Staging and Needle Sweeping?
Also, the less you fill the less fuel carried so the better the mpg?
  • Replies 53
  • Views 16.3k
  • Could you perhaps explain what "staging" and "needle sweep" is, because to me the first is something you do to produce something at a theatre, and needle sweep is looking for sharps on junkies, etc?
Hi!
It's in Instruments -> Adaptation, and if the actual consumption is 9% more than the maxidot shows, enter 109 for the correction factor. That seems unreasonably high error margin, how are you checking the actual consumption? I
On my Superb I have it set to 110% (it was reading 52MPG, actual 47MPG = 5 MPG too high), on my car it worked out that every 2% = 1MPG
HTH
  • 2 years later...
is the needle sweep possible on a non maxi dot dash board?
thanks
thanks
I suggest you ask the question either in the VCDS or Flabia section of the Forum.
