906 012 CL
Component and/or Version: 0000SG 3316
Software Coding: 00002
Work Shop Code: WSC 31480
Additional Info: TMBGP21U512486883 VWZ7Z0Y3096563
1 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
gggrrr! For the love of god now what is the matter with my car? I have had the turbo off and cleaned it just before Christmas, elephant mod'ed it, blanked off the EGR, fitted a few lengths of new vacuum hose (from the vacuum ball to the valve cluster and n75 down to the turbo).
I am starting to think the only cure for this car is a brick wall :D :D Shame as I wanted to get the old girl to 250k before she was allowed to retire!
Any ideas / suggestions?
N75? I have come across a couple of split diaphrams on the turbo too now try sucking the pipe maybe :|
Another thing to check is the air inlet pipe to the N75.
The N75 is a changeover valve. The three ports are vacuum, turbo actuator and air inlet.
The air inlet is connected to a plastic connection the air filter housing. This can easily be broken off, causing the pipe to drop down and get blocked.
I did change my n75 about 100k ago :-) Although I guess I might have to change it again.... is there anyway of testing the n75?
I'll have a suck on the control pipe at the weekend and see what happens. Can one source a replacement control bit for the turbo? and more to the point, is it possible to change without having to take the turbo off again?
Edited by mbames
I have a few scrap turbos kicking about that you could have an actuator off if you are stuck,
does it make much of a difference 'blanking the egr'? whats an elephant mod? :S
Cheers - might get back to you over the w/e. :thumbup:
Blanking off the EGR stops some of the exhuast gasses from being recirculated which seems then sticks to the warm oily air from the rocker cover breather and makes a horrible mess in the EGR and inlet manifold. The elephant mod is essentially a vent from the rocker cover to the atmosphere. The ideal solution is a 19mm catch can, so it filters the oil out and passes the air back into the air intake after the MAF, but I was doing mine on the cheap. This prevents any warm oily air mixing with the now non-existant exhaust gasses and should make for a cleaner running car (although maybe a little less environmentally friendly), also means your intercooler does not fill up with oil either!
cheers ;) my tdi has done excatly the same thing- twice in the past week, (same fault code) just got a new n75 (all hoses seem ok..) as soon as you cycle the ignition it clears..
another thing on the 'to do' list.. :S
The sticky turbo vanes is probably the problem, and the only real cure is to take it off and clean it up. Pictures from when I did mine: http://www.matthewames.co.uk/briskoda/index.php?loc=./20101112_turbo_clean I was hoping that as I had cleaned mine back in mid Novemember that would have solved it (first limp since then), so I am guessing something else must be wrong on mine too.....
Mine got worse and worse to the point when ever I accelerated hard it went into limp mode - made overtaking virtually impossible. A lot of my hoses were looking somewhat worse for where when they were clipped in, so I replaced a couple of them. I might check the rest at the weekend and replace them as the hose was relatively cheap (from a dealer).
How much was your new n75 as I feel maybe I should get one of them to rule it out of the equation....
new n75 from tps was in the region of £135 + vat :o i went to the local scrappy :thumbup: i might just try running on redex- i reallty dont want to strip the turbo off if i can help it- i think that will be my last option.. :S how did you clean the turbo vanes? what solvent? did you use? mines doing it once every week, so i really dont fancy the idea of stripping the turbo :( how long does it take to remove etc? i havnt got round to fitting the n75 yet- prob tommorrows job (just done arb links and bushes..) so i'll see how it goes on a roadtest..
fair play, looking at your turbo photos- that was stinking :thumbdown: did you notice much of a difference after the clean?
Aye, it worked properly, and was like a different car :-)
might try running on a few litres of additive- heating oil/ kerosene.. runs hotter and cleaner.. although theres not alot of lube in it.. that'll give it a good clear out :thumbup:
£175???? I thought they were about £20-£30 then I changed mine a few years back. Mine went into limp 3 times on the way home tonight - that is in 60 miles. Bu**er.
I just used my mother kitchen sink and some washing liquid! The job took me a long weekend, but I took my time over it.
I want to know what caused the car to decide an overboost has occured.... I am wondering if that sensor may be where my issue is - I have a feeling that might be the MAP sensor - anyone? I have heard if they get covered in oil they can become dodgy.
£135 :o
£175???? I thought they were about £20-£30 then I changed mine a few years back. Mine went into limp 3 times on the way home tonight - that is in 60 miles. Bu**er...
IIRC, the N75 is about £40 for the ASV/AHF
where is it available for £40 for the ahf?
Pretty sure mine is ASV, £40 sounds more sensible. I was wondering about MAP - I might start a new thread, looking at this from a different angle.
